Mohamed from Egypt,
my friend, please do not Jihad the ipad. bleeding it will not kill it.
Kidding my friend,
when you say Bleeding, are you saying there are areas on your screen that look like dried water spot areas or something, like where a line has been left behind from where it got wet ?
if this is the case then you can try this, but, i must warn you if you dont do it with the gentlest of touch and do it the way the guide tell you to do it, you will crack the front glass.
So you have been warned. take a blow dryer, and warm the black or white colored trim take the glass off and see if you can clean the back side of the glass off with a mild cut windex, lay it on a flat surface and be very very very gentle no pressure, because I promise you will crack the glass it is very thin and i have replaced at least 200 of them and i still crack them on occasion. don't clean the digitizer screen with windex. make sure it is cold when you do it. Watch several short You tube videos of people showing you how to remove the glass without breaking it.
Clean the digitizer with Distilled water and a lint free cloth. also your going to have to do it in a very dust free area no wind or fans. you will end up taking it off and on 50 times because of a piece of dust will keep getting in there and you will swear you had it totally clean. the best way to do it is to do it in the bathroom right after some one has taken a hot shower the moisture will take all the particles of dust to the floor and you will have the closest thing to a clean room there is.
if it is still cloudy, then you need to just buy and replace both the front glass, the outer bezel and the digitizer. buy it in one piece off of ebay. or go to the apple store if it is under warranty it will be free
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
0
