The ProScan PLT7223G Tablet, manufactured by Curtis International, is a basic Wi-Fi enabled tablet that is intended for personal or professional use.
Why won't my ProScan tablet connect to Wi-Fi?
My ProScan isn't connecting to my wireless internet
-I have tried restarting the modem and router and it still won't connect.
-I have restarted my tablet, however, it still isn't connecting to the Wi-Fi.
-I tried the factory reset on my ProScan but won't connect.
Is this a problem with my Modem/router or my tablet?
There are many reasons you could be having Wi-Fi connection problems. First it may caused by Router or Modem problems. Or sometimes the device wifi receiver may have to be fixed or restart.
So if Wifi symbol does not appear and web-based applications will not load, what you need you need t do is restart the Router firstly. If it still cannot connect to wireless network , you may have to reset the device to fix it. Check out the ProScan PLT7223G troubleshooting page for more information at ProScan Will Not Connect to Wi-Fi.
Because I've yet to see a REAL D@*%N answer on this! I'm guessing your issue is that you keep getting thrown back an Authentication failure when attempting to log into your wifi settings when you know for a fact you can log into open wifi networks and that the information to log on is absolutely correct. Well hate to break it too you but your security type on your wifi may be to advanced for your proscan. If you are using a security mode that is supported by WPA then you'll run into this issue. You'll have to have something that will provide a WEP security in order to connect. Downside is that WEP is not as secure as it use to be so you may need a router that cast 2 wifi signals. One specifically as WPA and one specifically to WEP. I spent HOURS trying to figure this out. If this saves someone even 30 minutes, I'd be glad.
you didn't accept my answer for if this was helpful... lack of experience and know how is on a low but i have tried all mentioned and my answer is still no
Honestly, I don't frequent this forum very often. This is my first time back since I posted this and kinda shocked that it was even helpful to anyone. I think the real solution is don't buy a ProScan tablet...
Daniel Hernandez crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 9,137
