<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Xbox One Wireless Controller 1697&quot;]]></title>
<link>https://ts.ifixit.com/Answers/Device/Xbox_One_Wireless_Controller_1697/All?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Xbox One Wireless Controller 1697&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Fri, 21 Aug 2026 11:39:30 -0700</pubDate>
<item>
<title><![CDATA[Xbox One Wireless Controller 1697: Xbox One Controller is Flashing Slowly and Won't Work.]]></title>
<description><![CDATA[<p>So, last night, I turned off my console for the night and went to bed. This morning, I tried to turn the controller (and the console) back on to play. The console worked fine, and started right up. However, my controller started to blink slowly, and none of the buttons work. I've tried syncing it, changing the batteries, and unplugging the console, but it's still blinking. It only stops after I take a battery out, or leave it alone for a while. But if I press it's power button, it just blinks away (slowly, if that matters). Help?</p>
<p>⟐ Commented August 11, 2026 at 21:13 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/476342/Xbox+One+Controller+is+Flashing+Slowly+and+Won&#039;t+Work.</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/476342</guid>
<pubDate>Tue, 11 Aug 2026 21:13:27 -0700</pubDate>
</item>
<item>
<title><![CDATA[Xbox One Wireless Controller 1697: My Xbox one controller is not powering on while using batteries]]></title>
<description><![CDATA[<p>My Xbox one S controller doesn't power on even if I use jumpers won't turn on..then another issue with batteries, they don't turn on now am stuck 😔 becoz I opened it I washed it thoroughly but the problem might be on the board mainly so I would like to take me through where to start from</p>
<p>⟐ Commented August 16, 2025 at 8:34 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/910756/My+Xbox+one+controller+is+not+powering+on+while+using+batteries</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/910756</guid>
<pubDate>Sat, 16 Aug 2025 08:34:28 -0700</pubDate>
</item>
<item>
<title><![CDATA[Xbox One Wireless Controller 1697: Why is it harder to desolder the analog sticks xbox one]]></title>
<description><![CDATA[<p>im having trouble desoldering the new style xbox one analogs controller its seems there is less solder and is in between the board and the analogg and cant get it all off to replace the analog</p>
<p>⟐ Commented August 03, 2025 at 23:06 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/411124/Why+is+it+harder+to+desolder+the+analog+sticks+xbox+one</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/411124</guid>
<pubDate>Sun, 03 Aug 2025 23:06:04 -0700</pubDate>
</item>
<item>
<title><![CDATA[Xbox One Wireless Controller 1697: Mel controle não que mais ligar]]></title>
<description><![CDATA[<p>Como resolver</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/905195/Mel+controle+n%C3%A3o+que+mais+ligar</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/905195</guid>
<pubDate>Thu, 26 Jun 2025 18:29:36 -0700</pubDate>
</item>
<item>
<title><![CDATA[Xbox One Wireless Controller 1697: water on my controller and since then the start button and x butn stop]]></title>
<description><![CDATA[<p>accidently spilt bong water on my xbx one controller and since the the start button and X button has stopped working      put the fan on it for 24 hrsm and still the buttons arent functioning</p>
<p>⟐ Answered June 11, 2025 at 23:26 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/903405/water+on+my+controller+and+since+then+the+start+button+and+x+butn+stop</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/903405</guid>
<pubDate>Wed, 11 Jun 2025 23:26:40 -0700</pubDate>
</item>
<item>
<title><![CDATA[Xbox One Wireless Controller 1697: How to remove the trigger pins holding the bracket?]]></title>
<description><![CDATA[<p>Hi, first time posting.</p>
<p>My Xbox one trigger has broken. I've found the root cause of my problem. The Trigger bracket (not the piece you unscrew), has snapped on one side. I need to remove the metal pin/rod that holds it and the spring in place.</p>
<p>However, I don't know how this pin is in place or how to pull it out. There's literally nothing on the internet about these pieces.</p>
<p>Help is appreciated</p>
<p>Regards</p>
<p>Jonathan</p>
<p>⟐ Commented March 07, 2024 at 21:49 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/461155/How+to+remove+the+trigger+pins+holding+the+bracket</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/461155</guid>
<pubDate>Thu, 07 Mar 2024 21:49:07 -0700</pubDate>
</item>
<item>
<title><![CDATA[Xbox One Wireless Controller 1697: How can I calibrate the thumbsticks?]]></title>
