MacBook Pro Late 2011 won't power on
While connecting a LogiLink Solar Charger (http://logilink.com/showproduct/PA0055.h...) to my MacBook Pro via USB it went off immediately and shows no sign of life since.
The Magsafe light is neither green nor amber nor dim: it's off; the very same Magsafe unit however works flawlessly on another MacBook Pro, including the green/amber light.
When the battery indicator button is pressed, not a single led goes on, despite the battery was on 100% when the incident happened.
Needless to say, the MacBook does not power on. Simply put, it does totally nothing.
Could a fuse be blown or should I assume that the whole thing is toast? Any help is appreciated.
In case your interested, the case is now solved.
I disconnected the battery and then connected the Magsafe unit: the MBP powered on and started the boot sequence. Disconnected the Magsafe, re-connected the battery and then re-connected the Magsafe: the MBP powered on again.
The battery indicator shows that the battery is completely discharged, but now it is charging again. I guess the incident did nothing good to it, but at least the MBP is up and running.
Exact same thing happened to me and this fix worked. I did not need to boot it off of the Magsafe. Just disconnecting the battery connector, letting it sit for a few seconds, and then snapping it back on was all that was needed.
Peter N crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 597
