With some testing, it is definitely safe for the charger if you are charging a macbook that needs more wattage.. The charger will never provide more than the rated wattage, and as such, there is no higher risk of failure.
On the other hand, if you use a 45w on your MacBook Pro, which requires an 85w charger while you are playing a game or editing video (using 100% CPU and/or GPU), your battery will still drain but at a must slower rate. I have read that if you let it reach zero, it'll keep on going and kill your battery as the voltage will go too low.
I personally use a 60w charger with my MacBook Pro Retina which comes with an 85w charger. It charges a tad bit slower but it's perfectly fine. Here are the screenshots:
In this image, I am using my 60w charger while low use (medium brightness, no CPU intensive tasks) but it is charging. It is only pulling 56.04 watts, well within the limits of the 60w charger.
Here, I experimented with a 45w charger while I am stress testing with geekbench and full brightness, as you can see the charger is pushing out 40w, again, well within the limits. On the other hand, it is now draining the battery (but at a slower rate)
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
9
well i have an old MBP needing 85W that will NOT work with 60W
i dont think that as mine is not backward compatible that the same mba - mac book air - of the same era would also not be compatable - it may work here n there temporarily but then damage the internal(s) of the machine as its designed to take less w-age - less wattage - NOT more or not 25W more then normal, however the only realy way to know is ... suck it and see some mac are different to other - i would not suck it an see id get a 60W as you dont want find it kills your mac if you try it its at your own risk.
crwdns2934271:0crwdnd2934271:0 robertgludlow crwdne2934271:0
So long as the connector is compatible with your MacBook Air you shouldn't have any issues as the computer will not draw more than the wattage required to charge it. The standard draw of the MacBook air is a max of 45Watts and that draw only occurrs when the computers battery is very low and you are running several applications while the computer is recharging the battery,
crwdns2934271:0crwdnd2934271:0 sm1kelly1 crwdne2934271:0
