<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Microsoft Surface Pro 5&quot;]]></title>
<link>https://ts.ifixit.com/Answers/Device/Microsoft_Surface_Pro_5/All?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Microsoft Surface Pro 5&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Wed, 08 Jul 2026 02:09:44 -0700</pubDate>
<item>
<title><![CDATA[Microsoft Surface Pro 5: touchscreen stopped working after I connected a Bluetooth keyboard.]]></title>
<description><![CDATA[<p>Hi. I have a Microsoft Surface Pro 2017 (Model 1796). My touchscreen stopped working after I connected a Bluetooth keyboard. The keyboard worked, but the touchscreen stopped responding. There was no drop or water damage.</p>
<p>In Device Manager, “Surface Tcon Device” shows a yellow warning sign with Code 10 – This device cannot start. I tried uninstalling/reinstalling drivers, restarting, and Windows updates, but nothing fixed it.</p>
<p>Could a Bluetooth keyboard connection cause a driver/firmware issue, or is this likely a hardware problem?</p>
<p>⟐ Commented May 17, 2026 at 7:27 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/955488/touchscreen+stopped+working+after+I+connected+a+Bluetooth+keyboard.</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/955488</guid>
<pubDate>Sun, 17 May 2026 07:27:02 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 5: Surface Tcon Device cannot start (STATUS_DEVICE_POWER_FAILURE)]]></title>
<description><![CDATA[<p>Replaced battery and screen on Surface Pro 5. After reassembling I powered on the device and started up ok, but a portion of the screen wasn’t responding. to touch. I shut it down and disassembled to check my connections but when I did I removed one of the connectors improperly. This damaged the pins slightly. I was able to gently bend them into place and when I pushed the ribbon cable into it seemed to connect in just fine. Removing the ribbon cable and inspecting the pins again looks ok to my eyes, but when I power on the device there is no backlight, the microsoft logo flashes a couple times and the display goes black. Connecting to a external display shows the device powered on just fine. I’ve checked all my other connections and they seemed fine. I’m stuck looking at the connector I damaged but it too looks like it should be working still. Anyone have a schematic or can at least tell me which ribbon cable provides power (left or right) to the display.</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/sVAUe6GonBMqEkQU.standard" width="282" height="211" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/sVAUe6GonBMqEkQU.full&quot;, '', 'width=640,height=480')" /></div>
<p>⟐ Answered May 17, 2026 at 0:55 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/677687/Surface+Tcon+Device+cannot+start+(STATUS_DEVICE_POWER_FAILURE)</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/677687</guid>
<pubDate>Sun, 17 May 2026 00:55:13 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 5: Do I need to change wifi antenna assembly?]]></title>
<description><![CDATA[<p>I replaced the battery and while opening up the screen, I tore off the wifi antennas from its assembly. However, the wifi still works after putting it back together.</p>
<p>The one thing I am confused about is, on this model, the antenna do not connect to anything on the motherboard, or am I mistaken?</p>
<p>There is a little metal piece on the bottom of the assembly (3rd pic) which connects to the motherboard but that piece does not attach to the antenna whatsoever.</p>
<p>I have attached some photos of what the antennas and the assembly look like in my case.</p>
<p>Thank You in Advance!</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/2wYRWLnToPdEQsYu.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/2wYRWLnToPdEQsYu.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/2D6t6Ik2QOiK1LAw.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/2D6t6Ik2QOiK1LAw.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/TIcJs5ciOUVTBa6G.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/TIcJs5ciOUVTBa6G.huge&quot;, '', 'width=900,height=1200')" /></div>
<p>⟐ Commented April 26, 2026 at 11:24 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/735358/Do+I+need+to+change+wifi+antenna+assembly</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/735358</guid>
<pubDate>Sun, 26 Apr 2026 11:24:25 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 5: Surface Pro 5 3rd touch failure. Screen replacement didn't fix the los]]></title>
<description><![CDATA[<p>Hello everyone!</p>
<p>I am so lost and really don't know what to do anymore. My customers Surface Pro 5 has lost it's touch function after a windows 10 update. Also there is no touch input within the UEFI bios.</p>
<p>Since I am a technician, I installed a known good tester display with new cables and a working touch board. Nothing.</p>
<p>Got a new display from AliExpress with a new touch controller, it worked until the first reboot. Aaaaand it's gone.</p>
<p>I did check the AliExpress display on a tester surface pro 5 and it worked prior to installing it on my customers device.</p>
<p>After I installed it on my customers SP5 it no longer worked.</p>
