GSM version of the fourth generation of iPad released November 2, 2012. Model Number A1459 / 16, 32, or 64 GB
Why can't I get 100% charge anymore?
I keep my Ipad 4th generation model A1459 on my nightstand 99% of the time and leave it connected to the charger. It has been staying at 100% full charge. Some days, when I take it off and use it, it drops to 90% charge and then goes back to full charge after being connected to the charger. I noticed today that it is only 93% charged even though it has been connected to the charger for several days. What could be the reason it is not fully charged ? Could this be a problem with the charger or the battery ?
Try leaving your laptop on and drain the battery to zero, then charge it back up to 100%. If this doesn't work, them you might need a new charger. It isn't a good idea to keep a device connected to a power source all the time. Doing so can result in a device overheating and causing problems with thr internal workings if a device. Hope this helps.
dorglet crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 82
