<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Vacuum Cleaner&quot;]]></title>
<link>https://ts.ifixit.com/Answers/Device/Vacuum_Cleaner/All?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Vacuum Cleaner&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Tue, 08 Sep 2026 21:02:27 -0700</pubDate>
<item>
<title><![CDATA[iRobot Roomba Combo Essential: Roomba rides off the charger when charging and stops charging after 5]]></title>
<description><![CDATA[<p>Roomba stops charging after 5 minutes and sometimes drives off the charger and stops right away</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/971522/Roomba+rides+off+the+charger+when+charging+and+stops+charging+after+5</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/971522</guid>
<pubDate>Mon, 07 Sep 2026 16:28:54 -0700</pubDate>
</item>
<item>
<title><![CDATA[Vacuum Cleaner: Vax Blade 3 not working]]></title>
<description><![CDATA[<p>I have a blade 3 Vax cordless vacuum that no linger works as it should. The battery pack (18v) does not recharge on the charger</p>
<p>The individual cells are showing about 3.7 volts each and the motor runs for a few seconds before a &quot;code red&quot;.</p>
<p>I suspect the battery managment system is faulty.</p>
<p>What I would like to do is &quot;convert it to corded&quot; i.e run it off an adaptor. The motor rating is 160 watts at 18 volts, and the charger adaptor is 18 v at 1.5 watts.</p>
<p>So is the 160 watt motor rating the no load, load or stall amount?</p>
<p>Does it really need a 9 amp rated 18 volt adaptor? (160 /18)?</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/DIs6l4FcMHXVUgOx.standard" width="81" height="225" class="hasMenu hasLarge" alt="crwdns2915344:0crwdne2915344:0" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/DIs6l4FcMHXVUgOx.full&quot;, '', 'width=1440,height=4000')" /></div>]]></description>
<link>https://ts.ifixit.com/Answers/View/971324/Vax+Blade+3+not+working</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/971324</guid>
<pubDate>Sun, 06 Sep 2026 02:56:33 -0700</pubDate>
</item>
<item>
<title><![CDATA[Dyson V12 Detect Slim: V12 keeps shutting off in seconds, but…]]></title>
<description><![CDATA[<p>V12 started shutting off after several seconds.</p>
<p>First, it only happened when the vacuum increased suction.</p>
<p>Then, it started happening within normal use. But if I started it in eco mode, it worked ok.</p>
<p>The thing is, once I turned it on again 3 or 4 times on a row, it started working as usual, without shutting off. Like if something is heating up so the vac starts operating as normal.</p>
<p>Now it shuts down even in eco mode. Still, 3–4 restarts help, and it runs until I manually turn it off.</p>
<p>⟐ Answer edited septiembre 05, 2026 at 6:18 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/899067/V12+keeps+shutting+off+in+seconds,+but%E2%80%A6</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/899067</guid>
<pubDate>Sat, 05 Sep 2026 06:18:51 -0700</pubDate>
</item>
<item>
<title><![CDATA[Robotic Vacuum Cleaner: How to reassemble front collision plate of robot]]></title>
<description><![CDATA[<p>Replacing a wheel in a Ikohs/Create S15, is there any service manual how to reattach the front collision plate which got accidentally dislodged, insufficient switch gap when reassembling it, attaching the bottom &quot;chin&quot;, it should be similar to some Neatsvor, Valubot, Tesvor robots, thank you for any informations.</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Aggiorna_09_04_Num_26" class="header">Aggiorna (09/04/26)</h3></div>
<p>I'm bewildered/stumped, also difficult to describe, but here it goes :</p>
<p>this is what it looks like, there are 5 mounting slots/channels on top, both robot and collision plate</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/BmU1DwVEBDIUNMxW.standard" width="169" height="225" class="hasMenu hasLarge" alt="crwdns2915344:0crwdne2915344:0" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/BmU1DwVEBDIUNMxW.huge&quot;, '', 'width=901,height=1200')" /></div>
