<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;MacBook Pro 15&quot;&quot;]]></title>
<link>https://ts.ifixit.com/Answers/Device/MacBook_Pro_15%22/All?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;MacBook Pro 15&quot;&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Thu, 28 May 2026 03:24:15 -0700</pubDate>
<item>
<title><![CDATA[MacBook Pro 15" Touch Bar 2019: Battery board data cable shorted out after replacing battery.]]></title>
<description><![CDATA[<p>I have now replaced the battery on this Macbook pro twice. After the first I charged it fully and it powered on for about 10-15 seconds and then lost all power. I opened it back up and found the battery board data cable shorted out between the 2 far left connectors. Ifixit sent me a replacement battery and I ordered a new battery board data cable and replaced yesterday. I charged it fully and powered it on and thought I had success as it was booting up and had been running for over a minute when all power went away and everything died again. I just opened it back up to find a  short &quot;hot spot&quot; in the battery board data cable in the exact same place. Does somebody know where I should look next for what is causing this issues?</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/RQHr3QyM3kyiX3SK.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/RQHr3QyM3kyiX3SK.full&quot;, '', 'width=960,height=1280')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/ZcX2fqICElRSGGCc.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/ZcX2fqICElRSGGCc.full&quot;, '', 'width=1512,height=2016')" /></div>
<p>⟐ Answered mei 26, 2026 at 14:35 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/956858/Battery+board+data+cable+shorted+out+after+replacing+battery.</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/956858</guid>
<pubDate>Tue, 26 May 2026 14:35:09 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 15" Retina Display Mid 2012: Failing GPU: alternative to reflowing?]]></title>
<description><![CDATA[<p>The GPU on my MacBook Pro is starting to fail every so often, leaving it with a black screen and no external graphics when plugged into an external monitor. I’ve got two repair shop opinions saying it’s the GPU failing. Because it also works just fine every once and a while, I think a simple reflow will fix the issue.</p>
<p>But here is the question: without microsolder experience/ability, is there something else I can do than pay $200+ for a reflow job? For example, one microsolder tech recommended that I pop the logic board (all by itself, disassembled from the laptop) in an oven at 450 degrees for 5 minutes. If that’s safe to do, I’d much prefer that to a $200 repair, as long as I don’t risk destroying the whole thing.</p>
<p>You microsolder wizards out there, what would you recommend? Or where would you recommend that can do the repair for cheap? I’ve already replaced the laptop, so now I’m just repairing to resell.</p>
<p>Thanks in advance.</p>
<p>⟐ Commented mei 22, 2026 at 8:20 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/613469/Failing+GPU:+alternative+to+reflowing</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/613469</guid>
<pubDate>Fri, 22 May 2026 08:20:52 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 15" Touch Bar 2018: Touchbar stopped working and a fuse burned?]]></title>
<description><![CDATA[<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/DjbGr2IXbbEwhGac.standard" width="282" height="211" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/DjbGr2IXbbEwhGac.huge&quot;, '', 'width=1600,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/64ciJYpMOKRbEvAw.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/64ciJYpMOKRbEvAw.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/Q1tYbaUKcBG4WjPF.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/Q1tYbaUKcBG4WjPF.huge&quot;, '', 'width=900,height=1200')" /></div>
