Why won't my laptop charge properly?
I charge my laptop for hours and it shows that the battery is drained or isn't charging.
Vanessa,
First, make sure the charger is completely plugged in. If it is, it may the outlet that isn't receiving power. You can test that by plugging something else into it.
If that still isn't working, you may have to replace the battery. The same thing happened to my computer. Replacing the battery fixed the issue.
I hope this helps!
I just replaced my battery. It worked well for nearly a month but now I'm having the same problem. It's plugged in but the battery is not accepting the charge.
I have the same problem. I just use my laptop 9 months. but now it's dont want charging (just keep 0%) and the battery indicator flashes. Do replace a new battery can be more durable ? Then how the technic of using the batteries so it's can be durable?
My ASUS R510C Notebook PC does not power up if I disconnect it from my household electrical receptacle. Do I need a new battery
crwdns2942667:0crwdne2942667:0 2,142
