Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
3DS won't stay stay on - makes a popping sound
Hello,
Recently I changed my 3ds LCD screen.
But once I tried to turn it on, it made a popping sounds and turn itself off after a few secounds.
I read about lossen ribbons and stuff, so I tried to disconnect everything and turn the 3DS on just to see if the motherboard can light up.
The blue light turns on for a few secounds before shuts off.
Could it be a blown fuse? I saw once that with blowen fuse the nintendo won't turn on at all..
What could be the problem? I discconected EVERYTHING, even the mic, and still it won't stay on!
Thanks.
- Theres no SD card inside.
- Theres no game inside.
- tried putting the motherbord inside a fully functationing 3DS XL.
- It charges.
When it shuts off does one of the screens flicker for a split second? If the bottom screen flickers then there may be an issue with the top lcd. The 3d flex cable is usually the culprit. The ribbon may have a slight tear that is preventing the top lcd to power up which results in the blue light shutting off. To replace it requires a complete tear down of your system.
No flicker when I turn it on.
It absolutely will not power on if any of the ribbons are ripped or disconnected. Try reconnecting everything and look if the cables are ripped.
ChubbyKai crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 1,259
