Read the spark plug first to try to see what has been going on. A plug in normal condition has a thin layer of light-brown deposits on it. If you see a thick layer of black carbon deposits, it's a sign that the carburetor mixture is too rich -- your engine may even be smoking. Electrodes that have been worn thin are a sign of overheating, often caused by too much ethanol in the gas. If your plug has wet, oily deposits, it's time to take the mower in for servicing, because oil is leaking into the combustion chamber where it shouldn't be.
Other Engine Problems
If your spark plug appears to have normal wear -- or if you've just installed a new one -- and the engine doesn't fire, you can check the plug by replacing the spark plug wire with a tester and pulling the starting rope. If you don't see a spark on the tester, there may be a problem with the ignition coil of the flywheel to which it's attached. The ignition coil doesn't frequently develop problems, but the connection between the flywheel and coil or between the starting pulley and flywheel can wear out, and the coil may not be turning. Replacing the worn part isn't difficult, but you may need a pro to properly disassemble the engine.
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
5
crwdns2944067:09crwdne2944067:0
See if you can get the service manual from http://www.kohlerengines.com/manuals/lan... here. The model number you posted does not yield any return.
crwdns2934271:0crwdnd2934271:0 oldturkey03 crwdne2934271:0
Thank you for the response. I'm like you, I can't find the manual for this model on that site.
Do you know if I can replace the ignitor module with a standard one, and do away with the digital module? Do you know of any way to test the digital module or if I can bypass this somehow? It seems that everywhere I look, I run into road blocks and find no information for this motor, except for the Craftsman site (which is no help).
crwdns2934271:0crwdnd2934271:0 Jeff crwdne2934271:0
hello my kohler engine start when it going on load one coil dont work.and it not bare load.i have change 3 coil but problem is same after 15 mint one coil dont work
crwdns2934271:0crwdnd2934271:0 saba crwdne2934271:0
Have had the same problem and have ordered a new coil will let you know if this solves the problem.
crwdns2934271:0crwdnd2934271:0 Ray crwdne2934271:0
Look under kholar command for parts they put our kholar pro cv16s under those
Cv16s is in with the command model's of kholar
Any part you need you'll find under kholar command that's what pops up for me it's like they don't have kholar pro cv16s replacement parts.
Leave it with me an I'll get it running in four hours or less.
crwdns2934271:0crwdnd2934271:0 Michael Bland crwdne2934271:0
crwdns2934275:04crwdne2934275:0
