Num Keys 1~9 not working
My Macbook Pro late 2010 suddenly stopped working Num keys 1~9, however num key 0 works. I already tried setting RAM but doesn't work. Please help
Here's the IFIXIT guide for the MacBook Pro 13" Mid '11 model Upper case replacement.
Sorry to say the keyboard is part of this assembly. While some people have managed to get from China directly just the keyboard sub-assembly it is a bear to replace as you'll need to remove about 50 screws or snap rivets.
Did you spill something into the keyboard?
Dear sir thank you very much for your kind answer. My macbook model is 13" late 2011. i didn't spill anything in the key board. The Num keys stopped working at the first time but after restart it use to work then again stopped for the couple of the times. But now it is permanently stopped working.
Sorry to say I think the keyboard is damaged here. While you might be able to get the keyboard alone directly from China it's a lot of work to replace as you have about 50 screws and/or pop rivets to remove. It's just easier replacing the full upper case.
As a last ditch effort, I would recommend reinstalling the OS before replacing any hardware. Please back up your information before reinstalling the OS. The fact that it worked sometimes makes me think it might be a software issue.
Dear Sir
at last i changed the key board now my macbook works fine with num keys.
Happy to here your number keys are working again! Did you swap out the top case or were you able to get a replacement keyboard and just replace it?
First hook up an external keyboard and see if the number keys work on it to eliminate a software issue. If the keys work on the external, your keyboard sounds like it has shorted out and you will need an uppercase replacement.
Thank you for your answer, the external key board works fine. Can you pls tell me in detail what is uppercase replacement?
Dan,
My numbers from one to nine do not work and my Fn-1 to Fn-9 keys as well.
What should I do ?
Best to create your own question here with all of your systems details as well as what happened. Sadly, it may require replacing a part or two.
Hi Suresh, where did you buy the keyboard and cost?
Did you buy the entire keyboard?
Thanks
crwdns2942667:0crwdne2942667:0 66,135
crwdns2944067:04crwdne2944067:0
how to make the numbers 1-9 to work
crwdns2934271:0crwdnd2934271:0 hassan albuainain crwdne2934271:0
@ hassan albuainain - Please explain and its best to create your own question with your systems details then tagging on to this one.
crwdns2934271:0crwdnd2934271:0 Dan crwdne2934271:0
I have problem too my number keys not working fom 1 to 9 i dont know what happen please help me
crwdns2934271:0crwdnd2934271:0 Mj Vallejo crwdne2934271:0
@Mj Vallejo Its a faulty keyboard, it means you need to replace the entire top of the case, I recommend taking it to a shop where they can do it for you. I still haven't fixed mine because I don't have the money to fix it, its around$250 for the top case and up to $200 for labor costs so you're looking at around a $450 repair. Another solution is to plug in a normal USB keyboard but that wont fix the damaged keyboard.
crwdns2934271:0crwdnd2934271:0 Jeremiah Hamman crwdne2934271:0
