This is a stainless steel, 4 slice toaster oven. The model number is located on the bottom of the device. It has a single rack height and a removable crumb tray.
Toaster Oven won't turn on
Why doesn't my toaster work when I turn the knob on?
Make sure Timer is in 'Stay On' position otherwise oven will not come on!
This could be a number of things.
  • Inspect the cord for any cuts or exposed wires
    • If the cord is damaged it should be replaced before anything else
  • Make sure that it is plugged in and that the outlet it is being plugged into is working
    • It can be checked by plugging in something that you know works into the same outlet and turning it on
      • If the outlet is not working, then that is probably the reason the oven will not work
  • Damaged internal wiring (This is very unlikely unless the oven has been taken apart since it left the factory)
  • Worn out heating elements or timer.
    • Unfortunately these can not be replaced because they contain welded connections
How can you tell if the problem is the worn out elements, timer, or the heat controls?
Alejandro Martin crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 19,559
