The BLU Life 8 is a smartphone based on Android 4.2. It is equipped with a 5" display with 720 x 1280 pixels resolution.
Why won't it charge?
My blue life 8 won't charge. The charging port looks fine. When I plug it in the charger . it will grab charge for 1 second. And then won't charge at all.
crwdns2889612:0crwdne2889612:0 15
Do you have a secondary charger/ cable you can try? it may look fine but the pins wear over time.
crwdns2933315:08crwdne2933315:0
The charging port tends to come unattached from the phone and needs to be fixed also my new phone the tips that you plug in some are smaller size so when you plug it in it won't charge but some have a tight fit which it means its a bet bigger and it fixed the problem you need to find the right charger even though there all the same type the may look the same but some are a tiny bit bigger which makes the perfect fit because the charging port tends to move around while charging it.
Sorry if I made any spelling mistakes.
-Ace
Do you know where i can fix my phone Ace?
We offer mail in repairs. www.gadgetifix.com
you may have a bad battery or you ned to replace the charging port
i have had mine for less than a month and having the same issue
yea I think something is not done correctly with that model. mine stopped charging after a month and my husband's stopped working . I just got a different phone.
There are a few things that it could be. As others have said, it could be the battery, charge port, or cable. On mine, however, it was the charge circuit on the motherboard. Mine was refurbished, so it didn't have a warranty. So I opened it up and saw that the solder work was supremely sub par. There were about 3 or 4 diodes that were far enough away from the solder pad, that they eventually lost connection. It could have been from the board flexing or from heat. Either way, I added a big solder blob to anything that wasn't perfectly centered and it worked again. I am actually thinking about trading mine in for something else.
I've had two Blu Life 8's. The first one had this issue (though mine was new), so I used the warranty to get another. It took them 3 months to send the second one and now it also has this issue. I for one, will not be buying another Blu product.
me either sent mine back twice keps charge for the first day i get and doesnt charge afterwards
I've had my phone for over a week now....everything was fine until it went completely dead..…now its not coming on at all
Bad connection to the battery or the circuit bored is broken or the screen is broken or you just bought a cappy phone
I had one that I had to return after only 3 weeks. It went dead and would not take a charge. Now the 2nd one I have is not charging completely and loses it's charge fast when taken off the charger. This happens whether I'm using the phone or not. On youtube I found a video that said to try cleaning the port. I'm in the process of trying to carefully do this. Actually it feels like the port may somehow have become loose. I think it has a few problems going on with the port as well as the battery.
It's the battery and or its just a crappy phone
My blue life x8 wont charge,even if the technician replace the charging pin a new one..but still wont charge.please help my problem..thank you.
Replace the circuit bored not just the charging pin
And or the battery
same thing heppened to me, the "flex" does not make sufficient contact with the charging port, you should put a small piece of cardboard underneath to press it
https://www.youtube.com/watch?v=nDKbUGZ-...
Yeah but but card boRd can catch on fire not the best place to be shoving cardboard in it evan though it may work.
karen crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 7,474
