Repair guides and support for your Apple Wireless Keyboard. Connect and command your Apple computer wirelessly.
Why "k" key doesn't function?
Hi, the "k" letter of my keyboard is dead, I tried connecting my keyboard to two different machines (Mac and Win) with the same results. I tried to take the key off and clean it, but nothing changed.
Any ideas??
Thanks
I have 3 original Apple wired keyboards all with a malfunctioning K key - typing anything with a "k" included needs visual check to ensure it appears... otherwise its repeated tapping to get a response.
Had the same problem with letter Y...if it' not a software issue like speech dictation or similar, or mechanical issue like spilled liquid try removing the cap of the letter than adjusting the rubber connector...than take a pointy object and try pushing the key and gently adjusting the rubber connector. It has worked for me
Here's the only solution I could find to a single malfunctioning key on that particular keyboard: http://www.omninerd.com/articles/Apple_C...
Thanks Mayer, I only press the k key, but nothing happen, upper o lower case is the same.
Thanks a lot
Thanks
That site appears to have been hijacked.
mvmarroquin crwdns2934231:0crwdne2934231:0
crwdns2959996:0crwdne2959996:0 19,053
