<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Tower Fan&quot;]]></title>
<link>https://ts.ifixit.com/Answers/Device/Tower_Fan/All?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Tower Fan&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Thu, 04 Jun 2026 23:12:46 -0700</pubDate>
<item>
<title><![CDATA[Honeywell HY-254-TGT: Synchronous Motor Replacement Part]]></title>
<description><![CDATA[<p>I am replacing the synchronous motor in this tower fan model and have found a suitable replacement. However, the original motor has a white plastic arm attached to the motor by way of a hollow metal pin running perpendicular to the motor shaft.</p>
<p>How is this white plastic arm removed or where can I get a replacement?</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/951593/Synchronous+Motor+Replacement+Part</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/951593</guid>
<pubDate>Wed, 22 Apr 2026 17:44:12 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ionic Breeze: Wire broke. Can it be replaced?]]></title>
<description><![CDATA[<p>Wire inside broke. Can it be replaced?</p>
<p>⟐ Commented noviembre 19, 2025 at 21:47 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/754936/Wire+broke.+Can+it+be+replaced</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/754936</guid>
<pubDate>Wed, 19 Nov 2025 21:47:22 -0700</pubDate>
</item>
<item>
<title><![CDATA[Tower Fan: It has 124V at the circuit but still not turning on]]></title>
<description><![CDATA[<p>I tested my tower fan with a voltage meter and confirmed that it is receiving 124 volts. Despite this, the fan still does not turn on. I’ve double-checked the power source and connections, and everything seems fine.</p>
<p>Has anyone experienced something similar or can suggest what might be causing this issue? Any advice on troubleshooting or possible internal faults would be appreciated.</p>
<p>Thanks in advance!</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/ByklhQNAlT1oTgNx.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/ByklhQNAlT1oTgNx.huge&quot;, '', 'width=900,height=1200')" /></div>
<p>⟐ Answered agosto 20, 2025 at 12:58 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/912768/It+has+124V+at+the+circuit+but+still+not+turning+on</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/912768</guid>
<pubDate>Wed, 20 Aug 2025 12:58:03 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ionic Breeze: My ionic breeze makes a constant clicking noise t.]]></title>
<description><![CDATA[<p>The rapid clicking noise started after a routine cleaning. I always air dry for 24hrs after a cleaning so I know it wasn't a moisture problem. I cleaned it again, rinsed thoroughly,  still clicking. I run it anyway but am concerned that the noise indicates a problem.</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/908876/My+ionic+breeze+makes+a+constant+clicking+noise+t.</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/908876</guid>
<pubDate>Thu, 24 Jul 2025 01:04:05 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honeywell HY-204: Where do I buy Febreze scent cartridges?]]></title>
<description><![CDATA[<p>My fan ran out of the Febreze scent, and just smells like air, and I couldn't find the cartridges at my local grocery store, is there a specific store I should go to, or a website I should try?</p>
<p>⟐ Commented marzo 05, 2025 at 11:17 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/197915/Where+do+I+buy+Febreze+scent+cartridges</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/197915</guid>
<pubDate>Wed, 05 Mar 2025 11:17:47 -0700</pubDate>
</item>
<item>
<title><![CDATA[Tower Fan: Why is the motor not working]]></title>
<description><![CDATA[<p>My Ozavo tower fan is not working but the circuit and the oscillator works perfectly fine. I checked for burns or wire damages, but it is good. Kindly help me with this</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/863298/Why+is+the+motor+not+working</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/863298</guid>
<pubDate>Tue, 06 Aug 2024 06:27:01 -0700</pubDate>
</item>
<item>
<title><![CDATA[Seville Classics MSC10166: Where do the wires all connect to?]]></title>
<description><![CDATA[<p>I am fixing my fan and forgot where all the wires go to so I was wondering if you can show me where all the wires go to from the PCB</p>
<p>⟐ Answered julio 05, 2024 at 14:46 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/857996/Where+do+the+wires+all+connect+to</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/857996</guid>
