Perhaps it is a vacuum leak? Vacuum leaks will cause the car to sound like it is going to stall or bog down a bit when idling. Vacuum leaks may also cause the car to idle higher due to the car having to work harder to force air through the motor.
Does your car start better in certain weather?
I would inspect any plastic pipes going into the motor as those are going to have to do with induction. PCV valves are a common culprit for issues like these.
Good luck
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
0
crwdns2944067:06crwdne2944067:0
What happens when it won't start? Does it turn over but does not fire?How do you know that the parts you listed or okay?
crwdns2934271:0crwdnd2934271:0 oldturkey03 crwdne2934271:0
a friend tested them. there's a possibility it could be my connectors to the battery so i got a new pair.
crwdns2934271:0crwdnd2934271:0 Marlene crwdne2934271:0
my car has no spark it turns over but wont catch its not my battery, alternator, spark plugs, or starter. My pcv valves. I had a friend that has some experience in american cars.
well it looks like my fuel filter needs to be replaced and i do not have the special tools you need, great
It was my ecu
