The Honeywell Cool and Refresh Mini Tower Fan is a two-speed fan paired with a Febreze scent cartridge that cools the air and helps eliminate bad odors.
The fan blades won't spin--how to fix?
I can hear the motor whirring inside when I first turn it on but it takes awhile for the fan blades to actually start spinning. How can I fix this?
The fan blades could be damaged. You can replace the blades, or see if there is anything blocking their movement. There could also be a problem with the motor as a whole. Use this guide to check the fan blades and replace the motor.
Armando Jacob Espinoza crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 12,858
