Dell Inspiron 1525 laptop won't charge the battery
I just bought a brand new battery for this laptop, it came with 53% battery life and because it has been plugged in it hasn't dropped a percentage but will not charge. it says in the battery info that it's plugged in but not charging
does anybody know why?
Under "Battery Info" it states "AC Adapter = Unknown device installed"
I have just done a fresh install to Windows Vista after it was downgraded to XP and the recovery partition was not available so I had to reinstall the drivers, there's some displayed as unknown (Base System Device?), could that be a problem? before when it was on XP (with the old battery) if you took the charger out it would just instantly turn off
crwdns2933315:07crwdne2933315:0
Your AC adapter is bad, though it can still supply power to your Laptop in a limited mode but the charging controller does not see it as a approved adapter, hence disables charging. Dell AC adapters have ID built in them, a failing chip inside the adapter or the broken wire(center pin) usually is the cause. Just buy an after market compatible one online, they work and are cheap.
Please remember to post back the results.
Had this problem & realized (from this post) that someone had switched my AC adapter with one for a different computer... which happened to work in the sense that it provided power to the computer... BUT it didn't charge the brand new battery. Found the proper adapter and the battery is now charging perfectly. yaaayyy thanks!
I have also the problem that the battery won't charge.
I have already replaced the battery, the adapter and even the power board. It didn't help.
The computer runs well with the power cord. I had XP, VistA and windows 7 installed. It makes no difference.
I don't know what to try next.
Update (05/20/2017)
Well, today I gave it another try.
I tried one more adapter today. I wasn´t expecting much, as I had already bought an aftermarket adapter and an original used adapter before, which both didn´t work.
This adapter though does work. I deliberately chose an adapter with an higher output. This adapter has 90W instead of 65W output. I am not totally sure, that this makes the difference. But after all it works! :-))
Press the F12 key when booting up, you will get a menu that will let you check the BIOS or run diagnostics. In BIOS the ac adapter and battery are at the top of the list. If the ac adapter shows as 1 watt or unknown then the problem is either the ac adapter or the mother board. If the battery does not show up then it is likely a bad battery. Run diagnostics to test the components, if the battery is bad it will show up as weak in diagnostics. Diagnostics will test the fans, CPU and memory.
Here are few things to try:
1. Check if the battery works in another laptop.
2. Clean the battery contacts if you’re comfortable with it. Also check if it’s damaged or bent.
3. Try another battery. If this battery works, then you know for sure that the other battery is faulty. If the system is under warranty you can get battery replacement from Sony
4. Seems like flashing BIOS has helped a great deal of people facing similar problem.
Please fully charge (24 hours) and discharge for several times to see how long the battery working time is. hope can help you,thanks
More:http://goo.gl/LJDmLA
Laptop dell inspiron 1525. Battery does not charge. It shows 75% charged but when i remove the charger, laptop closes immediately. Windows 7 ultimate original are installed. Latest bios are installed. There are no updates to be done. My charger is new original from dell. Any idea what sould i do or what should i replace on the laptop?
Hi I’m having the same problem. Did you find a fix for it yet? I’m hoping it’s not the motherboard.
1. Check the charger .
2. check the battery .
3. Tray the battery in another laptop ...
Hi Oumar,
the battery is normally charged in the laptop, not with a separate charger. How would I check the charger of the laptop?
The battery is new and ok.
After many attempts at solutions, the only way I found to resolve this was to remove the power cable and then plug it back in with as much force as humanly possible. I mean really, really press it in hard. The status then changes to "plugged in, charging".
Use this : Dell AC Adapter LA90PM130
Update (10/31/2020)
The problem comes from power adapter. Replace power DC won't fix no charging battery issue.
I recommend to buy this one :
Dell Slim Power Adapter - 90-Watt
Model No : LA90PM130
https://www.dell.com/en-us/shop/dell-sli...
You can find a cheaper one on Ebay
Gizmo crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 37
crwdns2942667:0crwdne2942667:0 13,022