<description><![CDATA[<p>I replaced the thumbsticks on my 1697 model with new hall effect based thumbsticks. Is it possible to calibrate the thumb sticks? The controller firmware seems to have internal stored calibration values of old ALPS potentiometer thumbsticks. Unfortunately the new ones are slightly off center and have different full-scale deflection ratio. At about 50% stick deflection the controller reports 100% value. I accuse the stored calibration, because I measured the full-scale deflection linearity of hall effect sensor in circuit. Output voltage range of hall effect sensor &quot;wiper pin&quot; is about 0.2V - 1.7V but interpreted range of ADC input seems to be somewhere from 0.5V - 1.4V.</p>
<p>I guess the controller still has its original firmware and I cannot upgrade firmware or use XBOX Accessories App (also the downgrade launch option doesn't help). Tried on multiple PCs with USB or wireless.</p>
<p>I also tried newer XBOX controllers, but I do not want to use them as they still do not use hall effect sensors and even worse, the firmware uses an integrated averaging filter for the thumbstick to &quot;heal&quot; drift issues, so that users won't notice the drift. However this filter leads to a square gating and not a circular gating stick movement.</p>
<p>Currently I can see only 2 options:</p>
<ul><li>use an intermediate op-amp mod to adjust the &quot;wiper&quot; range to the old values</li><li>try to reverse engineer the firmware running on the MKL26Z256VMC4 chip and find and update stored calibration values</li></ul>
<p>I will try the latter one as I'm more into software.</p>
<p>⟐ Answered March 06, 2024 at 13:36 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/837798/How+can+I+calibrate+the+thumbsticks</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/837798</guid>
<pubDate>Wed, 06 Mar 2024 13:36:52 -0700</pubDate>
</item>
<item>
<title><![CDATA[Xbox One Wireless Controller 1697: How to fix my dpad?]]></title>
<description><![CDATA[<p>all dpad directions seemed to work fine, until the down button stopped working (left,right and up are fine)</p>
<p>⟐ Answered February 16, 2024 at 8:50 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/469133/How+to+fix+my+dpad</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/469133</guid>
<pubDate>Fri, 16 Feb 2024 08:50:08 -0700</pubDate>
</item>
<item>
<title><![CDATA[Xbox One Wireless Controller 1697: My xbox one fat controller doesn't connect wireless]]></title>
<description><![CDATA[<p>If i put another controller anthena in it by soldering will it work? Or is there another solution?</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/816121/My+xbox+one+fat+controller+doesn&#039;t+connect+wireless</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/816121</guid>
<pubDate>Wed, 27 Sep 2023 13:44:52 -0700</pubDate>
</item>
<item>
<title><![CDATA[Xbox One Wireless Controller 1697: LT activates on its own when I press other buttons]]></title>
<description><![CDATA[<p>LT activates on its own when i press any other button, alreay removed the sensor and resistor just to see if it would stop, it activates even without the sensor</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/795046/LT+activates+on+its+own+when+I+press+other+buttons</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/795046</guid>
<pubDate>Thu, 01 Jun 2023 14:21:29 -0700</pubDate>
</item>
<item>
<title><![CDATA[Xbox One Wireless Controller 1697: Broke a headphone piece and it accidentally got stuck inside]]></title>
<description><![CDATA[<p>Me and my brother had got in an argument and we had wire headphones connected to the controller and he pulled on it and it had snapped the metal or whatever material from the headphones and got it stuck in the controller. I tried to get it out and accidentally pushed it in farther is there a way to get it out?</p>
<p>⟐ Answered March 13, 2023 at 10:47 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/769728/Broke+a+headphone+piece+and+it+accidentally+got+stuck+inside</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/769728</guid>
<pubDate>Mon, 13 Mar 2023 10:47:00 -0700</pubDate>
</item>
<item>
<title><![CDATA[Xbox One Wireless Controller 1697: Why is my right trigger always activated even when i'm not pressing it]]></title>
<description><![CDATA[<p>My right trigger has been like this for a year now i am going to open it up once i get the tools and i am wondering if anyone knows what is wrong and how to fix it.</p>
<p>Thanks</p>
<p>⟐ Commented March 01, 2023 at 17:19 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/509258/Why+is+my+right+trigger+always+activated+even+when+i&#039;m+not+pressing+it</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/509258</guid>
<pubDate>Wed, 01 Mar 2023 17:19:48 -0700</pubDate>
</item>
<item>
<title><![CDATA[Xbox One Wireless Controller 1697: Why is the home button getting stuck?]]></title>
<description><![CDATA[<p>Whenever I press the button, it goes down but takes so long to rise back up</p>