<p>I am an amateur so bear with me. I started trying to repair this Macbook Pro some time ago. Its my own.</p>
<p>Today I disconnected and connected the motherboard due to some work in the power button / touch id (There is another post related to this.</p>
<p>So, that is a short summary and what happened now is that when I reassembled the computer and turned it on I notices that the touch bar was not showing anything so I turned off the computer and looked inside to have a look at a connector on a cable that I messed up a year ago (Sadly I was not as careful back..). While examining the cable and connector and touching it I noticed some smoke(?).. I thought that I imagined it.. Then I see sparks and a tiny fire! I rush to disconnect the cable from the connector and disconnect the battery..</p>
<p>Here I am now, with two questions:</p>
<ol><li>Where does the touch bar get its power from? I cant figure it out by myself.</li><li>What is this connector that I messed up used for and did I burn a fuse on the MB? How should I proceed?</li></ol>
<p>⟐ Commented mei 18, 2026 at 14:19 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/805668/Touchbar+stopped+working+and+a+fuse+burned</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/805668</guid>
<pubDate>Mon, 18 May 2026 14:19:38 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 15" Touch Bar 2018: Need help diagnosing display issues]]></title>
<description><![CDATA[<p>My 2018 MacBook Pro display is shpwing flickering green and red lines, and occaionally blacks out or has a block pattern.  I cannot locate any cracks in the screen, and the laptop has not been dropped since I have owned it. Graphics display perfectly when using Airplay to cast to my TV. Does this seem to indicate a display cable issue, or should I be looking at replacing the screen? Thanks in advance for the help.</p>
<p>⟐ Answer edited mei 17, 2026 at 12:21 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/855681/Need+help+diagnosing+display+issues</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/855681</guid>
<pubDate>Sun, 17 May 2026 12:21:28 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 15" Touch Bar 2017: MacBook not turning on after screen flex cable repair failed]]></title>
<description><![CDATA[<p>First of all sorry for my bad English (bc I'm korean)</p>
<p>Recently I bought a1707 macbook with screen flex cable problem and bios locked</p>
<p>I thought I could fix it but I failed (the flex cable is cutted) plus I tried to fix bios with ch341 but I guess this failed too (ic not responding error)</p>
<p>But after reassemble macbook it's not turning on</p>
<p>Did this repair while battery cable is unplugged so think is not shorted</p>
<p>USB meter says 19.6v 10~20w 0.5~1a and no keyboard or track pad respond or light</p>
<p>Plus I assume display will not work bc of cutted flex cable</p>
<p>Tried:smc reset/unplug charger and press power button for 10sec and plug/nvram reset</p>
<p>If have any kind of solution pls tell me</p>
<p>Thank you for reading long text :)</p>
<p>⟐ Answer accepted mei 16, 2026 at 4:58 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/888256/MacBook+not+turning+on+after+screen+flex+cable+repair+failed</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/888256</guid>
<pubDate>Sat, 16 May 2026 04:58:45 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 15" Touch Bar 2019: Microphone Not Working After Touch Bar Repair]]></title>
