The Black N Decker Toast R Oven TRO200 is a 4 slice under counter toaster oven with bake and toasting capabilities.
on/off button for toaster doesn't stay on
The on/off button for the my under the cabinet B&D toaster oven will not stay on. The oven part of the unit works fine. I see that the button can be replaced, but where do I get a replacement button?
I couldn't find a replacement oem button for the toaster, you can go to radioshack and pick up a toggle switch and try that or buy a new toaster. Sorry
I have the same unit, I carefully, with a pair of pliers, adjusted the magnet so it aligned better with the switch mechanism.
It has been ok for me.
Where is magnet and how did you access it? Do I have to remove cover?
Magnet is same side as button and should stick to a little transformer ( 2 red wires from bread board). Just take the right side off and adjust the plate connected to button so it is flush when pushed in.
Linda Landrigan crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,925