<p>I feel like this surface pro 5 has a habit of frying display touch controllers. Checked the board for any heat spots or water damage but there is nothing.</p>
<p>All the voltages are fine and no capacitors or resistors are bad.</p>
<p>So what the hell is going on here? Do you guys have any idea what the issue could be?</p>
<p>Reinstalled everything as well btw and tried win 11 with no luck.</p>
<p>Had a similar issue with my personal Surface Pro 5 and had to replace the motherboard.</p>
<p>This is how ever a 1TB i7 board and it would a shame to trash it.</p>
<p>Best regards</p>
<p>⟐ Commented November 30, 2025 at 14:33 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/839495/Surface+Pro+5+3rd+touch+failure.+Screen+replacement+didn&#039;t+fix+the+los</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/839495</guid>
<pubDate>Sun, 30 Nov 2025 14:33:44 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 5: Screen bugged after battery replacement]]></title>
<description><![CDATA[<p>Hello,</p>
<p>I have replaced the battery on my Surface pro 5, and the screen displays a white line upon turning on.<br /></p>
<p>I tried reseating the ribbon  cables etc, but no luck, did I brick the screen on disassembly</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/5rtOOANTHmiZpWZf.standard" width="102" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/5rtOOANTHmiZpWZf.full&quot;, '', 'width=613,height=1362')" /></div>
<p>or worst the table itself?</p>
<p>Thanks for the answers!</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/906002/Screen+bugged+after+battery+replacement</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/906002</guid>
<pubDate>Thu, 03 Jul 2025 09:06:58 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 5: What is the name of the Pinset for the motherboard?]]></title>
<description><![CDATA[<p>I have a Surface Pro 5 that is not powering on and i have extracted the motherboard. I would like to know the pinset for the power to the motherboard so i can connect a DC Power Supply.</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/882867/What+is+the+name+of+the+Pinset+for+the+motherboard</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/882867</guid>
<pubDate>Tue, 07 Jan 2025 10:43:35 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 5: EMI shield for Surface Pro 5 display connector]]></title>
<description><![CDATA[<p>Hi,</p>
<p>I purchased Surface pro 5 display and converter cable to my Surface Pro 4 tablet.</p>
<p>Everything works well and I haven`t glued screen yet because I`ve doubts that if connector in screen stays there without EMI shield.</p>
<p>Anybody know where I can get EMI shield for connector in screen ?  Shield that is in Pro 4 display is too short for connector in never screen model.</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/841701/EMI+shield+for+Surface+Pro+5+display+connector</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/841701</guid>
<pubDate>Thu, 21 Mar 2024 02:49:28 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 5: Pro 5 1796 not detecting new battery.]]></title>
<description><![CDATA[<p>Hello all, I recently replaced the battery in my Surface Pro 5 1796, and upon powering it back on, Windows shows no battery present in the tablet. There is no battery icon in the taskbar, no battery settings in the Settings app, and upon checking device manager, it says that the Surface Battery is not installed in the computer.</p>
<p>Despite this, the battery is still sending power out to the system. I can unplug and use the device just fine, but when the battery dies, it immediately shuts off. No low battery warning, sleep state, or low battery icon from the UEFI when you try to power it up. Just a black screen.</p>
<p>This tells me that the battery is seated correctly in its spot, but something within the software is messing it up. I've tried reinstalling drivers, doing windows update, and performing a Surface Diagnostics Test, but to no avail. I have yet to try a full re installation of Windows.</p>
<p>If someone has any tips or solutions to this, please let me know. Thanks.</p>
<p>⟐ Answered December 14, 2023 at 11:16 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/745812/Pro+5+1796+not+detecting+new+battery.</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/745812</guid>
<pubDate>Thu, 14 Dec 2023 11:16:38 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 5: Red screen after change display]]></title>
<description><![CDATA[<p>Hello, I accidentally broke the screeen on my surface, so I went to a local repair point to have a professional repair of my PC. All good but after a month the screen has started to have some red flash as you can see in the video. So I returned to the repair point and he tried to repair but he said that is not the display but is the graphic card broken, so I can't do nothing. Do you agree with him or is a problem of compatibility/ display broken?</p>
<p>I tried also to connect to a external screen via HDMI and there isn't any red flash</p>
<p>Thank you</p>