<pubDate>Fri, 05 Jul 2024 14:46:24 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ionic Breeze: Why won't my Ionic Breeze Air Purifier turn on?]]></title>
<description><![CDATA[<p>Sharper Image model# SI830. Pushing power button does nothing. Tried taking it apart but cannon see any obvious thing to do, no blown fuse or anything I can identify by taking bottom cover off.</p>
<p>⟐ Commented junio 12, 2024 at 3:23 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/118966/Why+won&#039;t+my+Ionic+Breeze+Air+Purifier+turn+on</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/118966</guid>
<pubDate>Wed, 12 Jun 2024 03:23:45 -0700</pubDate>
</item>
<item>
<title><![CDATA[Lasko 4910: Trying to fix a Lasko Tower Fan, Model 4920]]></title>
<description><![CDATA[<p>The fan now operates only on the &quot;LOW&quot; Speed setting.  Trying to select &quot;MEDIUM&quot; or &quot;HIGH&quot; from the keypad or remote control has no effect.  In fact, the Remote Control unit doesn't seem to function at all.    (and yes, I did check the batteries ;-&gt;)</p>
<p>Here is the information on the name plate:</p>
<p>LASKO E20739 Blower Fan</p>
<p>Type TFB</p>
<p>CS6082065177</p>
<p>120 VAC, 60 hz, 1.0 Amp</p>
<p>Model: 4920</p>
<p>I reached out to Lasko's online customer support and received the following reply:</p>
<p>&quot;Thank you for your inquiry. Unfortunately, Encompass has no Service Parts or Literature available for your model. We apologize for any inconvenience&quot;.</p>
<p>Does anyone out there have any ideas about how to troubleshoot &amp; fix this item?   THANKS!</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/849452/Trying+to+fix+a+Lasko+Tower+Fan,+Model+4920</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/849452</guid>
<pubDate>Tue, 14 May 2024 04:44:49 -0700</pubDate>
</item>
<item>
<title><![CDATA[Bionaire Mini Tower Fan: 2nd speed fan button does not click and stay on]]></title>
<description><![CDATA[<p>How can I remove the top and get into where the fan speed buttons are?  The 2nd speed button does not &quot;click&quot; and stay on by itself, only the 1st speed button.</p>
<p>⟐ Answered mayo 12, 2024 at 2:47 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/500205/2nd+speed+fan+button+does+not+click+and+stay+on</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/500205</guid>
<pubDate>Sun, 12 May 2024 02:47:22 -0700</pubDate>
</item>
<item>
<title><![CDATA[Seville Classics MSC10166: Remote not Working on Seville Tower Fan]]></title>
<description><![CDATA[<p>I have a Seville Classic Tower fan and the remote is not working although I put in (2) new batteries. How can I troubleshoot?</p>
<p>Thank you.</p>
<p>Flo</p>
<p>⟐ Commented febrero 13, 2024 at 12:22 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/331723/Remote+not+Working+on+Seville+Tower+Fan</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/331723</guid>
<pubDate>Tue, 13 Feb 2024 12:22:35 -0700</pubDate>
</item>
<item>
<title><![CDATA[Vornado Duo: How can I tell if the problem is the fuse?]]></title>
<description><![CDATA[<p>How can I tell if the problem is the fuse? Is there “a tell” that the problem is the motor or circuit board before searching for fuses? For the 1st micro second it moves an inch like it’s getting power.</p>
<p>⟐ Answer edited septiembre 01, 2023 at 16:13 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/811514/How+can+I+tell+if+the+problem+is+the+fuse</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/811514</guid>
<pubDate>Fri, 01 Sep 2023 16:13:06 -0700</pubDate>
</item>
<item>
<title><![CDATA[Holmes tower fan: Why does the fan randomly rev up then slows again?]]></title>
<description><![CDATA[<p>My fan works great but lately it has begun to randomly rev to highest speed for a few seconds then return to the set speed. What's up?</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/803324/Why+does+the+fan+randomly+rev+up+then+slows+again</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/803324</guid>
<pubDate>Sun, 23 Jul 2023 11:40:25 -0700</pubDate>
</item>
<item>
<title><![CDATA[Ionic Breeze: I clean my ionic breeze filters and when I put it back in it will not]]></title>
<description><![CDATA[<p>I clean my on ion breeze filters. And when I put it back in the  Icon breeze filter it quit working</p>
<p>⟐ Answered julio 05, 2023 at 15:09 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/739811/I+clean+my+ionic+breeze+filters+and+when+I+put+it+back+in+it+will+not</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/739811</guid>