<p>once inserted gently into channels from the top, this is how it looks, like this there is sufficient switch play and the robot goes forward :</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/v3S6smpZLQLuMeLw.standard" width="282" height="211" class="hasMenu hasLarge" alt="crwdns2915344:0crwdne2915344:0" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/v3S6smpZLQLuMeLw.huge&quot;, '', 'width=1600,height=1200')" /></div>
<p>this is what it looks like from below, you can't see the switches inside the gap, about 1 mm, but it seems sufficient leeway by turning the robot on :</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/qlAXCoVKgLdBXDpD.standard" width="282" height="211" class="hasMenu hasLarge" alt="crwdns2915344:0crwdne2915344:0" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/qlAXCoVKgLdBXDpD.huge&quot;, '', 'width=1600,height=1200')" /></div>
<p>I suspect the problem could be reattaching the bottom &quot;chin&quot;, this is how it rests by aligning the screw holes gently :</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/CPfd2aXTbFntmjuT.standard" width="282" height="211" class="hasMenu hasLarge" alt="crwdns2915344:0crwdne2915344:0" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/CPfd2aXTbFntmjuT.huge&quot;, '', 'width=1600,height=1200')" /></div>
<p>it seems to me the chin is misaligned wrt to those 4 ridges on the robot's bottom, and screwing them back on it looses any &quot;play&quot; somehow, it's been working for about 5 years so it could have deformed somehow, so that the top part is possibly splayed outwards ? or something really finicky/fussy/particular ?</p>
<p>There wouldn't be any signs of visible damage or deformation that I can tell.</p>
<p>I circled where the switch contacts the collision plate/bumper which is worn due to usage :</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/ehGHhjZYV3cB3rjG.standard" width="169" height="225" class="hasMenu hasLarge" alt="crwdns2915344:0crwdne2915344:0" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/ehGHhjZYV3cB3rjG.huge&quot;, '', 'width=901,height=1200')" /></div>
<p>the switches would seem undamaged, and it works with just the top half of bumper slotted on, also the top and bottom of robot seem correctly seated together</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/3Zp2bC2sd2PmYjf6.standard" width="282" height="211" class="hasMenu hasLarge" alt="crwdns2915344:0crwdne2915344:0" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/3Zp2bC2sd2PmYjf6.huge&quot;, '', 'width=1600,height=1200')" /></div>
<p>I can't imagine it being so fussy, it could have warped with usage somehow, otherwise when manufacturing them it would take hours just for the bumper, also bumper reassembly videos on youtube seem fairly straightforward, just screwing the 2 halves of bumper together, not</p>
<p>update : it was a silly mistake, reassembling the robot, the top front fascia with sensors was misrotated about 3 mm, the collision plate of course fits perfectly after reseating it, you couldn't tell from those photos, I circled what it was :</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/bxLMJBDHijZxYR1F.standard" width="282" height="211" class="hasMenu hasLarge" alt="crwdns2915344:0crwdne2915344:0" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/bxLMJBDHijZxYR1F.huge&quot;, '', 'width=1600,height=1200')" /></div>
<p>⟐ Edited by author septiembre 04, 2026 at 16:23 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/971022/How+to+reassemble+front+collision+plate+of+robot</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/971022</guid>
<pubDate>Fri, 04 Sep 2026 16:23:08 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ecovacs Robotic Vacuum Cleaner: How to change side brush motor]]></title>
<description><![CDATA[<p>i have n20 pro model and side brush is not functioning need to replace motor, please share</p>
<p>⟐ Answered septiembre 01, 2026 at 7:32 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/970697/How+to+change+side+brush+motor</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/970697</guid>
