The Ematic FunTab 2 is a 7" Quad-Core 8GB kid-friendly tablet. It comes pre-installed with a variety of educational games, a parental control dashboard, a front facing camera, a 2 megapixel back facing camera, and other productivity apps.
Why won't my tablet turn on?
I press the power button, but nothing happens. How do I remedy this?
Had my ematic10"tablet for almost a month now, and I'm not very satisfied with it!! I can't set the clock,and whenever I do it will not hold the correct time.
There's a lot of of problems with turning it on,and I have only two games on it, but it freeze frame before I can finish the game or it will be 10 mins or more before the game will load. I think I'm stuck with a piece of junk!!
I have bought this tablet and had it for one day for my 2yr old it turns on with the pbs logo but goes blank screen after that. We put it on the charger it didn’t even show that it was charging with the battery
my playtime pad won"t turn on without the charger
Hi @ Patricia Thomas,
You have two options.
a) Try a factory data reset and check if this resolves the problem.
Be aware that a factory data reset will erase all your data and downloaded apps. It will restore the tablet to its’ default factory condition (or last system updated condition)
Therefore it is important to backup the tablet before performing a factory data reset if you do not wish to lose all your data and downloaded apps.
Also ensure that the battery is fully charged before performing the reset.
Backup the tablet using the tablet’s backup my data feature.
Once the backup has been completed, reset the tablet using the tablet’s factory data reset feature.
Once the tablet has been reset, check that the tablet operates correctly.
If it still doesn’t operate correctly see option b) below
If it now operates correctly then using the backup you made earlier, restore the tablet using the tablet’s automatic restore feature.
Once the tablet has been restored, check that it is still operating correctly.
If it is then the reset has resolved the problem.
b) There is a 90 day/1 year limited manufacturer’s warranty on the tablet. You could make a claim for a manufacturer’s warranty repair or replacement.
Try holding down the power and power up button
Your battery may be damaged or no longer holding a charge. You will need to replace the battery in either case. Link: Ematic FunTab 2 Battery Replacement
The motherboard may also be in need of replacing due to some damaged connections or other various reasons. Here is a link to replacing the motherboard Ematic FunTab 2 Motherboard Replacement
crwdns2886500:0Ematic FunTab2 Batterycrwdne2886500:0
crwdns2930805:0crwdne2930805:0
crwdns2934079:0crwdne2934079:0
crwdns2937801:0crwdne2937801:0
1 hour
crwdns2886500:0Ematic FunTab2 Motherboardcrwdne2886500:0
1 hour
Amanda Wolosz crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 6,463
