Device and repair guides for the RCA 10 Viking Pro, an Android tablet with detachable keyboard that can be identified by model number RCT6303W87 DK.
crwdns2934591:0426crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Screen can't use it
My touch screen I can't do anything with it????it just gos nuts
Hello Marvin
It sounds like your digitiser might be faulty.
You can buy a new one from here.
You can see a screen tear down from here.
Hope this helps.
David
My Computer Dude
Have you tried resetting your device? What about performing a firmware update? If problem still persists, open up the casing and check the ribbon cables. Make sure they are tight and snug (make sure your device is powered off while performing this step; will void your warranty). If the problem continues to occur, most likely your touch screen digitizer is faulty. It is relatively easy and inexpensive to replace (replacement panels start at around $8 on eBay or any other retailer). When buying a new panel, ensure that model and version number matches yours. Hopefully this helps.
  • Hit <enter> to insert another list item, and <enter> twice in a row to end the list. To get subitems, repeat the bullet character once for each level of indent you want (e.g. **)
My screen won’t work and I can’t get in
crwdns2942205:01crwdne2942205:0:
And it’s cracked
Marvin crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 991
