Why won't player turn on?
I have tried over and over again to turn my player on. I have tried charging it several times and have even tried the reset button, but it will not come on. It was working fine, then I started downloading some more music when it shut off and would not turn back on. My laptop recognizes that it is pluged up. I only have a USB cable to charge it and I have even tried three different USB ports on my laptop. What is the cause and fix for this problem?
henryr79, it does sound like a battery failure. If it has discharged to below its threshold it will no longer accept a charge or hold a charge. I would start with that. Follow this teardown to change your battery and re-evaluate. hope this helps, good luck.
What does a battery cost and where can one be bought?
Once you have it apart, there should be a number on the battery. Use that to do a search according to your location.
It was not working and how to fix it.
Um... what are you talking about???
My sony walkman wont turn on
henryr79 crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 2,991