<pubDate>Tue, 01 Sep 2026 07:32:43 -0700</pubDate>
</item>
<item>
<title><![CDATA[Bissell Zing 2156A: Bissell 2165Z cord reel assembly]]></title>
<description><![CDATA[<p>​Hi everyone,</p>
<p>​I'm trying to repair my Bissell 2165Z vacuum cleaner, which suddenly stopped working during use due to a burnt/melted internal plastic contact block inside the cord reel mechanism.</p>
<p>​Unfortunately, Bissell doesn't sell this specific internal component or a replacement cord reel assembly anymore. Since I want to avoid throwing the vacuum away and prefer a sustainable repair, does anyone know if there is a compatible alternative part, a source to find this exact cord reel, or a safe way to bypass this damaged contact block?</p>
<p>​Any advice or part numbers would be greatly appreciated! Thanks in a lot.</p>
<p>⟐ Commented agosto 30, 2026 at 17:04 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/970413/Bissell+2165Z+cord+reel+assembly</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/970413</guid>
<pubDate>Sun, 30 Aug 2026 17:04:38 -0700</pubDate>
</item>
<item>
<title><![CDATA[Dyson V15 Detect: Why is my laser stop working?..]]></title>
<description><![CDATA[<p>Hello folks! I just wanted to ask an question about Dyson V15 Detect laser head! One random day in 2024 the laser stopped working but the blue and yellow thing roll and suck things good as usual and the vacuum works. And i don't want to see 'put on the switch' bla bla cuz IT dont have the SWITCH AND IT ONLY have 'Fluffly Optic!🥰' and there is no hair in every roller if anyone is smarter like Albert please tell me what is wrong with it.😊</p>
<p>⟐ Edited by author agosto 27, 2026 at 7:03 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/969941/Why+is+my+laser+stop+working..</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/969941</guid>
<pubDate>Thu, 27 Aug 2026 07:03:20 -0700</pubDate>
</item>
<item>
<title><![CDATA[Roborock Qrevo S5V: Roborock Qrevo S5V dock power board (CPS036018) IC '21ASP' identification and open-collector configuration]]></title>
<description><![CDATA[<p>Troubleshooting component-level repair on Roborock Qrevo S5V docking station power supply board (PN: CPS036018). The SOT-23-5 IC marked '21ASP' has failed.</p>
<p>Bench measurements and trace analysis:</p>
<p>- Pin 2: GND (Vcc-)</p>
<p>- Pin 5: 10V Vcc+</p>
<p>- Pins 1 &amp; 3: AC line phase monitoring (zero-crossing/heartbeat inputs)</p>
<p>- Pin 4: Output running through a 10k resistor to the anode of a PC817 optocoupler (cathode to GND), sending the power-available heartbeat signal across to the secondary-side processor board.</p>
<p>Because Pin 4 drives an optocoupler LED via a 10k resistor rather than a standard logic trace, an open-collector/open-drain output configuration is actually required (sinking current through the optocoupler). We are looking for an exact cross-reference or identification for the '21ASP' SOT-23-5 IC matching this open-collector comparator or logic function.</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/969934/Roborock+Qrevo+S5V+dock+power+board+(CPS036018)+IC+&#039;21ASP&#039;+identification+and+open-collector+configuration</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/969934</guid>
<pubDate>Thu, 27 Aug 2026 05:50:37 -0700</pubDate>
</item>
<item>
<title><![CDATA[Roborock Qrevo S5V: Roborock Qrevo S5V dock power board (CPS036018) IC '21ASP' replacement/identification]]></title>
<description><![CDATA[<p>Looking for component-level repair help for a Roborock Qrevo S5V docking station power supply board (PN: CPS036018). The IC marked '21ASP' in a SOT-23-5 package has failed or needs identification. Bench measurements show Pin 2 = GND, Pin 5 = 10V Vcc, Pin 4 = 4.6V, and Pins 1/3 = ~0.1V. Pin 4 is some sort of data line via an optocoupler sending information over to the processor board. Pins 1 and 3 are control or sensor lines.</p>
<p>Since replacement power boards are unavailable, does anyone know the exact cross-reference or functional equivalent for this IC?</p>
