The Canon EOS Rebel T2i is a continuation of Canon's entry-level line of DSLR cameras, the Rebel series. The Rebel T2i is also known as the 550D and the Kiss X4.
Canon EOS Rebel T2i doesn't shoot
Hello!
I'm troubleshooting my Canon EOS Rebel T2i and I was wondering if you could spare some advice.
The camera turns on correctly, I can browse the menu and change the photo settings without any issue. At this point, I can also turn the camera off using the power switch.
The problem appears when I take a shot. Regardless if there is a lens installed or not, the screen remains black and the little LED at the bottom-right stays solid red. The camera instantly freezes and ceases to function.
A couple of observations:
  • The mirror seems to work fine. I can hear the mirror going up and down when I take the shot, and I can physically see the mirror moving when shooting without the lens.
  • If no memory card is installed, the LED light remains unlit. If present, stays on solid.
Lastly, if the camera freezes, I must remove the battery to turn the camera off. The power switch won't engage.
Do you guys have an idea of the part(s) at fault?
Thanks!
Hello!
Reading similar posts, I figured that the problem with my camera could be either a broken/faulty mother board or a SD board.
Is there a way I can determine which one is at falult?
How can I test the SD board, so I can rule it out?
Thanks!!
Hello!
I solved my own problem, and I thought of dropping a line in case somebody could benefit from it.
While troubleshooting, I noticed a message "Err 80" in green letters in the viewfinder tiny display. I did a brief research online and found out that that err 80 is a generic error (dang!) and most people linked it to a motherboard failure.
I was getting a little frustrated, so I decided to take a leap of faith and replace the motherboard. The replacement was successful and I now can take pictures again.
A word of warning for all the non technician people (like myself!) attempting to this fix. I fixed laptops and phones in the past, but I must admit that I struggled a little bit during the camera motherboard replacement. Screws and flex cables are tiny and very many of them. I think it's still doable, but I strongly advise to read all the useful guides you can find on this forum beforehand and reserve 2 solid hours to complete the board replacement.
Luke crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 970
