This affordable large-screen Android phone sports a 5.7-inch display and large 3,400 mAh battery.
screen of zte zmax screen won't operate
My zte zmax had fell in water. I put it in rice for the water damage to be resolved. Everything works just fine on the phone except I cannot touch my screen for it to do anything. I don't have a lot of money to fix this. What do I need to do to fix this in a cheap way?
crwdns2889612:0crwdne2889612:0 46
crwdns2944067:021crwdne2944067:0
My ZTE ZMAX also was damaged by water. after the rice and even breaking the phone down(removing battery, screen, separating motherboard, ect.) then again trying the rice with phone separated the screen continued to light up but would not respond to touch. I then replaced screen plus digitizer and even then the phone's issue with the screen remains unchanged. I'm very upset as I like this phone and don't have money to replace phone. To continue to try n invest time n money in the phone is something I'm wondering will eventually end up equaling out to be the same as the cost of the phone itself?
My ZMAX has never had water damage, i treat my phone very well, but all of a sudden the screen wont respond in one spot. It wiggs out of nowhere, but when i lock the screen and unlock it it works okay for a minute, then does it again.
I just dont understand
Mine is doing the same
Mine is the same way . Did any find away to get there's working ?
I think I figured it out. Mine has been doing the same for the past 4 days. It was exposed to just a little bit of moister a week before it started happening. But I think it's just the phone getting old and having a flaw. Try getting you're zte really warm it takes a few min for the warmth to reach the inside but this is the only thing that resurrects my zte. It's only a short term but try it to salvage any important info you may have
crwdns2934275:016crwdne2934275:0
Whenever you're dealing with water damage it's always at best a 50/50 chance on getting the device fully restored to its previous condition. There's also a lot of misinformation out there about fixing devices that have been immersed in water. Your first mistake was to fall for the "Rice Trick" method. Your device has many layers in the design. From the back there's a protective casing/frame, cables, a battery, a logic board, camera, speakers, vibration motors, and more. Water is a liquid which is quite handy at getting into the tightest nooks and crannies. Throwing it in a bag or bowl of rice helps only in absorbing the water nearest to any openings on the device but it doesn't really touch or help evaporate the other liquid still within the various layers.
What you're dealing with could (and likely is IMO) related to a faulty display. After water damage I always recommend replacing the battery, charging port and display to begin with. One may reasonably need to replace other components too as they fail but these are usually the main components to start with. But screens can be expensive and you're trying to save on cost. What's going on is you likely have a faulty digitizer or digitizer connections. So let's go the cheap method of troubleshooting. Disassemble the device and take out the logic board. Purchase some Isopropyl Alcohol of at least 91% purity (should be about $3 from Rite-Aid/CVS/Walgreens) and then a soft bristled toothbrush ($.99). Take the alcohol and pour it into a washable clean container and submerge your logic board within the solution for about 30-60 minutes. Longer is better in my experience. Take out the board and use the brush to gently clean all the connections then, once fully dry, reassemble the device and test your screen. If it's functional that may have fixed the problem. If not, your next method of troubleshooting is with a new screen.
*iFixit allows you to purchase a part you may need to fix the repair and, within 30 days, return the part for a refund if it turns out the part doesn't fix the problem you're experiencing.
crwdns2889612:0crwdne2889612:0 9
I read similar instructions on other boards, some of which didn't specify that you are only to be dunking/bathing the LOGIC BOARD in the alcohol-- NOT the entire phone (except for the battery, back cover and sim card).I think you can submerge the entire phone, but if you do, it must be quick, only a few seconds, because otherwise alcohol can seep INTO the screen itself, creating bubbles which will discolor things. I did this, and I can also say the touch screen still does not work, so it solved nothing.
I think in my case, even if I only cleaned the logic board, it still wasn't going to solve the problem, because when my phone first got wet/hit the water, it was ON at the time, and it stayed on (it was playing a radio stream), actually -it actually wouldn't let me turn it off, so I spent too much time fooling with the power button, when what I should have been doing was IMMEDIATELY remove the battery, turning it off. THEN into the rice. Had I done that, I might've been able to save w/ alcohol...
I dropped my qlink zte in a cup of coffee it comes on, but when I press to hold to turn it on it dont do anything
Any suggestions
My ZTE Touch Screen stopped Working. My phones battery died and I replaced the battery as it would not turn back on. Once I replaced the battery and turned it back on everything looked fine but the touch screen would not respond. How do I fix this? No cracks or damage.
Old the power button down for 15- 20 seconds. I tried absutely everything when my zmax screen would not come on. I. Thought. It wasn't holding a charge etc.... Someone suggested that I hold the power button down for 15 seconds sand at about 13, viola!I. Had too do it a couple more time over the next couple of days and now it worries fine. .Gluchktood q
All of you who have water damage sorry but u need to do what the guy said and dip it in 93% rubbing alcohol,and it wouldn't hurt to get some dust off(canned compressed air) and blow out whatever you can get to then reassemble, if that doesn't work then you're stuck getting a new digitizer
Alcohol works really well just dont strip the screws and use a guitar pick to pry phone open very carefully remember or mark screws where u removed them.
Hey ... My mobile(ZTE ZMAX) did not fell down in the water but center and soft keys is not working .. What should I do .. Please help
I just dropped my phone with the case and screen saver in a bucket of bleach and dishwashing liquid ...took it out immediately but the phone was on when ig fell in the water i took the screen saver off and the case but the battery is not a removable battery but i do have it in a bag of white rice and i also tried to vacuum as much of the water out and removed the screen saver cause i saw water on the screen up under the saver ...ugh what are my changes of saving this phone..i did pay to get the screen fixed and the charger port as well..o. I hope im doing the right steps and acted in enough time but ....after i picked it up the screen was flashing and now it wont turn on....any tips of is it a lost cause?
hfelicia88 crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 68,314
