<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Samsung WF361BVBEWR Washing Machine&quot;]]></title>
<link>https://ts.ifixit.com/Answers/Device/Samsung_WF361BVBEWR_Washing_Machine/All?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Samsung WF361BVBEWR Washing Machine&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Tue, 08 Sep 2026 15:11:39 -0700</pubDate>
<item>
<title><![CDATA[Samsung WF361BVBEWR Washing Machine: Why is my machine leaking when the washer is filling?]]></title>
<description><![CDATA[<p>My washer is leaking water when it fills at the beginning of the cycle and when it fills to rinse. It’s a steady stream of water when this happens. It’s leaking on the front, middle, underside of the machine. I’ve drained the emergency drain and it’s plugged correctly. I get a lot out of there, I try to drain that every few days. But tonight I was able to see the leak in action, and I was consistent with filling, not draining. Any suggestions??</p>
<p>⟐ Answer accepted Ocak 22, 2026 at 12:06 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/789325/Why+is+my+machine+leaking+when+the+washer+is+filling</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/789325</guid>
<pubDate>Thu, 22 Jan 2026 12:06:45 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung WF361BVBEWR Washing Machine: چرا لباسشویی به خشک کن نمیره؟]]></title>
<description><![CDATA[<p>چرا لباسشویی ما بعد حالت آبکشی به خشک کن نمی رود</p>
<p>Translation:</p>
<p>Why doesn't our laundry go to the dryer?</p>
<p>Why doesn't our laundry go to the dryer after rinse mode</p>
<p>⟐ Edited Nisan 10, 2023 at 13:55 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/779292/%DA%86%D8%B1%D8%A7+%D9%84%D8%A8%D8%A7%D8%B3%D8%B4%D9%88%DB%8C%DB%8C+%D8%A8%D9%87+%D8%AE%D8%B4%DA%A9+%DA%A9%D9%86+%D9%86%D9%85%DB%8C%D8%B1%D9%87%D8%9F</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/779292</guid>
<pubDate>Mon, 10 Apr 2023 13:55:24 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung WF361BVBEWR Washing Machine: Spins, rinses but will not wash.]]></title>
<description><![CDATA[<p>I have samsung front load washer when put in any washing cycle it does wash my clothes . It will fill with water spins rinse but not washing. It just sits still little going back and forth but then acts like its stuck. I did run diagnostic test and came back with no error codes. Please advise. Thank you 🙏</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/756975/Spins,+rinses+but+will+not+wash.</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/756975</guid>
<pubDate>Thu, 24 Nov 2022 10:59:48 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung WF361BVBEWR Washing Machine: Why does the machine fill up above normal level and then give a nf err]]></title>
<description><![CDATA[<p>The machine fills up fast and above ordinary level and still it wont goto next cycle and drain, displaying a nf error which stands for a water filling failure… it does fill. Even over fill. I even have leaks due to water level. I have to power off the machine and force the spinning cycle for the water to drain.</p>
<p>When i go into forced spin cycle, the water drains easily but the cycle seems stuck. I have to stop the machine, shut down, power on again and go into the forced spin cycle again, for it to work and complete.</p>
<p>can someone help?</p>
<p>⟐ Commented Ekim 20, 2022 at 23:13 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/523919/Why+does+the+machine+fill+up+above+normal+level+and+then+give+a+nf+err</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/523919</guid>
<pubDate>Thu, 20 Oct 2022 23:13:25 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung WF361BVBEWR Washing Machine: Front load washer spins and rinses but won't wash!]]></title>
<description><![CDATA[<p>My Samsung front load washer gets stuck right after it initially fills with water. The normal cycle is 1:09 and at 1:07 it stops and starts humming. The humming sounds like its trying to pull water in, but I could be wrong about that. I replaced the water inlet valve, but I don't think that was ever the issue because the Rinse &amp; Spin cycle works just fine, as does the Spin Only cycle. The quick wash cycle, just like the normal cycle, will not work.</p>
<p>⟐ Commented Ocak 04, 2022 at 21:56 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/717285/Front+load+washer+spins+and+rinses+but+won&#039;t+wash!</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/717285</guid>
<pubDate>Tue, 04 Jan 2022 21:56:40 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung WF361BVBEWR Washing Machine: How to unlock washer door]]></title>
<description><![CDATA[<p>My washing machine samsung WF361 door would not unlock. There was 11 minutes remain in the cycle when it stopped , it has no water all drained. I Turn power off the wall and still locked. How can I open it and get the clothes out?</p>
<p>⟐ Commented Aralık 20, 2020 at 13:37 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/253464/How+to+unlock+washer+door</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/253464</guid>
<pubDate>Sun, 20 Dec 2020 13:37:00 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung WF361BVBEWR Washing Machine: Ae6 code fixed now have 3e1 code]]></title>
<description><![CDATA[<p>Last week my washer started to smoke. Got the error code Ae6. I ordered the new control board and got it installed today. Washer started fine but the paused when it got to the spin cycle. I now have the 3e1 error code. I checked all the wires and plugs and everything looks good. Could the new part be defective? This washer is only 13 months old…</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/644611/Ae6+code+fixed+now+have+3e1+code</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/644611</guid>
<pubDate>Mon, 06 Jul 2020 19:48:40 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung WF361BVBEWR Washing Machine: Washer won't drain after wash cycle but drains on all other cycles]]></title>
<description><![CDATA[<p>Washer stops after wash cycle with &quot;not draining&quot; error. I drain manually and continue and the wash completes from that point with no issues. Already unplugged it for a minute.   Not my exact model above but close.</p>
<p>Update:  Now some cycles drain while others don't.</p>
<p>⟐ Answered Ocak 03, 2019 at 0:54 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/489268/Washer+won&#039;t+drain+after+wash+cycle+but+drains+on+all+other+cycles</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/489268</guid>
<pubDate>Thu, 03 Jan 2019 00:54:32 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung WF361BVBEWR Washing Machine: Lights are on just won’t start]]></title>
<description><![CDATA[<p>My daughter open my dryer Samsung door while was on and now it won’t start</p>
<p>⟐ Answered Ağustos 18, 2018 at 19:23 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/506220/Lights+are+on+just+won%E2%80%99t+start</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/506220</guid>
<pubDate>Sat, 18 Aug 2018 19:23:12 -0700</pubDate>
</item>
<item>
<title><![CDATA[Samsung WF361BVBEWR Washing Machine: Why is my washer making loud noise?]]></title>
<description><![CDATA[<p>Why does my washer make a loud noise, shake just before it starts spinning? Once it starts spinning it stops and is fine</p>
<p>⟐ Commented Mayıs 28, 2018 at 8:51 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/489031/Why+is+my+washer+making+loud+noise</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/489031</guid>
<pubDate>Mon, 28 May 2018 08:51:41 -0700</pubDate>
</item>
</channel>
</rss>