<description><![CDATA[<p>Hi, I opened my Mac to repair the Touch Bar. After that, when I started it, I discovered that the microphone was not working, even though I reattached all the cables and connectors. Could you help me?</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_05_12_Num_26" class="header">Update (05/12/26)</h3></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/MbIHguXVPxnPTraI.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/MbIHguXVPxnPTraI.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/QNZLAROECGjGxk1a.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/QNZLAROECGjGxk1a.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/xVIopHcrMXYr6WqF.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/xVIopHcrMXYr6WqF.full&quot;, '', 'width=1200,height=1600')" /></div>
<p>⟐ Answer accepted mei 15, 2026 at 17:49 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/954629/Microphone+Not+Working+After+Touch+Bar+Repair</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/954629</guid>
<pubDate>Fri, 15 May 2026 17:49:16 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 15" Touch Bar 2018: Where to find replacement Trackpad washers.]]></title>
<description><![CDATA[<p>Two of the tiny washers located on the mounting posts of the trackpad disappeared when replacing the battery.  How do I replace these washers?</p>
<p>⟐ Answer edited mei 14, 2026 at 6:22 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/954801/Where+to+find+replacement+Trackpad+washers.</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/954801</guid>
<pubDate>Thu, 14 May 2026 06:22:24 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 15" Unibody Mid 2012: New iFixIt battery - Laptop is autobooting when power cord is applied]]></title>
<description><![CDATA[<p>I have a 2012 Macbook Pro A1278 that I replaced the battery with an iFixIt battery. I also replaced the MacOS with Ubuntu Linux 24.04 LTS. After replacing the battery, the laptop now auto starts when the power cord is applied or disconnected. I have reset both firmware and SMC with: CMD, OPT, P, R keys and Left keys plus power button for the SMC, but it still does this. Is there a possibility that the iFixIT battery is bad? Thank you.</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_05_08_Num_26" class="header">Update (05/08/26)</h3></div>
<p>I appreciate the comments here; thank you!  What actually worked:  I downloaded a copy of catalina .dmg and used Balena Etcher on linux to burn it to a thumbdrive and booted the thumb drive by holding the Option button while powering up.  I was then able to launch the terminal from the installer's menu bar.  From the terminal, I was then able to run: nvram AutoBoot=%00   and this disabled that behavior (power on when power cable connected / disconnected).  This command is only available in the MacOS image, so this was the missing step to be able to get access to it. Thank you!</p>
<p>⟐ Edited by author mei 11, 2026 at 7:48 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/953862/New+iFixIt+battery+-+Laptop+is+autobooting+when+power+cord+is+applied</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/953862</guid>
<pubDate>Mon, 11 May 2026 07:48:57 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 15" Retina Display Mid 2015: MBP Anti Glare coating worth removing? Method least likely to damage?]]></title>
<description><![CDATA[<p>I got a MBP here that seems to be affected with the stain gate issue that I've seen around but mine isn't as bad as others I've seen. I'm just wondering if mine is worth removing because on one hand, it's not that bad in dim conditions but really noticeable in daylight. Also, I've seen plenty of horror stories with people ruining their screens with listerine getting underneath the display or breaking the screen with pressure and I'm kinda worried about preforming the AG-coating removal procedure.</p>
