Drive Belt
The drive belt is a very long, slender belt that wraps all the way around the dryer drum, around a tension pulley, and then around the drive motor. Over time, the drive belt can become frayed or otherwise damaged. If the drive belt is frayed or damaged, the dryer will be noisy as it turns. Inspect the drive belt for signs of wear. If the drive belt is worn, replace it.
Parts
Drive Belt for your Dryer
Drive Belt - Part # 1480895 Mfg Part # W10136934
RepairClinic Item #1480895
Drum drive belt
$37.00
Quantity:
In Stock
Same Day Shipping
Order by 8 PM EST, and this part ships TODAY!
365-Day Return Policy
Return any item for any reason within 365 days of placing your order. Find out more >
Total: $37.00
ADD TO CART
Cause 3
Drum Roller
One or more of the drum rollers might be worn out. Many dryers have two drum support rollers on the rear of the drum, and some dryers have two more rollers supporting the front of the drum. When the drum rollers are worn out, they can cause the dryer to make a loud rumbling noise. To determine if the rollers are worn out, inspect the rollers. If one or more of the rollers are severely worn, we recommend replacing all of the rollers at the same time as a preventative measure. (The roller shaft can often be reused if it is in good condition. Clean the shaft thoroughly before installing the new rollers.)
Parts
Drum Roller for your Dryer
Drum Roller - Part # 1925071 Mfg Part # W10314173
RepairClinic Item #1925071
Drum support roller. Tri Rings are not included.
$11.15
Quantity:
In Stock
http://www.repairclinic.com/RepairHelp/H...
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
3
crwdns2942205:01crwdne2942205:0
My washer maytag Brovos quiet series 300
Mvwb450wq1
Ser# co3170851
While it's running it sounds squeaky noise
An right after it spin it shows a UL an on the screen and it stop with out done ????
crwdns2934271:0crwdnd2934271:0 Shanise farrar crwdne2934271:0
