Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
Battery won't charge even though charge port and battery replaced
I have an iPad 3rd Generation with a power problem. The battery simply will not charge. When I installed a different working charged battery in the iPad, it did turn on but once the battery was drained it wouldn't charge either. I tried replacing the charge port with a known good one, and I checked the data cable and a/c adapter; all were fine. If there is a charged battery installed, everything on the iPad works until the battery is drained, then the iPad is dead. Can anyone tell me what else could be wrong?
crwdns2889612:0crwdne2889612:0 -1
If you have tested with know working parts then the charging system or charging IC chip has failed or other componets on the logic board. This would be a board level repair.
AZMICROREPAIR crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 192
