How to fix my phone it won't turn on
My phone don't won't to turn on an I had it on the charger an it still don't want to turn on i not knw what is wrong with it
Hi,
Do you get any response from the phone when you connect the charger that it is charging?
If you do get an indication that it is charging, see how to perform a hard reset below.
If you do not get a response from the phone that it is charging, try connecting it via a USB cable to a PC and see if you get a charging indication
If you do get a charging indication, allow it to charge for approximately an hour. Then try turning on the phone. If it turns on, it means that you have a faulty charger and it needs to be replaced.
If it still does not turn on you need to do a hard reset - see below.
If you do not get a response from the phone when it has been connected to either a charger or a PC, then you either have a faulty charging circuit in the phone or a faulty battery.
How to perform a hard reset on your phone.
This will restore your phone to factory default condition.
All your downloaded apps and user data will be erased. A hard reset is best done with a charged battery.
Follow these steps:
1. Make sure your phone is off and the charger is disconnected.
2. Press and hold Volume Down + Menu button + Power button (all three together) until you see the menu of Recovery mode. Then release the buttons.
3. Select option "wipe data/factory reset"
(using the Volume buttons to scroll and the Power button to confirm).
4. Now choose from the menu "Yes -- delete all user data".
5. After that press Power button to enter "reboot system now".
The phone is now resetting, be patient, it takes a few minutes.
I
my phone still wont come on
I tink it crash caz I recently download a game and suddenly my fone wont come on, pls advice me what to do
Hi @baichu
I assume you mean that you tried the 'hard reset' procedure as written above and it did not come on. Is this correct?
Do you get any indication on the phone when you try to charge the battery?
How long have you had the phone?
My blue life play 2 won't come on but when I press the power button the backlight flashes that's all! HELP PLZ!!!!
cant perform a reset if the thing won't come on....
If your Android device’s battery is almost dead, you’ll often see an “empty battery” indicator on the screen when you try to turn it on. But, if you let the battery completely die, your phone or tablet won’t respond at all when you press the Power button.
To fix this problem, just plug your Android phone or tablet into a wall charger and let it charge. You can’t just plug it in and try to turn it on immediately — you’ll need to give it a few minutes to charge first.
Plug it in and let it charge for fifteen minutes or so. Come back later and try to power it on with the Power button. If the problem was caused by a dead battery, it should boot up normally.
If it doesn’t work at all, try plugging the device in with a different cable and charger. The charger or cable could be broken and preventing an otherwise-good device from charging.
Thankyou
What about if it is power off and does not respond when I make it power on and it lights flashlight when I try to power on.
my android fierce one touch is not cutting on, i already pressed the power button plus the volume together and it still didn't work.
how do I get my phone to turn on It overheated when I was watching something and How do I get it to turn on plus It was on the same number charge on 100% Plz tell me how to get it to work
Best Thing You Can Possibly Do Is Go Onto Youtube, And Look Up How To Fix It If That Doesnt Work You Should Go To Where You Bought It And Get It Repaired. If That Doesnt Work, I Dont Know What To Tell You.
I still can't get my phone to come on
This is a Blu smart phone
crwdns2936753:030crwdne2936753:0 56
crwdns2942667:0crwdne2942667:0 163,472
crwdns2944067:029crwdne2944067:0
No it didn't work I hold it down for a long time an nothing came on
crwdns2934271:0crwdnd2934271:0 Brian Harris crwdne2934271:0
Hi,
Sorry my suggestions didn't work. Maybe you should check your warranty and if still valid contact the manufacturer or the retailer for a warranty repair.
crwdns2934271:0crwdnd2934271:0 jayeff crwdne2934271:0
try Going into safe mode or may be just reset the phone follow https://goo.gl/O5wQVL see if that helps you
crwdns2934271:0crwdnd2934271:0 debra mayes crwdne2934271:0
Can you help me please because is the same problem that I have
crwdns2934271:0crwdnd2934271:0 jmisaias crwdne2934271:0
Hi @jmisaias,
Did you try all the options given in the Chosen Solution below?
crwdns2934275:024crwdne2934275:0
