A budget companion phone for the Galaxy SIII, Also known as Samsung I8190 Galaxy S3 mini, Samsung Galaxy S III more. Available as Samsung I8190N Galaxy S III mini with NFC. Identifiable by the model number GT-i8190.
Why can't I turn my phone on? Battery is checked OK.
Hi,
My phone suddenly went down. I thought battery was low, so put him to charge without success.
It won't turn on nor charge (always black screen, no light). My external batterie detects the phone when connected, but the phone stays off and not charging.
The battery seems pretty charged (3.3V on 3.8V)
I tried VolUp+Home+Power, VolDown+Home+Power, VolUp+VolDown+Home+Power, but nothing happens...
Is the motherboard dead ? repearable ?
After more tries :
- Battery is OK
- Charger is OK
- should not be the power button because it does not react to charger (no charging screen)
- should not be the screen because no vibration when pluging charger or try to power it on
- The phone don't react when i try to power it ok whith a fully charge battery
To me, it sounds like the LCD is out. You could buy the LCD replacement but it would be more work than needed. If it were me in this situation, I would purchase a used Galaxy s3 mini of the same model as yours (since they are selling for around $30 to $40 online) and swap out the motherboards. That would allow to keep all your information and would only take about 10 to 15 minutes to swap them over.
If this is the route you take, and you are still having the same issue, then the problem lies on the board.
Thanks for the reply, but i don't think it is the LCD because the phone do not vibrate when i try to turn it on... It is probably the motherboard who died...
hopefully the lcd is not out. i know for some strange reason phones will not charge or come on unless they are charged with the factory charger one that produces a whole lot of amps in charging. My suggestion is to see if maybe charging it with a more powerful charger can help out. i have had this problem with tablets before and that worked for me. I hope that this is helpful.
Thanks for the reply. I tried to put another battery (fully charged) in the phone but the phone still dont react when charging or when i try to turn it on. So another charger should not resolve the issue either...
Nico crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 217
