<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Water Dispenser&quot;]]></title>
<link>https://ts.ifixit.com/Answers/Device/Water_Dispenser?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Water Dispenser&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Tue, 30 Jun 2026 02:01:59 -0700</pubDate>
<item>
<title><![CDATA[GE Profile Tri Temperature Water dispenser: Water from cold water dispenser is not cold.]]></title>
<description><![CDATA[<p>Water from cold water dispenser is not cold.</p>
<p>⟐ Answer accepted December 19, 2023 at 5:50 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/152212/Water+from+cold+water+dispenser+is+not+cold.</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/152212</guid>
<pubDate>Tue, 19 Dec 2023 05:50:12 -0700</pubDate>
</item>
<item>
<title><![CDATA[GE Profile Tri Temperature Water dispenser: Why is my cold water not cold?]]></title>
<description><![CDATA[<p>My water cooler was working and all of a sudden the water is not cold. What do i do?</p>
<p>⟐ Commented December 05, 2022 at 18:10 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/170267/Why+is+my+cold+water+not+cold</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/170267</guid>
<pubDate>Mon, 05 Dec 2022 18:10:45 -0700</pubDate>
</item>
<item>
<title><![CDATA[GE Profile Tri Temperature Water dispenser: Dispenser freezes the water in the reservoir]]></title>
<description><![CDATA[<p>The cold water slows and then stops as a block of ice forms in the inside of the dispenser. In removing a panel on the rear that has 4 screws, I see on either side of the unit there are  rheostats with an adjusting screw. What is needed?</p>
<p>Model Number GXCF25FBS</p>
<p>⟐ Commented September 25, 2025 at 9:34 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/53133/Dispenser+freezes+the+water+in+the+reservoir</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/53133</guid>
<pubDate>Thu, 25 Sep 2025 09:34:31 -0700</pubDate>
</item>
<item>
<title><![CDATA[Water Dispenser: Why won't my bottom load water cooler pull water from the jug?]]></title>
<description><![CDATA[<p>My bottom load water cooler won't pull and dispense water from the jug.  We've tried another bottle and made sure the cap with water tube is securely inserted. What can I try to fix it?</p>
<p>⟐ Commented May 04, 2026 at 21:55 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/764521/Why+won&#039;t+my+bottom+load+water+cooler+pull+water+from+the+jug</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/764521</guid>
<pubDate>Mon, 04 May 2026 21:55:19 -0700</pubDate>
</item>
<item>
<title><![CDATA[GE Profile Tri Temperature Water dispenser: The water cooler is leaking, what might be the culprit?]]></title>
<description><![CDATA[<p>What is the best way to  figure out where the leaking water is coming from and what may be causing it?</p>
<p>⟐ Answered April 28, 2025 at 4:27 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/286091/The+water+cooler+is+leaking,+what+might+be+the+culprit</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/286091</guid>
<pubDate>Mon, 28 Apr 2025 04:27:03 -0700</pubDate>
</item>
<item>
<title><![CDATA[GE Profile Tri Temperature Water dispenser: cold water wil not come out]]></title>
<description><![CDATA[<p>the water will not come out ,the green light stays on all the time</p>
<p>⟐ Commented June 17, 2022 at 22:25 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/193847/cold+water+wil+not+come+out</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/193847</guid>
<pubDate>Fri, 17 Jun 2022 22:25:18 -0700</pubDate>
</item>
<item>
<title><![CDATA[GE Profile Tri Temperature Water dispenser: My free standing water dispenser is leaking from the bottom]]></title>
<description><![CDATA[<p>I have a hot/cold free standing water dispenser and it is leaking.  I wonder if they can be repaired and if so where do I go.</p>
<p>⟐ Answered December 19, 2019 at 1:20 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/414869/My+free+standing+water+dispenser+is+leaking+from+the+bottom</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/414869</guid>
<pubDate>Thu, 19 Dec 2019 01:20:45 -0700</pubDate>
</item>
<item>
<title><![CDATA[GE Profile Tri Temperature Water dispenser: How do I clear or fix an E4 error code]]></title>
<description><![CDATA[<p>I get an E4 error code and have unplugged for 24 hours and restarted but still get E4 code and unit automatically shuts off</p>
<p>⟐ Commented October 27, 2022 at 11:31 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/342419/How+do+I+clear+or+fix+an+E4+error+code</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/342419</guid>
<pubDate>Thu, 27 Oct 2022 11:31:59 -0700</pubDate>
</item>
<item>
<title><![CDATA[Water Dispenser: Why does our water taste like dirt?]]></title>
<description><![CDATA[<p>I have removed the water bottle and drained all the water from the water cooler.  I have wiped clean the inside where the water lays from the water bottle.  The water still has a dirty taste.  What to do?</p>
<p>⟐ Edited December 19, 2023 at 5:55 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/250824/Why+does+our+water+taste+like+dirt</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/250824</guid>
<pubDate>Tue, 19 Dec 2023 05:55:28 -0700</pubDate>
</item>
<item>
<title><![CDATA[GE Profile Tri Temperature Water dispenser: dispenser is leaking internally]]></title>