<p>⟐ Answer accepted January 04, 2023 at 9:49 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/762493/Why+is+the+home+button+getting+stuck</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/762493</guid>
<pubDate>Wed, 04 Jan 2023 09:49:03 -0700</pubDate>
</item>
<item>
<title><![CDATA[Xbox One Wireless Controller 1697: Does Xbox One Wireless Controller 1697 work in with xbox series x / s?]]></title>
<description><![CDATA[<p>This is a xbox one controller, so according to microsoft it is compatible with next gen consoles.  However, it is so old...</p>
<p><a href="https://support.xbox.com/en-US/help/hardware-network/controller/which-xbox-one-accessories-work-on-series-x-s-controller" rel="nofollow noopener noreferrer" title="https://support.xbox.com/en-US/help/hardware-network/controller/which-xbox-one-accessories-work-on-series-x-s-controller" target="_blank">https://support.xbox.com/en-US/help/hard...</a></p>
<p>⟐ Answered October 20, 2022 at 22:58 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/751673/Does+Xbox+One+Wireless+Controller+1697+work+in+with+xbox+series+x+-+s</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/751673</guid>
<pubDate>Thu, 20 Oct 2022 22:58:06 -0700</pubDate>
</item>
<item>
<title><![CDATA[Xbox One Wireless Controller 1697: Controller shows power but wont connect via usb or Bluetooth.]]></title>
<description><![CDATA[<p>I got an Xbox controller for free and I went to try to use it and it was not responding to any inputs after I turn it on, won't go into paring and won't shut off,  I decided to hook it up to my computer and the computer does not show anything is plugged in even though  the  controller is receiving power. I took it apart and I see no signs of obvious damage. Any suggestions?</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/746791/Controller+shows+power+but+wont+connect+via+usb+or+Bluetooth.</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/746791</guid>
<pubDate>Tue, 06 Sep 2022 23:11:03 -0700</pubDate>
</item>
<item>
<title><![CDATA[Xbox One Wireless Controller 1697: Replace micro USB port on Xbox Controller 1697]]></title>
<description><![CDATA[<p>A while back I broke the charging port on my Xbox controller and since it's not Bluetooth and I don't own an Xbox (I used it for PC), its just been collecting dust, is there a way I can replace the charging port?</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/742031/Replace+micro+USB+port+on+Xbox+Controller+1697</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/742031</guid>
<pubDate>Sun, 31 Jul 2022 15:34:13 -0700</pubDate>
</item>
<item>
<title><![CDATA[Xbox One Wireless Controller 1697: There is quite a gap between my left trigger and left bumper]]></title>
<description><![CDATA[<p>The gap between my left trigger and left bumper is quite  and the trigger is always slightly downward and stays active when pressed once until i forcefully move it slightly upwards is there any fix to this?</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/741913/There+is+quite+a+gap+between+my+left+trigger+and+left+bumper</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/741913</guid>
<pubDate>Sat, 30 Jul 2022 09:27:33 -0700</pubDate>
</item>
<item>
<title><![CDATA[Xbox One Wireless Controller 1697: How do I fix my guide button?]]></title>
<description><![CDATA[<p>I took apart my controller to replace the bumper buttons and I put everything back together. Now when I try to use my controller to power it on, the guide button will not work. It lights up just fine, but when I press it nothing happens. Anyone know what could have went wrong/ how to fix it? Thanks.</p>
<p>⟐ Commented July 20, 2022 at 23:45 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/740111/How+do+I+fix+my+guide+button</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/740111</guid>
<pubDate>Wed, 20 Jul 2022 23:45:24 -0700</pubDate>
</item>
<item>
<title><![CDATA[Xbox One Wireless Controller 1697: Why can’t I connect my Xbox controller to my phone]]></title>
<description><![CDATA[<p>I want to connect my controller to my iPhone to play with but I can’t</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/740138/Why+can%E2%80%99t+I+connect+my+Xbox+controller+to+my+phone</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/740138</guid>
<pubDate>Thu, 14 Jul 2022 16:39:59 -0700</pubDate>
</item>
<item>
<title><![CDATA[Xbox One Wireless Controller 1697: Dpad not clicking with faceplate]]></title>
<description><![CDATA[<p>I bought a replacement dpad on eBay and it clicks fine with no faceplate but with the faceplate on left and right don't click</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/735920/Dpad+not+clicking+with+faceplate</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/735920</guid>
<pubDate>Thu, 09 Jun 2022 07:50:09 -0700</pubDate>
</item>
</channel>
</rss>