<p>Basically, is my Anti-glare coating worth removing and if it is, which method is least likely to cause damage? Also, is image quality affected other than the anti glare properties if I were to remove the coating? Like a loss in color accuracy or something like that.</p>
<p><strong>UPDATE</strong></p>
<p>I used some Kirkland signature baby wipes to remove the layer but it was taking forever. I used Clorox wipes and that seemed to work too. Overall took about 30-45 minutes to remove the majority and about more than an hour to get it all off completely. To make sure it’s completely off use a flashlight and point it at the screen.</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/LLsQI5iyLWfv1NAY.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/LLsQI5iyLWfv1NAY.huge&quot;, '', 'width=900,height=1200')" /></div>
<p>⟐ Commented mei 09, 2026 at 20:09 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/721869/MBP+Anti+Glare+coating+worth+removing+Method+least+likely+to+damage</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/721869</guid>
<pubDate>Sat, 09 May 2026 20:09:19 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 15" Retina Display Mid 2015: Somethings have suddenly gone missing in widgets & settings...]]></title>
<description><![CDATA[<p>I clean installed my Macbook about 8 months ago with OS Monterey 12.7.6 (The last supported OS) and everything has been running fine since then....about 3 days ago  I noticed some things have gone missing from my settings, I have not removed or uninstalled any of them:</p>
<p>The widgets are stored within <code>/System/Library/CoreServices</code>But Notes &amp; Reminders are not there anymore (Maybe some others also have gone).</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/mSFSSYS1qXv6gMTj.standard" width="111" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/mSFSSYS1qXv6gMTj.full&quot;, '', 'width=340,height=694')" /></div>
<p>Unable to set weather location</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/NiLBiCemm1awFyWG.standard" width="258" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/NiLBiCemm1awFyWG.full&quot;, '', 'width=660,height=576')" /></div>
<p>Bluetooth Sharing has gone, but Bluetooth is on as I use a Magic Mouse II without any issues.</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/fMR6KTZFr2W3yoGR.standard" width="280" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/fMR6KTZFr2W3yoGR.full&quot;, '', 'width=1324,height=1064')" /></div>
<p>I also <strong>CANNOT</strong> change 'Open with default app' for example .mp3 or .mp4 opens with either Books, Music, Audacity, QT Player (All are different), even when I change to VLC as it always was with before via various methods <strong>NONE</strong> are changed so they all open with my preferred app. No matter what I try nothing seems to change anything, <strong>GET INFO</strong> (Set Default), <strong>Right Click (Open with other...)</strong> or even with <strong>App Cleaner</strong> app to set default app by extension etc....</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/iSDIbV2qHoc6IpHw.standard" width="209" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/iSDIbV2qHoc6IpHw.full&quot;, '', 'width=486,height=524')" /></div>
<p>This is really bugging me as I do not want to perform a complete clean install as I have a dual boot system and many files. We can rule out using Time Machine as that maybe will not solve it as from experience TM might still bring over the corrupted settings.... Is there a preferences file that I can delete or restore if so which one? Otherwise, system is running fine, these are my only issues noticed so far since a week or so. I have no dodgy software installed, nothing recently installed, no updates have been done (None to do anyway as all is up to date)..... I have booted into safe mode, rebooted as normal, but it has made no difference. Mystified on this as it is something I am usually good at fixing.</p>
