Ok, i decided to try the reflow procedure, since it was working for many other users who have tried it! So i covered the MBPro in a blanket and turned it on for 40min, it got quite hot! Then i shut it down and restarted it, it booted fine without any issues and worked as if it was brand new! Just to make sure i restarted it a couple of times, all seemed it was ok! Of course im not expecting this to last for ever, but in case it doesn't work again, il go straight in replacing the logic board!
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
0
crwdns2944067:07crwdne2944067:0
zoran, based on your serial number, these are your sepcs:"2.4 GHz Core 2 Duo (T8300)
Intro Date: February 26, 2008 Disc Date: October 14, 2008
Order No: MB133LL/A Model No: A1260 (EMC 2198)
Subfamily: Early 2008 Model ID: MacBookPro4,1
Std RAM: 2 GB Std VRAM: 256 MB
Std Storage: 200 GB (5400 RPM) Std Optical: 8X DL "SuperDrive"
crwdns2934271:0crwdnd2934271:0 oldturkey03 crwdne2934271:0
just to verify, are these the symptoms you have:"(no sleep light, no fan movement, no hard drive spin-up, no Caps Lock LED illumination when pressed, and no display illumination?
Sleep light is constantly on, fan is moving, no hard drive spin-up, no caps lock led illumination when pressed and there is no display illumination!
crwdns2934271:0crwdnd2934271:0 genik crwdne2934271:0
I got a cable (dvi to hdmi) to check the display on an lcd tv. Just to be safe,i first plugged it in an older laptop of mine (powerbook g4), just to be certain on what will i be expecting to see! But now i think i got more mixed up cause i can only see the PowerBooks desktop wall paper... is that right?
Guys, forget about the issue with the older laptop, it was just a matter of screen arrangement. I connected the dvi2hdmi cable to the MBPro model and there was nothing to display on the lcd tv. So what is the verdict now?
crwdns2934275:02crwdne2934275:0
