<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Portable Air Conditioners&quot;]]></title>
<link>https://ts.ifixit.com/Answers/Device/Portable_Air_Conditioners?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Portable Air Conditioners&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Fri, 05 Jun 2026 00:40:10 -0700</pubDate>
<item>
<title><![CDATA[Delonghi portable upright air conditioner: I can not disassemble my ac portable unit delonghi pinguino.]]></title>
<description><![CDATA[<p>All screws are out. But I'm stuck on the part right after screws are out. Nothing is moving nor opening. It's standing as if I didn't unscrew anything. I can't take the top board off because I'm afraid I'll damage wires.</p>
<p>⟐ Answered 八月 12, 2025 at 12:00 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/909438/I+can+not+disassemble+my+ac+portable+unit+delonghi+pinguino.</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/909438</guid>
<pubDate>Tue, 12 Aug 2025 12:00:29 -0700</pubDate>
</item>
<item>
<title><![CDATA[Delonghi portable upright air conditioner: Why won't the fan blow on my portable air conditioner?]]></title>
<description><![CDATA[<p>IT seems like Everything is working on my portable air conditioner but the fan will not turn on</p>
<p>⟐ Answered 五月 25, 2026 at 21:29 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/815985/Why+won&#039;t+the+fan+blow+on+my+portable+air+conditioner</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/815985</guid>
<pubDate>Mon, 25 May 2026 21:29:17 -0700</pubDate>
</item>
<item>
<title><![CDATA[Portable Air Conditioners: How to Disassemble Sharp Air Cooler PJ-A200TV-B? Pump Replacement]]></title>
<description><![CDATA[<p>I own a <strong>Sharp air cooler (PJ-A200TV-B)</strong> and the water pump has failed, most likely due to our Malaysian water quality causing mineral buildup over time. The fan still works fine, but without the pump circulating water, it’s basically just blowing normal air.</p>
<p>I’ve removed every screw I can find on the unit, including the obvious ones at the back and bottom, but I still can’t fully dismantle it. It honestly feels like this thing was designed never to be opened. I don’t want to force it and risk cracking the plastic clips or damaging the casing.</p>
<p>Another reason I need to take it apart is to properly clean the internal fan, as there’s quite a bit of dust buildup inside. I can only clean the exterior and filters, but the fan blades themselves are hard to reach without opening the unit.</p>
<p>I’ve searched online for a teardown guide or tutorial video but couldn’t find anything specific to this model. I did find a Facebook post from someone who replaced the pump before, but he hasn’t responded to my message. Maybe he’s no longer active.</p>
<p>I’ve already sourced a compatible replacement pump from Shopee, so I’m ready to fix it myself. I just need guidance on how to properly open the unit and access the pump without breaking anything.</p>
<p>If anyone here owns the same model or has experience taking apart Sharp air coolers, I’d really appreciate any advice, photos, or step-by-step tips. Thanks in advance.</p>
<p>⟐ Edited 三月 04, 2026 at 19:03 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/943262/How+to+Disassemble+Sharp+Air+Cooler+PJ-A200TV-B+Pump+Replacement</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/943262</guid>
<pubDate>Wed, 04 Mar 2026 19:03:48 -0700</pubDate>
</item>
<item>
<title><![CDATA[usb mini climatiseur mobile: Blue light turns on and off then doesn't work]]></title>
<description><![CDATA[<p>When connected to the cable, a blue light comes on and then disappears and nothing works. I checked the fan and found that it is rotating and working. I do not know what the problem is.</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/914287/Blue+light+turns+on+and+off+then+doesn&#039;t+work</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/914287</guid>
<pubDate>Thu, 28 Aug 2025 06:23:50 -0700</pubDate>
</item>
<item>
<title><![CDATA[Portable Air Conditioners: Why does it leak water out of the bottom?]]></title>
<description><![CDATA[<p>Haier portable air conditioner</p>
<p>No water comes out of the drain but leaks around the bottom seams.</p>
<p>⟐ Commented 六月 23, 2024 at 18:33 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/856232/Why+does+it+leak+water+out+of+the+bottom</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/856232</guid>
<pubDate>Sun, 23 Jun 2024 18:33:14 -0700</pubDate>
</item>
<item>
<title><![CDATA[Portable Air Conditioners: No cool air from the unit!]]></title>
<description><![CDATA[<p>Hi,</p>
<p>I bought a new GE portable air conditioner from Amazon! Hardly used over 4 months (only two summers). Now everything works well except no cooling. The filter is still clean and looks brand new.</p>
<p>Help me to fix, if I need to add coolant or fix any leaks.</p>
<p>Thanks</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/855483/No+cool+air+from+the+unit!</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/855483</guid>
<pubDate>Wed, 19 Jun 2024 05:23:37 -0700</pubDate>
</item>
</channel>
</rss>
