<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Razer Blade Pro 17 2020&quot;]]></title>
<link>https://ts.ifixit.com/Answers/Device/Razer_Blade_Pro_17_2020?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Razer Blade Pro 17 2020&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Sun, 24 May 2026 03:29:10 -0700</pubDate>
<item>
<title><![CDATA[Razer Blade Pro 17 2020: Damaged board, screen and keyboard]]></title>
<description><![CDATA[<p>Hello!</p>
<p>My blade 17 (<strong>RZ09-0329</strong>) has been through some stuff over the years and the broken screen has now put the final nail in the coffin. I am based in the UK and have located a screen seller on ebay, but it did not work and just shows some pink lines (of which I will get a picture of the next time I have it). The keyboard has a few broken keys and missing keycaps so I am wondering if I should get a new unit (~100GBP) or fix it myself. The last any possibly most crucial part is on the board. I have noticed that a very small fuse or resistor has been chipped off on the board near the power connector. There are no scorch marks so I am guessing it was me who knocked it off when I took the keyboard out. I have attached an image of it.</p>
<p><strong>Here are my questions:</strong></p>
<ul><li>Is there any good repair shop based in the UK which can repair the board component?</li><li>Is there a cheaper alternative to getting a new keyboard unit?</li><li>Has anyone found schematics for razer laptops of know if razer publishes them?</li><li>Is there another option for me to get my screen fixed other than going back and forth with a seller testing screens and eDP cables?</li></ul>
<p>Thanks for your time and all the best!</p>
<p><strong>The board image (<em>red arrow in the upper left points to the component</em>):</strong></p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/5eKlTCUVeLyCtCYr.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/5eKlTCUVeLyCtCYr.huge&quot;, '', 'width=900,height=1200')" /></div>]]></description>
<link>https://ts.ifixit.com/Answers/View/916851/Damaged+board,+screen+and+keyboard</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/916851</guid>
<pubDate>Fri, 12 Sep 2025 05:45:17 -0700</pubDate>
</item>
<item>
<title><![CDATA[Razer Blade Pro 17 2020: Razer Blade Pro 17 (2020) – Battery Issue and Powering Without Battery]]></title>
<description><![CDATA[<p>Hi everyone,</p>
<p>I have a Razer Blade Pro 17&quot; (2020), model RZ09-0329x and recently the battery swelled up. Now the laptop won’t power on at all, even when I connect it to the original AC adapter.</p>
<p>I couldn't find a replacement battery anywhere, and since I urgently need to use the laptop, I tried disconnecting the battery connector completely to see if it would run just on AC power. But unfortunately, that didn’t work — it still won’t turn on.</p>
<p>While inspecting the inside, I noticed a small circuit board between the two battery cells, near the bottom cooling fans. It seems to be a Battery Management System (BMS) board.</p>
<p>So my main questions are:</p>
<p>- Is this BMS board required for the laptop to boot even when the battery is removed?</p>
<p>- Is there any safe way to bypass it or trick the system into running directly off the adapter?</p>
<p>- Has anyone here successfully powered this model without a battery? Any tips or schematics would be a huge help.</p>
<p>Thanks in advance for any help or suggestions!</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/907195/Razer+Blade+Pro+17+(2020)+%E2%80%93+Battery+Issue+and+Powering+Without+Battery</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/907195</guid>
<pubDate>Sun, 13 Jul 2025 01:25:32 -0700</pubDate>
</item>
</channel>
</rss>