<pubDate>Wed, 05 Jul 2023 15:09:22 -0700</pubDate>
</item>
<item>
<title><![CDATA[Tower fan: Doesn't act like it has any power at all]]></title>
<description><![CDATA[<p>So I got a fan that didn't work for free to fiddle with and I've got it taken apart and it has power, I used a multimeter and connecting a couple of wire to the leads via solder I was able to get the different functions to work, I'm new to using one but the multimeter stayed at 0. Anyways I was wondering what it could be or if I could just hard wire the high and low settings to an external switch.</p>
<p>⟐ Commented junio 11, 2023 at 19:17 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/796489/Doesn&#039;t+act+like+it+has+any+power+at+all</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/796489</guid>
<pubDate>Sun, 11 Jun 2023 19:17:09 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honeywell HY-254-TGT: Why isn't the fan oscillating?]]></title>
<description><![CDATA[<p>I've had this fan for over a year without any problems. I tried using i today and the fan is no longer turning as it normally does. It still blows air but doesn't move back and forth. Help!</p>
<p>⟐ Commented abril 25, 2023 at 13:35 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/262815/Why+isn&#039;t+the+fan+oscillating</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/262815</guid>
<pubDate>Tue, 25 Apr 2023 13:35:22 -0700</pubDate>
</item>
<item>
<title><![CDATA[Bionaire Mini Tower Fan: Noisy mini bionaire oscillating fan]]></title>
<description><![CDATA[<p>How do I quiet down my mini bionaire oscillating fan</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/781694/Noisy+mini+bionaire+oscillating+fan</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/781694</guid>
<pubDate>Tue, 18 Apr 2023 16:10:57 -0700</pubDate>
</item>
<item>
<title><![CDATA[Aloha Breeze Tower Fan: Why the motor wont turn and fan will not come on.]]></title>
<description><![CDATA[<p>When i plug in my Aloha Breeze tower fan nothing happens</p>
<p>⟐ Edited diciembre 21, 2023 at 16:57 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/89397/Why+the+motor+wont+turn+and+fan+will+not+come+on.</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/89397</guid>
<pubDate>Thu, 21 Dec 2023 16:57:07 -0700</pubDate>
</item>
<item>
<title><![CDATA[Holmes tower fan: How to put this back together again?]]></title>
<description><![CDATA[<p>I bought this at a rummage sale for $8 and I was trying to take the front part off to clean it out and the base fell out. What happened was all of these parts fell out and I have tried to put it together several times. Can someone walk me through and show me how to put this together again or this is food for the trash can?  It came with no instruction manual and I looked up the manual on the internet and it shows me nothing on how to put this back together again. It’s a Holmes Oscillating Tower Fan 32 Inch with Remote Control, HT38R-U. I have included pictures. Thank you.</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/3fRgFdR3qTPvq5WU.standard" width="127" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/3fRgFdR3qTPvq5WU.huge&quot;, '', 'width=675,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/tBT61gQ4Yta6XVaL.standard" width="127" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/tBT61gQ4Yta6XVaL.huge&quot;, '', 'width=675,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/bOajUMI1oItVLH66.standard" width="127" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/bOajUMI1oItVLH66.huge&quot;, '', 'width=675,height=1200')" /></div>
<p>⟐ Answered abril 26, 2021 at 8:43 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/689856/How+to+put+this+back+together+again</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/689856</guid>
<pubDate>Mon, 26 Apr 2021 08:43:38 -0700</pubDate>
</item>
<item>
<title><![CDATA[Honeywell HY-204: The rotation switch is on but the fan won't rotate--solutions?]]></title>
<description><![CDATA[<p>When I turn the fan on and have the rotation switch on as well the fan won't rotate.</p>
<p>The fan will not rotate even though both the rotation and fan switches are on.</p>
<p>⟐ Commented abril 25, 2021 at 14:24 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/198410/The+rotation+switch+is+on+but+the+fan+won&#039;t+rotate--solutions</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/198410</guid>
<pubDate>Sun, 25 Apr 2021 14:24:25 -0700</pubDate>
</item>
</channel>
</rss>