<p>I found this link <a href="https://apple.stackexchange.com/questions/296461/path-to-the-folder-where-widgets-are-stored" rel="nofollow noopener noreferrer">about widgets</a> but no joy .</p>
<p>⟐ Answered mei 04, 2026 at 8:41 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/885498/Somethings+have+suddenly+gone+missing+in+widgets+&amp;+settings...</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/885498</guid>
<pubDate>Mon, 04 May 2026 08:41:25 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 15" Retina Display Early 2013: Converting 2013 MacBook Pro to USB trackpad / keyboard]]></title>
<description><![CDATA[<p><strong>TL;DR</strong> - I am attempting to convert a keyboard &amp; trackpad from an early 2013 Macbook Pro retina (a1398) into a standalone usb keyboard &amp; trackpad that can be used with any modern laptop. As someone with minimal soldering and electronics experience, I could use some guidance!</p>
<p><strong>Steps I've taken so far:</strong></p>
<ul><li>Researched to see if this is even possible -- looks like the answer could be 'yes' based on some examples seen around the web</li><li>Tried to find someone I could hire to do this (no luck thus far... hence why I'm here)</li><li>Recently downloaded the a1398 schematics with the 820-3332-A board and fed it into some chatbots to potentially teach me how to do it myself (schematics link: <strong><a href="https://f.ch1p.io/rjHAmTOU/820-3332-a.pdf" rel="nofollow noopener noreferrer" title="https://f.ch1p.io/rjHAmTOU/820-3332-a.pdf" target="_blank">https://f.ch1p.io/rjHAmTOU/820-3332-a.pd...</a></strong>)</li></ul>
<p><strong>Chatbot Summary of Instructions</strong> -&gt; could use help determining if this would work</p>
<p>1. <em>Isolation</em>: Open up the case and remove the R5701 &amp; R5702 resistors -&gt; Ensures the MacBook's PCH doesn't interfere with whatever end computer I connect it with.</p>
<p>2. <em>Data</em>: Solder the Green (D+) and White (D-) wires of the USB cable to the connector side of those R5701 &amp; R5702 resistor pads -&gt; Corresponds to the 'USB_TPAD_P' and 'USB_TPAD_N' connections (Keyboard + trackpad data signals are combined via IPD cable)</p>
<p>3. <em>Power</em>: Solder the Red (5V) wire of the USB cable to the L5700 pad leading to the connector -&gt; this small inductor/ferrite bead provides 5V to the PP5V_S4_TPAD rail via L5700, allowing the trackpad's circuitry to manage internal power needs</p>
<p>4. <em>Ground</em>: Solder the Black wire (GND) to the metal ears or shield of the J5800 connector -&gt; ensures data signals are clean and will be recognized by an external computer</p>
<p><strong>NOTE</strong>: In case you're wondering why I'm doing this...</p>
<p>- I have chronic myofascial pain in my upper extremities. This Macbook Pro model allowed me to go for long periods of time without pain. Having tried dozens of newer laptop models for Mac, Windows, and Chromebook, I have yet to find one with a keyboard/trackpad that performed as well for my pain as the MBP a1398. I could really use some help on how to do this myself.</p>
<p>⟐ Commented mei 03, 2026 at 12:25 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/953155/Converting+2013+MacBook+Pro+to+USB+trackpad+-+keyboard</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/953155</guid>
<pubDate>Sun, 03 May 2026 12:25:36 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 15" Touch Bar 2017: SSD not showing up in Disk Utility]]></title>
<description><![CDATA[<p>I just replaced the battery and now the internal SSD does not show up in Disk Utility when trying to perform and OS upgrade.  It boots fine as is but I cannot upgrade it.</p>
