First generation, based on the Ford C1 global platform.
Mazda 3 Check Engine Light P0126 & P0128
The two codes from the check engine light are: P0126 & P0128
Here is what I found according to my research:
P0126 is either replace coolant temperature sensor or replace the thermostat. According to my research, 99% of the people who had this code needed to replace the thermostat. Once that was replaced, 99% of the people said that the light turned off and that they noticed the car ran better than it did before. Some people said that the repair is about $100 (including the parts and labor) and that no one should pay over $200. People said that they were even able to replace it themselves (if you can get under the car). The thermostat part is LF7015170. I looked it up online from a Mazda parts dealer and it's about $45-$50 depending on which parts dealer you buy it from. I'm sure I could even find it on eBay for cheap too.
P0128 indicates that the computer is detecting that the engine is not reaching operating temperature within a reasonable time after startup. I am guessing that this relates to the issue with the thermostat, but I'm not 100% sure.
CAN ANYONE GIVE ME MORE ADVICE/INFORMATION AS TO WHAT I SHOULD DO? HOW MUCH IT WILL COST?
thanks for this one. Gonna do the work myself
Ingrid, take a look at this information from the service manual. The actual installation is not a horribly complicated job and definitely doable:
DTC P0126 DTC P0128
Coolant thermostat stuck open
DETECTION CONDITION
DTC P0126
• If the ECT signal never exceeds 71°C {160 OF} after engine start for specified period, PCM determines that the coolant thermostat is stuck open.
MONITORING CONDITIONS -IAT: above -10°C {14 OF} -Vehicle speed: over 6.0 km/h {3.7 mph} DTC P0128 • The PCM monitors MAF, IAT, VSS and EAT signals and calculate radiator's heat radiation ratio while following monitoring conditions are met. If calculated value exceeds threshold, PCM determines that the coolant thermostat is stuck open.
MONITORING CONDITIONS -IAT: above -10°C {14 OF} -ECT at engine start: Below 36°C {97 OF} -Difference between ECT at engine start and minimum IAT: Below 6 °C {10.8 OF} -Vehicle speed: over 30 km/h {18.6 mph} Diagnostic support note
• This is an intermittent monitor (Engine cooling system).
• The MIL illuminates if PCM detects above malfunction condition in two consecutive drive cycles or in one drive cycle while DTC for the same malfunction has been stored in PCM.
• PENDING CODE is available if PCM detects the above malfunction condition during first drive cycle.
• FREEZE FRAME DATA is available.
• DTC is stored in PCM memory.
• DIAGNOSTIC MONITORING TEST RESULT is available.
POSSIBLE CAUSE
• ECT sensor malfunction
• Cooling system malfunction
• Coolant thermostat malfunction
• PCM malfunction
THERMOSTAT REMOVAL/INSTALLATION [ZJ, Z6]
Warning
• Remove and install all parts when the engine is cold, otherwise they can cause severe burns or serious injury.
1. Remove the battery cover. (See BATTERY REMOVAL/INSTALLATION [ZJ, Z6].)
2. Disconnect the negative battery cable.
3. Remove the under cover.
4. Drain the engine coolant. (See ENGINE COOLANT REPLACEMENT.)
5. Disconnect the lower radiator hose from the thermostat.
6. Remove in the order indicated in the table.
7. Install in the reverse order of removal.
8. Add engine coolant. (See ENGINE COOLANT REPLACEMENT.)
9. Inspect the system for engine coolant leakage. (See ENGINE COOLANT LEAKAGE INSPECTION.)
Thermostat Installation Note
1. Install the thermostat into the thermostat case with the jiggle pin at the top.
THERMOSTAT REMOVAL/INSTALLATION [LF]
Warning
1. Remove the battery cover. (See BATTERY REMOVAL/INSTALLATION [LF].)
3. Remove the under cover and splash shield as a single unit.
5. Set the coolant reserve tank out of the way.
6. Remove the plug hole plate. (See PLUG HOLE PLATE REMOVAL/INSTALLATION [LF].)
7. Set the drive belt out of the way. (See DRIVE BELT REPLACEMENT [LF].)
8. Remove the drive belt tensioner. (See TIMING CHAIN REMOVAL/INSTALLATION [LF].)
9. Remove in the order indicated in the table.
10. Install in the reverse order of removal.
11. Add engine coolant. (See ENGINE COOLANT REPLACEMENT.)
12. Inspect for the engine coolant leakage. (See ENGINE COOLANT LEAKAGE INSPECTION.)
The important part to look for with this answer, is the engine type ZJ, Z6, and LF.
Then there is this message: Model Years affected 2004, 2005, 2008
Some vehicles may experience Check Engine Light illumination with a trouble code indicating the thermostat is stuck open. The thermostat will need to be replaced with a modified one and there is a software update for the Powertrain Control Module.
I would think this is a 2-hour job and an average repair cost of approximately $260 to replace a thermostat on a Mazda 3. Personally, I would opt to purchase a 2004-2011 Mazda 3 Thermostat—Beck Arnley 143-0838 from places like this, spend $30 and plan on a whole day to do it ;-)
I do hope I did not confuse you and that this response wasn't too lengthy. Hope this helps, good luck.
The same code P0126 also applies to the Mazda MPV. The removal/replacement procedure is similar. There are videos on y
YouTube that show the process. Some people suggest replacing the Thermostat Housing, and you should also check your hoses as well.
I purchased an Action Code Reader from an auto supply store. It connects under the dash. They run around $75.00+ depending on the model, and let you check your vehicle for malfunction. My MPV MIL light came on, the code was P0126. The Action unit red the coolant temperature was between 147 to 163 ° when it should be around 180°. Low coolant temperature impacts engine performance and fuel economy, and the Thermostat should be replaced. The Thermostat is around $15.00 and a Thermostat and Housing is around $50.00.
After watching the video on you tube i replaced the thermostat on my Mazda 3 in 45 minutes. I placed a drain pan underon the t-stat housing and removed the tensioner and hoses. About 2quarts of coolant came out which i put back in after repair. If you're willing to pay $200 for the job, Ill do them all day long. Not a difficult job people! Bought part on Amazon.com.
Our 2004 Mazda 3's thermostat went out last year. It wasn't a hard repair, just cramped due to the location, and screws underneath the thermostat assembly.
all good for that ..
good for that service ..
Ingrid crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 55
crwdns2936753:030crwdne2936753:0 331
crwdns2942667:0crwdne2942667:0 209,813