<div class="large videoFrame videoBox_center" style="width:452px"><div class="videoBox"><video id="yR2N3FUYe5UTeuen" controls width="448"   height="252"   poster="https://guide-images.cdn.ifixit.com/igi/JxBAV5nxx466URBA.large" loop   >  <source src="https://documents.cdn.ifixit.com/igo/video/ifixit/yR2N3FUYe5UTeuen_MP4_720.mp4" type='video/mp4; codecs="avc1.4D4029, mp4a.40.2"' res="720" label="480p" /> </video></div></div>
<p>⟐ Commented October 22, 2023 at 9:34 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/818656/Red+screen+after+change+display</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/818656</guid>
<pubDate>Sun, 22 Oct 2023 09:34:54 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 5: Can the digitizer cable in the display be repaired/replaced?]]></title>
<description><![CDATA[<p>When opening the computer to replace the battery, I ended up damaging the digitizer cable on the LCD screen. Any way this can be fixed or replaced?</p>
<p>Screen works perfectly, lost the touch screen functionality though :(</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/pLnSKcgQcCevAZVO.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/pLnSKcgQcCevAZVO.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/56uPlQGsVCrLbxYT.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/56uPlQGsVCrLbxYT.huge&quot;, '', 'width=900,height=1200')" /></div>
<p>⟐ Commented October 16, 2023 at 18:05 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/819581/Can+the+digitizer+cable+in+the+display+be+repaired-replaced</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/819581</guid>
<pubDate>Mon, 16 Oct 2023 18:05:46 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 5: Cannot turn it on]]></title>
<description><![CDATA[<p>It was working perfectly but needed to be charged, charged overnight, LED on charging cable on.  Next day opened and pressed power button and only display was black screen with large white empty battery icon in the center.  Does it need to have its battery replaced?  If that is not the problem, what is?</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/815137/Cannot+turn+it+on</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/815137</guid>
<pubDate>Thu, 21 Sep 2023 17:41:48 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 5: I would like to know the location of bios chip]]></title>
<description><![CDATA[<p>Hi</p>
<p>I would like to know the location of Bios chip of Microsoft surfce pro 5 model number 1796</p>
<p>Thanks</p>
<p>⟐ Commented July 29, 2023 at 12:15 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/528640/I+would+like+to+know+the+location+of+bios+chip</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/528640</guid>
<pubDate>Sat, 29 Jul 2023 12:15:50 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 5: Any shop to buy original or at least a good battery for Surface 5 Pro?]]></title>
<description><![CDATA[<p>Hi, I am desparate. I am sending a 5th battery back because it wasn't the original one or wasn't even a brand I needed. The only original one was a discounted one 3-4 years old, which had to be discharged already.</p>
<p>I am looking for a battery of a good brand, similiar to the OEMs., as the original ones are not available anymore. Is the one listed here on this site a good one? Or do you know any shop or other brand closer to the original's battery quality?</p>
<p>Thanks for any response.</p>
<p>⟐ Answered July 26, 2023 at 9:20 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/803787/Any+shop+to+buy+original+or+at+least+a+good+battery+for+Surface+5+Pro</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/803787</guid>
<pubDate>Wed, 26 Jul 2023 09:20:35 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 5: Broken ZIF Connector for Power/Volume Controls on Surface Pro Series 5]]></title>
<description><![CDATA[<p>When replacing the battery (which was an effort and a half but managed to do it without breaking the screen!) I ended up breaking the ZIF connector that interfaces the Power and Volume Control buttons from the case.</p>
<p>Does anyone know the part I could order to replace this? Also, is this something someone with a decent soldering iron can fix or is it more complicated than that?</p>
<p>Working Connector (Open)</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/DqUsScPVtLEyNfjE.standard" width="282" height="211" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/DqUsScPVtLEyNfjE.huge&quot;, '', 'width=1600,height=1200')" /></div>
<p>Pieces from Broken Connector</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/juJUgYcnfi3CXNOw.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/juJUgYcnfi3CXNOw.huge&quot;, '', 'width=901,height=1200')" /></div>
<p>Piece with an Identifying Mark (712)</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/JmLynORFqTv2BXUG.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/JmLynORFqTv2BXUG.huge&quot;, '', 'width=901,height=1200')" /></div>
<p>Working Connector (Closed)</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/AQykAbWUgdbQ5Enb.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/AQykAbWUgdbQ5Enb.huge&quot;, '', 'width=901,height=1200')" /></div>
<p>Broken Connector left on Board</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/Ut5JRBTSm4ZlA3jT.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/Ut5JRBTSm4ZlA3jT.huge&quot;, '', 'width=901,height=1200')" /></div>