<description><![CDATA[<p>The dispenser (GE) stand alone....water leading ...appears to be internal issue.</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/340839/dispenser+is+leaking+internally</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/340839</guid>
<pubDate>Thu, 29 Sep 2016 18:00:32 -0700</pubDate>
</item>
<item>
<title><![CDATA[GE Profile Tri Temperature Water dispenser: How I make the water cooler]]></title>
<description><![CDATA[<p>is there a dial for coolder water</p>
<p>⟐ Answered June 08, 2021 at 23:05 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/118948/How+I+make+the+water+cooler</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/118948</guid>
<pubDate>Tue, 08 Jun 2021 23:05:57 -0700</pubDate>
</item>
<item>
<title><![CDATA[Water Dispenser: hot water did not work]]></title>
<description><![CDATA[<p>hot water did not work</p>
<p>⟐ Commented July 25, 2021 at 12:18 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/389176/hot+water+did+not+work</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/389176</guid>
<pubDate>Sun, 25 Jul 2021 12:18:44 -0700</pubDate>
</item>
<item>
<title><![CDATA[GE Profile Tri Temperature Water dispenser: How to clean the piping etc of the Water dispenser.]]></title>
<description><![CDATA[<p>It is easy enouph to take the bottle down to clean the reachable parts of the dispenser but how does on clean the internal piping of the dispenser?</p>
<p>⟐ Commented October 12, 2017 at 15:58 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/87935/How+to+clean+the+piping+etc+of+the+Water+dispenser.</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/87935</guid>
<pubDate>Thu, 12 Oct 2017 15:58:13 -0700</pubDate>
</item>
<item>
<title><![CDATA[Water Dispenser: Why there is no proper flow from hot outlet]]></title>
<description><![CDATA[<p>thw cold water outlet working smoothly, but very slow water coming out from hot water outlet. this is Class pro water bottled dispensor. i already cleaned using vinegar with hot water, but still the same condition</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/380546/Why+there+is+no+proper+flow+from+hot+outlet</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/380546</guid>
<pubDate>Sun, 05 Mar 2017 20:51:30 -0700</pubDate>
</item>
<item>
<title><![CDATA[Water Dispenser: Nestle water dispenser user's manual]]></title>
<description><![CDATA[<p>The hot water is leaking without pressing it.. It is flooding all the time while bottle is on the dispenser.. How to fix it?</p>
<p>⟐ Commented March 23, 2026 at 20:54 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/722973/Nestle+water+dispenser+user&#039;s+manual</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/722973</guid>
<pubDate>Mon, 23 Mar 2026 20:54:41 -0700</pubDate>
</item>
<item>
<title><![CDATA[Water Dispenser: Water leakage from water dispenser]]></title>
<description><![CDATA[<p>I just replaced the water bottle in my water dispense but the water starts leaking to the floor from the sides and rear of the dispenser.</p>
<p>⟐ Answer deleted September 03, 2021 at 23:17 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/328828/Water+leakage+from+water+dispenser</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/328828</guid>
<pubDate>Fri, 03 Sep 2021 23:17:09 -0700</pubDate>
</item>
<item>
<title><![CDATA[Water Dispenser: Locating Hot Water RESET]]></title>
<description><![CDATA[<p>I currently own the Crystal Mountain “Storm” bottle water dispenser. I moved the unit recently, now the water is not heating properly - at all. I’ve attempted to toggle the switch up front with no luck. I cannot find any useful info online for locating the hot water RESET button in the rear. I’d appreciate any useful ideas or solution. Thx!</p>
<p>⟐ Answer edited July 25, 2021 at 13:26 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/700321/Locating+Hot+Water+RESET</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/700321</guid>
<pubDate>Sun, 25 Jul 2021 13:26:44 -0700</pubDate>
</item>
<item>
<title><![CDATA[GE Profile Tri Temperature Water dispenser: What would cause the water from my dispenser to leak out onto the floo]]></title>
<description><![CDATA[<p>GE Profile water dispenser is leaking water out onto the floor.</p>
<p>⟐ Answered May 19, 2019 at 9:23 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/568325/What+would+cause+the+water+from+my+dispenser+to+leak+out+onto+the+floo</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/568325</guid>
<pubDate>Sun, 19 May 2019 09:23:33 -0700</pubDate>
</item>
<item>
<title><![CDATA[GE Profile Tri Temperature Water dispenser: Why is my ge water dispenser leaking?]]></title>
<description><![CDATA[<p>I put a jug of water on my ge water dispenser i got from my dad and the water leaks out the bottom. Help.. i have well water</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/273524/Why+is+my+ge+water+dispenser+leaking</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/273524</guid>
<pubDate>Fri, 27 Nov 2015 21:32:44 -0700</pubDate>
</item>
<item>
<title><![CDATA[GE Profile Tri Temperature Water dispenser: Why the water dispenser faucet is leaking?]]></title>
<description><![CDATA[<p>why the water dispenser faucet is leaking?</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/249358/Why+the+water+dispenser+faucet+is+leaking</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/249358</guid>
<pubDate>Mon, 17 Aug 2015 10:35:55 -0700</pubDate>
</item>
</channel>
</rss>
