Check out these guides for information on repairing and dissembling your sewing machine.
crwdns2934591:092crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Why does the electronic beeper beep and the sewing machine won't sew?
I have a Singer 7462 Electronic sewing machine. When the foot pedal is depressed the electronic beeper beeps and lights flash but the sewing machine doesn't sew- I tried suggestions from Singer site but it didn't solve the problem. No sewing Machine repair in this area.
I have a electric brothers sewing machine and the E6 lights flashing look it says a thread may be tangled ,but don’t see any.what else could be wrong?????help
Pls I have a singer confidence quilter . The light comes up when I turned it on but it doesn't engage to start sewing rather it beeps and alarm and then stops but the lights keeps blinking what do I do ?
crwdns2933315:09crwdne2933315:0
The Singer Athena will do this when the bobbin is threaded backwards... Sometimes it will sew for a few stitches - bunch the threads and then stop. Once that happens it will simply beep and not operate.
Troubleshooting on bunching (a separate subject) can be done by loading distinctly different colored threads top and bobbin (bottom) and see which color thread is bunching.
I know this sounds almost as stupid an answer as "is your machine plugged in and turned on", but truly it's easier to mislead the bobbin than one thinks.
Hope this was helpful.
actually your problem is your bobbin winder!!!! flip it back to theright position if its flipped with no bobbin it shuts down
Thank you so much Crystalleecase!!, I just tried this on my 4+ years idle machine that though was broken and it worked. ☺️☺️☺️☺️
{Slaps forehead}. Thank You crystalleecase . I never would have thought of that. I wish this was posted as an answer rather than a comment so we could Vote for it! (7462)
Hi
I think there is something jammed in your sewing machine: motor belt, bobbine,gears. etc. Try desconnect it from main and clean it. Then try to rotate it forwards and backwards looking for the part that is stuck. Some times the nylon gears breaks and get the machine out of order and stuck.
I hope this hints may help you,
Sully
My singer 7422 turns on I can hit reverse button and it works but does nothing when pressing pedal anyone know y
crwdns2942205:01crwdne2942205:0:
Have you tried making sure the pedal is fully connected with both prongs?
If so, have you troubleshot the pedal itself? Perhaps a wire could be broken. I'd do this by disconnecting the pedal completely and seeing if the machine will sew when you press the manual start and stop sewing button to to sew forward.
On the plug in part that plugs into the machine, from the foot pedal, around the metal rod, is a tiny lip of black plastic. This needs to be cut off around the metal rod that inserts into the machine. The little thickness of the plastic, about 1/16 of an inch, is preventing the metal rod from the foot pedal from making proper contact by not allowing it to go far enough into the plugin hole. Take a small knife or razor blade and cut that little piece off. I just got lucky figuring it out. Happy Sewing---Jesse 12-31-2016
I would remove the bobbin area pull out any lint and reapply. Typically it thinks it feels a string. If not, replace foot pedal
Just solved my problem of whirling noises and machine not working.
It was where I had wound a bobbin on the top, but the bobbin shaft had not been clicked over correctly , so the bottom of the machine was still switched off..
Simple, but very frustrating, hope this helps someone.
Check this out before doing anything else if you hear that noise!
You may have pressed the “Reverse Operation Button”, or “Reverse Stitch Switch”. I found on my machine that in Reverse mode, the machine does one stitch and stops with flashing lights.
Solution : Press the Button (it is near the sewing needle, and has a U and arrow sign - it is beside the U and 3 sign)) to set machine into normal mode.
My C240 was doing something similar, just beeping, not picking up a stitch, the needle wasnt coming down. Apparently I twisted/ broke the cord for the foot pedal. When I disconnected the wire, and used the button on the machine to sew, it worked. Will have to get a new pedal if I want to use that method.
About a ten year old Brother Computer CS 6000i. Saw a hole and oiled it. Even oiled into small space around wheel. Cleaned bobbin area really good. Now it simply won’t sew. The bell goes off and the needle won’t sew. It just vibrates and the threads get tangled where bobbin is. Is there hope?
Susan crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 63
crwdns2936753:030crwdne2936753:0 243
crwdns2942667:0crwdne2942667:0 39,076