<p>Ribbon that Connects to the Connector</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/sQZPRijvOPqcEQJu.standard" width="282" height="211" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/sQZPRijvOPqcEQJu.huge&quot;, '', 'width=1600,height=1200')" /></div>
<p>Many thanks.</p>
<p>⟐ Edited by author July 14, 2023 at 21:33 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/801557/Broken+ZIF+Connector+for+Power-Volume+Controls+on+Surface+Pro+Series+5</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/801557</guid>
<pubDate>Fri, 14 Jul 2023 21:33:00 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 5: Replaced Battery, this is what I got..]]></title>
<description><![CDATA[<p>Was wondering what I broke here? I was very careful and it seemed to be okay when I replaced the battery and reassembled it.</p>
<p>The screen is not cracked, but I was wondering if it was a connection issue. However, why would just a strip display like this?</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/Tr52FWU1OFNZ1lGS.standard" width="102" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/Tr52FWU1OFNZ1lGS.huge&quot;, '', 'width=540,height=1200')" /></div>
<p>⟐ Answered July 06, 2023 at 11:36 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/799474/Replaced+Battery,+this+is+what+I+got..</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/799474</guid>
<pubDate>Thu, 06 Jul 2023 11:36:02 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 5: Can I replace a pro 5 lcd with a pro 4 lcd?]]></title>
<description><![CDATA[<p>Can I replace a pro 5 lcd with a pro 4 lcd?</p>
<p>⟐ Commented May 16, 2023 at 8:52 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/465760/Can+I+replace+a+pro+5+lcd+with+a+pro+4+lcd</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/465760</guid>
<pubDate>Tue, 16 May 2023 08:52:43 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 5: power connector port fault]]></title>
<description><![CDATA[<p>hi guys,</p>
<p>i observed that my surface pro 5 charging port is not charging due to physical damage to the port how can i fix it</p>
<p>⟐ Commented February 16, 2023 at 17:46 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/769446/power+connector+port+fault</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/769446</guid>
<pubDate>Thu, 16 Feb 2023 17:46:24 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 5: Heat Gun/Blower for Screen Replacement]]></title>
<description><![CDATA[<p>I am looking at purchasing a heat/gun blower to replace my Surface pro 5 screen (warm the adhesive to weaken it)....as well as for other electronics.</p>
<p>I have come across 3-in-1 Function Heat Blower and Soldering Iron (see link below),  which I thought could be helpful with other projects also.</p>
<p><a href="https://www.jaycar.co.nz/3-in-1-function-heat-blower-and-soldering-iron/p/TH1604" rel="nofollow noopener noreferrer" title="https://www.jaycar.co.nz/3-in-1-function-heat-blower-and-soldering-iron/p/TH1604">https://www.jaycar.co.nz/3-in-1-function...</a></p>
<p>Has anyone had any experience using this type of &quot;heat blower&quot;? First thought is it may be difficult to control the temperature...although it does have a flame adjustment setting.</p>
<p>Thanks in advance for your help.</p>
<p>⟐ Commented January 26, 2023 at 5:49 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/476251/Heat+Gun-Blower+for+Screen+Replacement</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/476251</guid>
<pubDate>Thu, 26 Jan 2023 05:49:29 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 5: Touchscreen only works when touching the case]]></title>
<description><![CDATA[<p>I bought an used SP5 and replaced the screen. All went perfect and no issue seemed to be present. But after using it more, I found a problem with the touch recognition. I can only use my finger to interact while touching the Metall case of the SP5, when laying it on the table (or any other surface) it won't recognize the touch input. I tried every other troubleshooting tip (reinstalling drivers, firmware, resting or setting the calibration etc).</p>
<p>I do have a screen protector on the screen. Might this be the problem? Or do I have to open the device again? Maybe there's some current acting as phantom touch on the whole screen? Magnetic interference? Surface pen works flawless.</p>
<p>⟐ Commented October 12, 2022 at 4:40 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/751141/Touchscreen+only+works+when+touching+the+case</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/751141</guid>
<pubDate>Wed, 12 Oct 2022 04:40:06 -0700</pubDate>
</item>
<item>
<title><![CDATA[Microsoft Surface Pro 5: won't run on battery]]></title>
<description><![CDATA[<p>When it's plugged in it works just fine but if it gets unplugged it automatically shuts off and even when it's plugged in it will never show battery charging or get over like 6% battery life Do I just need new batteries or where should I start</p>
<p>⟐ Answer accepted September 17, 2022 at 21:20 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/639808/won&#039;t+run+on+battery</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/639808</guid>
<pubDate>Sat, 17 Sep 2022 21:20:34 -0700</pubDate>
</item>
</channel>
</rss>
