Released in October of 2014. This model, SM-G530H/DV Samsung Galaxy Grand Prime, comes in a White, Gray, or Gold casing.
My Phone Won't Charge
Hello! I kinda need help, my phone wont charge correctly and I can't find a solution. Last night I plugged my phone in to charge it (Note: it was at 3%) and it showed the charging icon and so I went to bed, well when I woke up the next morning my phone was still at 3% it says my phone is charging and I tried restarting it and taking the battery out, but to no prevail. Any help is appreciated Thank you.
G530h when power off charging work butt phone on can't show in icon
crwdns2933315:08crwdne2933315:0
Thanks for your question.
Sorry for your troubles.
From what you are describing, it soukds like your battery may be the reason for your problems.
Because you are getting the charging icon when you connect the charger, the usb cord, charging block and charge port seem to be working.
What isn't happening is the battery is not taking the charge that the cable and block and charge port are giving it.
The first and cheapest way to test a solution is to replace your battery. Make sure the new battery is an OEM (Original Equipment Manufacturer) one. If someone suggests something else other than a Samsung battery, tell them to shove off.
I just checked prices and a new battery shouldnt be more that 20 to 30 bucks.
If the issue pursists then seek out a trusted cellphone repair professional for power issues. Those, for the most part, are straightforward repairs.
Hope this helps.
Good luck.
My grand prime is less than 8 months old. Why should I have to pay for a new battery. The battery heats up too much.
I have the same problem and I got a new battery but it still doesn't work. ( The battery was only $12) ( Yes it was an OEM)
I have same issue. I think I have to buy new battery.
thanks
My mobil is not charge when he is above 94% charger plugs in but he is not charging what is saloution
My Samsung galaxy grand prime plus doenst charge fully it on My charges till about 70 and it says unfortunately this app as stopped and etc.. I'm not sure what to do
take the battery out of your phone but leave the charger connected and holf the power button for about 10 secconds. disconect the charger and put the battery back in, then re connect the charger. always works for me :)
That does not work at all! Not for me at least. After almost three years, my Galaxy Grand Prime refuses to charge. Period. Nothing works, nada, zip. Replacement charger, and replace cord, nothing. The phone was not dropped, not got wet, no rooting. Just normal usage. Then within a period of 3-5 days the phone has refused to charge the battery, and won't even turnon, with drained battery, when plugged in. Went through multiple sockets, that are known to work, nothing. Just refuses to charge. When it does turn on, it immediately issues, critical power level, with 1 or 0 % remaining, then shuts off.
I have same issue.
Honestly i don't even know. But it worked!
the posting of January 6th is MISLEADING. The dude is wrong. There are known issue with Grand Prime which Samsung won't admit. You have to re-heat U420 and U421 chips which are located under CPU. If that doesn't work the chips have to be replaced. The best way is to get rid of this lousy model and get something decent.
I have problem with.my samsung galaxy grand prime. I accidentally fell it and now don't start even I change the battery. They said it's a motor. If it's true where I can buy and how much
I have my own issue grand prime too. It won't charge when off and does not recognize PC.
i have Galaxy grand prime plus . when i connect charger it starts charging for 5 to 10 seconds then it is disconnected by itself. screen start blinking due to connect and disconnect of charger. charger and data cable is absolutely fine. kindly suggest me solution ?
Same exact problem as mine!
I have bought a Grand Prime Pro three of us that will not be charged again after using an OTG cable, showing the battery icon and it stays and does not charge, I charge the battery and charge it on another cellphone Samsung Grand Prime, and there is no problem if Can you help me?== Heading text ==
I have a ssung grandprime its battery full (100%) then i can use only 30% charge batter icon is coming tobellow 70% then my Phone is go to switch off automatically
First battery complainted Now using another one what i do?
I have the same problems my samsung grand prime the first day it charged well but when I insert sim card did not turn on until I removed the battery and drain power and turned on. But when I connected to a charger the phone is not charging and battery icons is just blinking. Help what can be the cause
buy new battery or try factory reset it work for me
Leo Boss crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 48
crwdns2942667:0crwdne2942667:0 37,321
