Why can't my computer connect to the internet?
I try to connect to Wi-Fi in Windows. It takes a while, and then fails to connect.
Open the Network troubleshooter by right-clicking the network icon in the notification area, and then clicking Troubleshoot problems.
2. Make sure that all cables are connected (for example, make sure your modem is connected to a working phone jack or cable connection, either directly or through a router).
3. Restart your modem, and then restart your router. Remove the power cable from the modem and router. After all lights on the device have gone out, wait at least 10 seconds, and then plug the modem and router back in. Some modems have a battery backup that prevents the lights from going out. For this type of modem, press and quickly release the Reset button. If you don’t see a Reset button, remove the battery instead.
4. connect computer with internet and try to go online
I always recommend isolating the problem as quickly as possible.
First figure out if the modem and router are working properly. Connect with any other device to the internet to check this.
If other devices can connect than this is an issue with your computer, in which case the guide Matthew suggested is perfect.
Its is likely a software issue that is easy to fix; however, it could also be a hardware issue. For help fixing this, starting with software and moving to hardware, please take a look at this guide
update the wireless driver and try to use the internet if it doesn't work than restore the computer and try to connect laptop with internet .i hope this will help
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 12,527
check the lan driver and wireless driver and update them and make sure no software is blocking the internet connection . remove the checkmark in power managment in wireless driver . for more visit http://goo.gl/mxCXiL and see if that works for you
crwdns2934271:0crwdnd2934271:0 riteshsingh207 crwdne2934271:0