<p>⟐ Commented april 29, 2026 at 18:19 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/952604/SSD+not+showing+up+in+Disk+Utility</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/952604</guid>
<pubDate>Wed, 29 Apr 2026 18:19:35 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 15" Unibody Early 2011: MacBook Pro 2011, I replaced the logic board but can't get it to work]]></title>
<description><![CDATA[<p>Hello</p>
<p>I have a Macbook Pro from early 2011 and I had problems with the video, I took it to a technician to reball it and it supposedly worked, at the same time it failed again and this time they told me they had changed the video chip.</p>
<p>In the end, it failed again and when I took it to repair it again it did not work again.</p>
<p>I finally bought a used logic board in china and was able to successfully install it as a replacement for the deceased one.</p>
<p>But I have the following problems:</p>
<p>1 The battery or battery charger does not work so the fans run at full speed.</p>
<p>2 I was able to get it to boot but it does not recognize the SSD.</p>
<p>3 I put the original hard disk (unfortunately it had been used for a windows pc) and tried to install different versions of OS</p>
<p>- Yosemite USB installation (failure to finish preloading the USB, the computer restarts and the installation begins again)</p>
<p>- Installation via USB of El Capitan (failure to finish preloading the USB similar to Yosemite) but then I was able to install it with &quot;Clover&quot; and the installable image of El Capitan. The installation was successful but when the mac tries to start it reboots before finishing the progress bar with the apple at the start. This installation only works failsafe and I cannot start the diagnostic mode (D, cmd + D, option + D) nor the recovery mode (R, command + R)</p>
<p>- Recovery using time machine, since I have a copy of High Sierra, I recovered the complete installation but the behavior is the same. Fails to start unless in safe mode.</p>
<p>- Currently installing a minor version (mountain Lion) install the first stage, restart and start installing the second stage. it always restarts after 30% and starts again.</p>
<p>4 In the El Capitan version I uninstalled the drivers for the dedicated video card, hoping that was the problem, but I never got it to boot normally.</p>
<p>I also did all the possible updates and only the installation of &quot;MacBook Pro EFI Firmware Update 2.7&quot; fails because when the Mac restarts to do the update, it restarts again and again and only continues in safe mode. when I look for if something needs to be updated, &quot;MacBook Pro EFI Firmware Update 2.7&quot; reappears</p>
<p>Please if you can tell me what steps to follow or some guide would be saving me.</p>
<p>I am in Argentina and the prices to take this equipment to an official service are exorbitant and unreliable.</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_08_31_Num_2021" class="header">Update (08/31/2021)</h3></div>
<p>Hi <a class="user-mention-link notranslate" href="/User/408812/DanJ">@danj</a> , you really blew my mind!</p>
<p>First of all thanks for your help and advice, in my many searches I found many of your contributions and they were always very helpful.</p>
<p>I read quite a bit about it and to try and rule out that this was the problem and did the following:</p>
<p>Using my other computer (macbook pro early 2013) and internet recovery I installed mountain lion on a 16Gb pendrive. I put it in the macbook pro 2011 and by pressing option I told it to boot from it.</p>
<p>To my surprise and for the first time it managed to start!</p>
<p>I even managed to install the update &quot;EFI Firmware Update 2.7&quot; ...</p>
<p>My joy ceased when it rebooted for no reason while trying to install the Safari update. (started downloading update and failed)</p>