<p>⟐ Answered agosto 27, 2026 at 5:04 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/969461/Roborock+Qrevo+S5V+dock+power+board+(CPS036018)+IC+&#039;21ASP&#039;+replacement-identification</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/969461</guid>
<pubDate>Thu, 27 Aug 2026 05:04:48 -0700</pubDate>
</item>
<item>
<title><![CDATA[iRobot Roomba 900 Series: error 6 cliff sensor move to new location all the time]]></title>
<description><![CDATA[<p>roomba 980 new  lithium battery, covered cliff sensors and it continues with ERROR 6  rebooted continues as soon as it  starts to leave the docking station it stops and ERROR 6 “move to a new location”  I covered the sensors with aluminum foil so IR should have activated.  Is it a sensor or is it  motherboard issue everything such as charging display all works.  Thank you  Antonio</p>
<p>⟐ Commented agosto 26, 2026 at 0:33 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/643697/error+6+cliff+sensor+move+to+new+location+all+the+time</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/643697</guid>
<pubDate>Wed, 26 Aug 2026 00:33:53 -0700</pubDate>
</item>
<item>
<title><![CDATA[Dyson Small Ball: Replace the belt in Dyson small Ball]]></title>
<description><![CDATA[<p>How to get to the belt that drives the roller brush on a Dyson Small Ball Vacuum Cleaner ?</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/969730/Replace+the+belt+in+Dyson+small+Ball</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/969730</guid>
<pubDate>Tue, 25 Aug 2026 22:42:26 -0700</pubDate>
</item>
<item>
<title><![CDATA[Roborock S8 MaxV Ultra: flexi arm won't spin]]></title>
<description><![CDATA[<p>any fixes for the flexi arm not spinning?</p>
<p>⟐ Commented agosto 24, 2026 at 18:09 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/939453/flexi+arm+won&#039;t+spin</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/939453</guid>
<pubDate>Mon, 24 Aug 2026 18:09:16 -0700</pubDate>
</item>
<item>
<title><![CDATA[ZCWA BR151: BR151 Stuck in Docking Loop]]></title>
<description><![CDATA[<p>When you turn the unit on, and tell it to go home, it will find the base and align with it, center up, go up the ramp, then bump against the back wall of the charging base to only turn around and do it all over again. I have noticed that just as it contacts the back wall of the charging base, the plug light on top of the unit will go from green to red for just a second, then back to green. It will do this dance indefinitely. I wondered if the battery could be bad, but they ain't cheap and I don't want to buy a new one without knowing if this will solve the problem. Contacts were cleaned. Censors cleaned. Battery was pulled from unit for 30+ minutes. Anybody solved this problem?</p>
<p>Edited to add: I checked the voltage on the docking station and it is getting voltage. The feet on the docking station are springy so they are not stuck. Everything has been cleaned with rubbing alcohol.<br /><br />Edited again 8-24-2026:<br /><br />Changed the battery out, but the behavior persists. Suspect it is probably the charging board. Firmware update requires installing an app that wants far too much information for the purpose it fills. No way am I going to turn loose a robot from Shenzhen, China on my WiFi network that is all ready having issues with a ton of personal info. I don't see any other external ports to plug the robot in via usb either. Will put this in the junk pile. Maybe some other parts will find their way here someday and I can cannibalize those pieces into one working machine.</p>
<p>⟐ Edited by author agosto 24, 2026 at 17:39 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/967094/BR151+Stuck+in+Docking+Loop</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/967094</guid>
<pubDate>Mon, 24 Aug 2026 17:39:42 -0700</pubDate>
</item>
<item>
<title><![CDATA[Simple Way Pet Grooming Vacuum V10 XWLMQ01: How do I replace the trimming guards for the blade attachment]]></title>
