Why doesn't my silence button work anymore?
When flipping the switch to silent, the "silent" and "non-silent" icons flash on the screen at random times. The phone will only stay silent for a few minutes or less at a time although it is set on silent. How would one fix this? The phone has not been damaged or exposed to moisture. It just started one day.
crwdns2944067:05crwdne2944067:0
I noticed you never got an answer to this. Are you still having this problem?
crwdns2934271:0crwdnd2934271:0 originalmachead crwdne2934271:0
Thank you. Yes, I think the connection is loose, but I am too scared to open it up and take it apart. I've gotten used to it and just use headphones when needing to silence it. Still, I would be happy to hear some suggestions if any.
crwdns2934271:0crwdnd2934271:0 redacted crwdne2934271:0
== This is ==
a DIY site - if you're not comfortable doing it yourself print out the guide and take it to an electronics repair shop that will do it for you.
If this answer was helpful please remember to mark it accepted.
Good Luck,
N
I took it apart following the Vibrate/Ring Switch guide. Everything seemed to be connected properly, so I jiggled some pieces around and put it back together. The silence worked for the first hour, then after changing it back to ring it reverted back to the original issue (flash the silence ring back-and-forth and vibrate if vibrate is on). Not sure what needs to be replaced.
My mute button will not let my calls come in
crwdns2934271:0crwdnd2934271:0 rosieannwallace crwdne2934271:0
