Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
crwdns2934055:0crwdne2934055:0
Replace battery & Charger Port. Phone wont power on after it dies!
Hey, I am fixing a phone for a client. When I got it the phone would not power on. So I replace the battery.
The powered on fine. So I replaced the charger port as well. The phone powered on and charged fine. I thought it was fixed.
So the next day the phone died. So I went to charge it up. NOW THE PHONE WONT EVEN POWER ON AGAIN! I am stumped. Do you guys have any suggestions as to what the problem could be.
A new program that started about 10 days ago: Check your serial number here to see if it qualifies for the Battery Replacement Program:
https://ssl.apple.com/support/iphone5-ba...
Could be the battery thats faulty or the charge port
I replaced the battery and the charger point. It was working until the battery died. Now the phone wont even power when I put it in on the charger. So Now I am back at square one.
Same issue here. Phone came in dead. Put in a new battery and it charges fine. However if you let the battery die it will no longer charge. Tried several known good batteries and charger ports. I read that there is a component called the U2 IC. It is a 36 pin chip. When this fails you will get the symptoms we are experiencing. Looks like a pretty advanced repair. Hoping someone else has run across an easier solution.
affter replace charging port
phone dead
what go wrong
ant advice
what go wrong
any advice
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 649