<description><![CDATA[<p>I lost the blade attachments for the shaving part of the vacuum and I need to replace them.</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/969529/How+do+I+replace+the+trimming+guards+for+the+blade+attachment</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/969529</guid>
<pubDate>Mon, 24 Aug 2026 11:04:31 -0700</pubDate>
</item>
<item>
<title><![CDATA[iRobot Roomba J7 Plus: Cannot Factory Reset / No Sound]]></title>
<description><![CDATA[<p>Gifted a J7+ that was refurb from manufacturer. Replaced the battery and still having issues.</p>
<p>When attempting to register, it says device needs factory reset. After performing factory reset, it says it failed and to try again. I also do not hear any tones or sound. Any recommendations? I've tried numerous solutions but nothing seems to work.</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/969468/Cannot+Factory+Reset+-+No+Sound</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/969468</guid>
<pubDate>Mon, 24 Aug 2026 05:09:44 -0700</pubDate>
</item>
<item>
<title><![CDATA[Black and Decker CHV1410 Dustbuster: What can I do to stop my vacuum from turning off every 10 seconds?]]></title>
<description><![CDATA[<p>The vacuum worked fine the first few times I used it, but it now turns off every couple seconds even when the battery level says it has charge.</p>
<p>⟐ Commented agosto 23, 2026 at 15:52 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/612375/What+can+I+do+to+stop+my+vacuum+from+turning+off+every+10+seconds</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/612375</guid>
<pubDate>Sun, 23 Aug 2026 15:52:25 -0700</pubDate>
</item>
<item>
<title><![CDATA[Black and Decker CHV1410 Dustbuster: Can I change my dust buster battery and if so where do I get it?]]></title>
<description><![CDATA[<p>Black and Decker dust buster CHV1410L built in rechargeable battery has died. Can I purchase a new battery? If so where?</p>
<p>⟐ Commented agosto 23, 2026 at 15:43 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/534648/Can+I+change+my+dust+buster+battery+and+if+so+where+do+I+get+it</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/534648</guid>
<pubDate>Sun, 23 Aug 2026 15:43:11 -0700</pubDate>
</item>
<item>
<title><![CDATA[Eufy RoboVac 30C: Replacement Rubber strip for the brush guard for Eufy 30c]]></title>
<description><![CDATA[<p>Help— to reduce wastage . have a Eufy 30c . Looking for replacement for the rubber strip in the brush guard rather than buying a new brush guard for Eufy 30c.</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/969339/Replacement+Rubber+strip+for+the+brush+guard+for+Eufy+30c</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/969339</guid>
<pubDate>Sun, 23 Aug 2026 07:16:08 -0700</pubDate>
</item>
<item>
<title><![CDATA[McCulloch MC-1275 Heavy Duty Steam Cleaner: Troubleshooting heats but not working]]></title>
<description><![CDATA[<p>When the button is pressed steam is not coming out.  I know that the machine is correctly heating to temperature and setam seeps in order to not over pressurize but not sure how to fix the problem</p>
<p>⟐ Commented agosto 21, 2026 at 22:43 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/390786/Troubleshooting+heats+but+not+working</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/390786</guid>
<pubDate>Fri, 21 Aug 2026 22:43:04 -0700</pubDate>
</item>
<item>
<title><![CDATA[ZACO V5s pro robotic vacuum cleaner: All lights flash So what?]]></title>
<description><![CDATA[<p>Zaco V5s Pro's manual  indicates in case of  &quot;All lights flash&quot;: when robot in error.</p>
<p>I switched off both the loader and the robot. Then I switched on both the loader and the robot and got an undefined signal: upper lights on, middle and under lihgts flash.</p>
<p>So what can I do?</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/969105/All+lights+flash+So+what</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/969105</guid>
<pubDate>Fri, 21 Aug 2026 10:14:16 -0700</pubDate>
</item>
</channel>
</rss>