<p>The mac rebooted again and while loading the OS it rebooted again! This behavior persists as long as a reboot failure occurs and I think I manage to stop this reboot cycle when I hold the power button and turn on again while pressing the option key to choose usb as startup.</p>
<p>As you had indicated to me that the cable could be the cause of the failure. Disconnect the hard drive cable from the logic board. I started again and it rebooted again :( again trying to update Safari.</p>
<p>Just in case, also disconnect the cable from the optical drive.</p>
<p>With both units disconnected it continues to fail.</p>
<p>Currently, it only has a 16 Gb USB as a hard drive.</p>
<p>Since I couldn't update Safari, I downloaded Chrome and managed to install it.</p>
<p>But as soon as I want to start Chrome and the icon starts jumping on the dock while loading, it restarts again ...</p>
<p>Here's my suspicion: Could this be a matter of memory? Currently, it has two 4Gb memories and before doing all these tests I had changed them for two 2Gb and it also failed.</p>
<p><strong>Update (09/02/2021)</strong></p>
<p>Here it is the report I got booting into safe mode</p>
<p>Anonymous UUID:       FA68BE48-FBB3-5DF7-60AE-31C84802DD15</p>
<p><br /></p>
<p>Mon Jan  1 13:45:58 2001</p>
<p><br /></p>
<ul><li>Panic Report *</li></ul>
<p>panic(cpu 7 caller 0xffffff800578687f): Kernel trap at 0xffffff7f87f37964, type 14=page fault, registers:</p>
<p>CR0: 0x000000008001003b, CR2: 0x0000000000000033, CR3: 0x00000000092ca000, CR4: 0x00000000000626e0</p>
<p>RAX: 0x0000000000000000, RBX: 0xffffff801e685580, RCX: 0x0000000000000202, RDX: 0xffffff80e614b77d</p>
<p>RSP: 0xffffff910ff7a890, RBP: 0xffffff910ff7a8c0, RSI: 0xffffff910ff7a960, RDI: 0xffffff801e685580</p>
<p>R8:  0xffffff910ff7a700, R9:  0x0000000000000008, R10: 0x0000000000000010, R11: 0x0000000000000000</p>
<p>R12: 0xffffff801e685580, R13: 0xffffff7f87fa7658, R14: 0x0000000000000000, R15: 0x0000000000004006</p>
<p>RFL: 0x0000000000010202, RIP: 0xffffff7f87f37964, CS:  0x0000000000000008, SS:  0x0000000000000000</p>
<p>Fault CR2: 0x0000000000000033, Error code: 0x0000000000000000, Fault CPU: 0x7, PL: 0, VF: 1</p>
<p><br /></p>
<p>Backtrace (CPU 7), Frame : Return Address</p>
<p>0xffffff910ff79d10 : 0xffffff800566ae76</p>
<p>0xffffff910ff79d60 : 0xffffff8005794484</p>
<p>0xffffff910ff79da0 : 0xffffff8005786654</p>
<p>0xffffff910ff79e10 : 0xffffff800561ce60</p>
<p>0xffffff910ff79e30 : 0xffffff800566a8ec</p>
<p>0xffffff910ff79f60 : 0xffffff800566a6ac</p>
<p>0xffffff910ff79fc0 : 0xffffff800578687f</p>
<p>0xffffff910ff7a130 : 0xffffff800561ce60</p>
<p>0xffffff910ff7a150 : 0xffffff7f8636f553</p>
<p>0xffffff910ff7a290 : 0xffffff8005cb7ea7</p>
<p>0xffffff910ff7a2e0 : 0xffffff8005cb79b3</p>
<p>0xffffff910ff7a320 : 0xffffff8005cb5662</p>
<p>0xffffff910ff7a360 : 0xffffff800566ad31</p>
<p>0xffffff910ff7a3b0 : 0xffffff8005794484</p>
<p>0xffffff910ff7a3f0 : 0xffffff8005786654</p>
<p>0xffffff910ff7a460 : 0xffffff800561ce60</p>
<p>0xffffff910ff7a480 : 0xffffff800566a8ec</p>
<p>0xffffff910ff7a5b0 : 0xffffff800566a6ac</p>
<p>0xffffff910ff7a610 : 0xffffff800578687f</p>
<p>0xffffff910ff7a780 : 0xffffff800561ce60</p>
<p>0xffffff910ff7a7a0 : 0xffffff7f87f37964</p>
<p>0xffffff910ff7a8c0 : 0xffffff7f87f4f054</p>
<p>0xffffff910ff7a900 : 0xffffff7f87f4edbc</p>
<p>0xffffff910ff7a950 : 0xffffff7f87f4ed03</p>
<p>0xffffff910ff7a9b0 : 0xffffff7f87f4c4b1</p>
<p>0xffffff910ff7a9f0 : 0xffffff7f87f516d8</p>
<p>0xffffff910ff7aa20 : 0xffffff7f87f55d54</p>
<p>0xffffff910ff7aa70 : 0xffffff7f87f76e08</p>
<p>0xffffff910ff7aaf0 : 0xffffff7f87f781ad</p>
<p>0xffffff910ff7ab30 : 0xffffff7f87f78e9e</p>
<p>0xffffff910ff7ab80 : 0xffffff7f87f70360</p>
<p>0xffffff910ff7abc0 : 0xffffff7f87f74ac1</p>
<p>0xffffff910ff7ac20 : 0xffffff7f87f2cf23</p>
