fabric softener won't empty
fabric softener will not empty into washer
If the fabric softener is still in the fabric compartment at the end of the wash and it hasn’t been taken out it could be because the washing machine has aborted the program before reaching the section where the softener gets taken. If this has happened, you should get some flashing lights or a program selector clicking round, or some other error code display indication telling you the wash has aborted. Once this fault has been fixed the fabric conditioner should flush in OK.
If washer is completing wash cycle OK –
Fabric conditioner If the washing machine is going through the wash program properly, but the fabric softener isn’t being taken out it’s possible the water valve which flushes it away into the machine has failed. This is relatively rare because the fabric softener water valve only gets used for a few minutes each wash but it can go faulty.
Also, some older washing machines didn't use a separate fabric softener water valve and could instead have a movable nozzle that directs water from a single cold valve into the fabric compartment. As the program selector moves round there is a lever system that goes from the control selector to the top of the soap dispenser that moves as the program selector is turned. It's possible for this nozzle to jam, or the spring to come off meaning water cannot be directed into the fabric conditioner compartment.
The reason I’d suspect the softener fill solenoid valve (if fitted) is because if the fault was with the cold water supply itself then the washing machine would hit problems when it first tried to rinse, or as most washing machines are now cold fill only when it first tired to wash. If the fabric conditioner is still all there after a wash and the washing machine hasn't aborted you need to find out why water hasn't entered the fabric conditioner compartment by checking the connections on the softener valve.
Sometimes the soap dispenser is bunged up with mould and a black jelly-like substance which can block the nozzles at the top. However, this condition is more likely to cause the softener to be taken out too soon due to diverted water from rinsing straying into the softener compartment, but it’s worth checking. Take out the soap drawer and inspect the roof of the dispenser. If it’s full of black gunge maybe it’s deflecting water away from the small fabric compartment – Black jelly-like substance in soap dispenser and on soap drawer
Other than that, the softener valve might be faulty (open circuit) or not getting an electrical supply or neutral return.
My washer is brand new
@hegwohl It's covered under warranty, if you attempt to repair it you may void that warranty.
The unit uses the fabric softener. At the end of the cycle the fabric softener bin is full of clear water. Still looking for resolution.
Like John Brandt indicated the issue is that the softener is being used but the softener bin is filling back up with water. This happens whether or not I add softener. I have to empty it after every use.
I have the same problem , but my washer won't even get rid of softener..My washer 5 or 6 years old, but it has done it from day one.. I just stopped using liquid softener and went to Gain Fireworks pellets...
crwdns2947821:0crwdne2947821:0
I have a Maytag maxima washer that I just spent a couple days trouble shooting as it wasn’t dispensing softener. Took the removable tray out and cleaned it, but still no luck. I confirmed the “siphon” tower inside the softener tray was clear. We live in a rural area and our water is very hard and has a lot of iron in it. It appeared that water was being delivered to the bleach compartment but not to the softener. Tried scrubbing the holes in the top of the tray receiver with no luck. I removed the top panel of the washer and ran it through a diagnostics test (should be a manual affixed to the inside of the top panel which explains diagnostics and troubleshooting). The diagnostics test was returning no errors dispite the problem. While running the diagnostics test I observed the entire cycle to make sure the arm that controls the rotating valve inside the dispensing tray was operating correctly. If the arm is not moving then the motor that controls it has likely failed. I removed the top of the tray receiver and completely disassembled it. You will need to unscrew a few screws to drop the tray from the washer frame. Then push the receiving tray back to release it from the frame. There will be several tabs around the tray that need to be opened to remove the top of the tray reciever. You will also need to remove the valve motor and operating arm linkage (take picture before you pull part). I then put ‘lime away’ inside the channels that run up to the holes that dispense water above the softener tray and bleach tray. I then blew out the holes and channels with compressed air and ran numerous pipe cleaners twisted together down each channel. There was obviously a blockage as this fixed the problem once reassembled. At the same time I took the opportunity to clean the drain trap which requires removal of the front of the washer which was jammed full of junk. I also thoroughly cleaned the gasket in the front of the washer which was also a mess. I ended up removing the tension band that holds the gasket in and used soapy warm water and a sponge to clean the gasket. I also removed and inspected the hoses and screens to make sure they weren’t plugged which can affect your water pressure inside the washer. Good luck, I hope this helps someone out there!
Mine has done this from day one..Brand new. Just fills up with water, has to be dumped every wash.. softener side and soap side fills up with water..soap side drain normally, but fills up with water... I'm gonna try vinegar and use tooth brush to scrub it...
I have a MAYTAG BRAVOS
Brand new Maytag MVW6500MBK0, softener dispenser is not working from the day one.
I have a new Bosch washing machine series 6 and I ready the manual before use. Still it doesn’t take softener from middle - softener drawer. I called the supplier, they came and took it back and brought another new one but still same problem. Technician came, opened top cover and found no water pipe connected to softener drawer. Why is Bosch misleading customers like this? I feel that I wasted my money on this. If Bosch can reply please I will appreciate. geoffreygekonde2@gmail.com
Hi Geoffrey,
I’ve noticed the exact same problem with my Bosch series 6. Did anyone ever get back to you?
Amrit
Yes im also facing same issue i have only 5 days back n facing this problem
I had the same issue.. if the washer isn’t level, it will not add the softner.
I got my Bosch series 6 today . On the display panel it is showing up a red light a tap sign and the fabric conditioner will not dispense through the drawer . Apparently this is meant to mean low water pressure. If there is low water pressure the fabric conditioner will not dispense into the wash.
Bosch washers are not well made. I had to replace mine after two years. They are junk
I have a commercial technology maytag washer. My fabric softener stopped emptying during cycle. Finally I suctioned it out. Turned off fabric softener added cycle. Just use the downey ball. But now I get light grey stains on my clothes. How do I fix these issues. This is my 2nd nee maytag washer in less then 10 yrs. I have always had maytag, but becoming a little unhappy. Help!!
crwdns2936753:07crwdne2936753:0 34
crwdns2936753:030crwdne2936753:0 184
crwdns2942667:0crwdne2942667:0 115,170
crwdns2944067:06crwdne2944067:0
My fabric softener is getting out but then it’s filling back up with water. Any ideas?
crwdns2934271:0crwdnd2934271:0 Bridget crwdne2934271:0
Mine is using all the softener and then filling back up with water what do I do if it does that and the water will not drain
crwdns2934271:0crwdnd2934271:0 Caitlyn Crawford crwdne2934271:0
Maytag bravos xl washer fabric softener dispenser filling back up with water or does not empty, clogs washer leaks water from underneath. Repairman out 2 times. Cleaned softener of gunk. Approximately a month between repairman visit.
crwdns2934271:0crwdnd2934271:0 wsmoore@bellsouth.net crwdne2934271:0
I just got my Maytag and having the same issue. The detergent and fabric softener are draining but then it fills with water every time. I have have to empty the drawer after every load. Any suggestions besides taking it back?
crwdns2934271:0crwdnd2934271:0 Lisa McCleary crwdne2934271:0
I filled my fabric softener dispenser with vinegar and let it sit for a few days. This cleared up the clog and I can use the dispenser again. You might have to do this more than once.
crwdns2934271:0crwdnd2934271:0 Jackie Slivatz crwdne2934271:0
