Why can't turn on wifi, hotspot and bluetooth on note 3 SM-N900?
There are some good options on this page that may help you
I just turned airplane mode on, and then back off
My wifi for note 2 is not turning on hotsport and my radio are not turning on. Help me pease
The wifi in my note 3 isnt turning on but also it got dropped in toilet before too.
I have had nothing but trouble since I was given this XiaoMi Note 4. Have nearly thrown it against the wall several times. Now it is refusing to turn on the wifi. I touch the wifi on and it turns on for a second or two and then flips off. I've tried clearing the cache, did a backup and reset, removed the battery and reinstalled it......nothing works. I think I will use it for target practice the next time I go to the gun range. Truly a piece of crap.
hello friend,
dont give up.
kindly go to your app settings and uninstall BABEL FONT update.
thank me later.
Thank you Joshua.
I have been frustrated since this wifi, hotspot and bluetooth issues started.
I can work comfortably now.
You are a life saver!
May Bluetooth and hotspot is not working way
Thanks okejoshua they are working now
Don't know how to thank you enough for this...I had tonnes of forum and blogs to read as regards this same problem but this simple solution saved the day... Thanks very much again Josh!
@okejoshua
Your response about uninstalling babel font update fix the issue on my Infinix x551.
I really appreciate. Thanks to this website
Please give me the answer
Guys, I also had the same issue and it's been bothering all these while. At a point, I even had to restore factory settings which made me lose omega of my personal files and data. The second time I had this issue was when I saw Joshua's advise... I uninstalled the babel fonts update and it's WORKING PERFECTLY LIKE MAGIC. Thanks bro.
My hotspot, wifi& bletooth not work in my infinix note 2 x600 Phone and dont have babel font.
what can i do sir?
Same thing happened to me- go to settings, backup & reset- reset network settings- works like a charm- everything is working perfectly now- try it! then try to reboot it
How can i locate the babel font on my infinix note 2
Go to app settings. Babel Font is an app. Just Uninstall the update. I had same issue with my infinix Note 2 as well as this solution solved it!
i cant see babel app
Pls I have uninstall my babel font but still problem still not resolve do I need to disable the babel font too
Hi
Pls help, my infinix note 4 is not connecting on Wi-Fi and also bluetooth.
Pls help me
Thanks. Your response about uninstalling babel worked. Thanks a lot
Where I can find babelfont?
Babel font can be found ur list of apps
Settings>applications>all apps
Babel font can also be found in
Play store>my apps
My hotspot,wifi& bletooth not work in my Phone huawei Y221-U22.
what can i do sir?
I have note 3 but dont have babel font. What do i do? Tried switching it on safe mode, doesnt work.
i also have same problem.. please help...
Same here...no babel font app or update shown...wifi and blue tooth never connect.Done a hard reset and clean install...safe mode...nothing works. WTF?
I’m having the same problem I have wiped my phone clean and I can’t connect to WiFi to even get my apps back on my phone
Same here
Any one found a solution to this??
Same here. Please help me
I have an issue with lenovo k5 pro. Bluetooth can't turn on, hotspot can't connect, WiFi has an issue. Anyone who can help please.
I'm not sure but after trying everything I think the issue can be insufficient app permission but I don't know which ones exactly I can grant permissions
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 80,915
crwdns2944067:06crwdne2944067:0
I can say yes but cant no what a crap. This answer doesnt solve my issue.
crwdns2934271:0crwdnd2934271:0 nb rk13 crwdne2934271:0
I can't turn on my Bluetooth!!!!!!
crwdns2934271:0crwdnd2934271:0 Saratul humaira Mahima crwdne2934271:0
i solved it finally... just Hard Rest it. turn it off then press power off and volume up together then select Wipe Data./Reset factory
crwdns2934271:0crwdnd2934271:0 Jackie Daguinot crwdne2934271:0
Just uninstall Babel Font and see how it turns out. If you still have the same problem go into your phone and sd card storage and delete all files you deem unnecessary. I did that and You won’t believe it! everything was back to normal.
crwdns2934271:0crwdnd2934271:0 gatunemoses crwdne2934271:0
i dont understand this clap, i have infinix note 2 lite it stated those behaviors three days ago and am very stressed . okey i did everythink like everything, hardreset, factoryreset,deleting babyfont both in phone and in sd card bt nothing anyway sometimes when i hardreset it work okey bt for sometime like an hour and then turn its self off bt for now it is on bt it keep scannig and no WIFI show and still bluetooth having the same issue and radio too soo anyone can help plz i will appreciate it or just chat me on this number +254700042279, {facebook page wiliekamash}
crwdns2934271:0crwdnd2934271:0 wilie kamande crwdne2934271:0
