Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
crwdns2934591:01203crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Can I install a 2009 logicboard into a 2008 MacBook model?
I have a Penryn white plastic macbook. I was wondering, if I need to install a new logic board, are the latest 2009 macbook logic boards compatible?
I see it has a sata connection for internal optical drive, so that's a "problem". But other than that, would it fit?
crwdns2889612:0crwdne2889612:0 -1
The logic board from this machine would be as high as you can go:
Apple MacBook "Core 2 Duo" 2.13 13" (White-09) Specs
Identifiers: Mid-2009 - MC240LL/A - MacBook5,2 - A1181 - 2330
crwdns2942205:01crwdne2942205:0:
Yes, I found that indeed. However, an answer on another similar question shows that you'll also need a new bottom case, because the 2009 model has different screw positions. So, I guess I won't attempt. (Swap late 2008 Black MacBook logic board to Mid 2009 logic board?)
Peterdk crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 278