<p>0xffffff910ff7acb0 : 0xffffff7f8635ce99</p>
<p>0xffffff910ff7ad00 : 0xffffff7f8635c34c</p>
<p>0xffffff910ff7ad20 : 0xffffff7f87fffa71</p>
<p>0xffffff910ff7ad60 : 0xffffff7f880230b9</p>
<p>0xffffff910ff7bd20 : 0xffffff7f880244b6</p>
<p>0xffffff910ff7bd70 : 0xffffff7f88025f91</p>
<p>0xffffff910ff7be10 : 0xffffff8005c6b2c6</p>
<p>0xffffff910ff7be60 : 0xffffff7f88009240</p>
<p>0xffffff910ff7be90 : 0xffffff7f880093de</p>
<p>0xffffff910ff7beb0 : 0xffffff8005c6e685</p>
<p>0xffffff910ff7bf00 : 0xffffff8005c7135b</p>
<p>0xffffff910ff7bf50 : 0xffffff8005c73076</p>
<p>0xffffff910ff7bfa0 : 0xffffff800561c557</p>
<p>      Kernel Extensions in backtrace:</p>
<p>         com.apple.driver.AppleSMC(3.1.9)[0249444C-80D4-3184-9060-F70DA3BEB17D]@0xffffff7f86364000-&gt;0xffffff7f86380fff</p>
<p>            dependency: com.apple.iokit.IOACPIFamily(1.4)[95DA39BB-7C39-3742-A2E5-86C555E21D67]@0xffffff7f8635b000</p>
<p>            dependency: com.apple.iokit.IOPCIFamily(2.9)[F763C275-306F-358F-B6B0-0FD93486BD5F]@0xffffff7f85e94000</p>
<p>         com.apple.driver.AppleACPIPlatform(6.1)[B0282791-F78C-3A3D-A829-629AD847C7EA]@0xffffff7f87f27000-&gt;0xffffff7f87fc2fff</p>
<p>            dependency: com.apple.driver.AppleSMC(3.1.9)[0249444C-80D4-3184-9060-F70DA3BEB17D]@0xffffff7f86364000</p>
<p><br /></p>
<p>BSD process name corresponding to current thread: kernel_task</p>
<p><br /></p>
<p>Mac OS version:</p>
<p>17G14042</p>
<p><br /></p>
<p>Kernel version:</p>
<p>Darwin Kernel Version 17.7.0: Fri Oct 30 13:34:27 PDT 2020; root:xnu-4570.71.82.8~1/RELEASE_X86_64</p>
<p>Kernel UUID: 5E83A13A-32F5-3604-8591-50E2F2F70DC6</p>
<p>Kernel slide:     0x0000000005400000</p>
<p>Kernel text base: 0xffffff8005600000</p>
<p>__HIB  text base: 0xffffff8005500000</p>
<p>System model name: MacBookPro8,2 (Mac-94245A3940C91C80)</p>
<p><br /></p>
<p>System uptime in nanoseconds: 23321620454</p>
<p>last loaded kext at 23023073418: com.apple.kext.AMDLegacySupport    1.6.8 (addr 0xffffff7f88fa1000, size 1187840)</p>
<p>loaded kexts:</p>
<p>com.apple.iokit.AppleBCM5701Ethernet    10.3.1</p>
<p>com.apple.driver.AirPort.Brcm4360    1250.20.1a4</p>
<p>com.apple.driver.AppleIntelSNBGraphicsFB    10.0.4</p>
<p>com.apple.driver.AppleSMCPDRC    1.0.0</p>
<p>com.apple.driver.SMCMotionSensor    3.0.4d1</p>
<p>com.apple.filesystems.autofs    3.0</p>
<p>com.apple.driver.AppleHDAHardwareConfigDriver    281.52</p>
<p>com.apple.driver.AppleHDA    281.52</p>
<p>com.apple.driver.AppleGraphicsDevicePolicy    3.20.18</p>
<p>com.apple.AGDCPluginDisplayMetrics    3.20.18</p>
<p>com.apple.driver.pmtelemetry    1</p>
<p>com.apple.iokit.IOUserEthernet    1.0.1</p>
<p>com.apple.iokit.IOBluetoothSerialManager    6.0.7f22</p>
<p>com.apple.Dont_Steal_Mac_OS_X    7.0.0</p>
<p>com.apple.driver.eficheck    1</p>
<p>com.apple.driver.AppleHV    1</p>
<p>com.apple.driver.AGDCBacklightControl    3.20.18</p>
<p>com.apple.driver.AppleLPC    3.1</p>
<p>com.apple.driver.ACPI_SMC_PlatformPlugin    1.0.0</p>
<p>com.apple.driver.AppleFIVRDriver    4.1.0</p>
<p>com.apple.driver.AppleThunderboltIP    3.1.1</p>
<p>com.apple.driver.AppleBacklight    170.12.6</p>
<p>com.apple.driver.AppleSMCLMU    211</p>
<p>com.apple.driver.AppleMuxControl    3.20.18</p>
<p>com.apple.driver.AppleIntelSlowAdaptiveClocking    4.0.0</p>
<p>com.apple.driver.AppleMCCSControl    1.5.5</p>
<p>com.apple.iokit.IOBluetoothUSBDFU    6.0.7f22</p>
<p>com.apple.driver.AppleUSBTCKeyEventDriver    254</p>
<p>com.apple.driver.AppleUSBTCButtons    254</p>
<p>com.apple.driver.AppleUSBTCKeyboard    254</p>
<p>com.apple.driver.AppleIRController    353</p>
<p>com.apple.driver.AppleFileSystemDriver    3.0.1</p>
<p>com.apple.filesystems.hfs.kext    407.50.6</p>
<p>com.apple.AppleFSCompression.AppleFSCompressionTypeDataless    1.0.0d1</p>
<p>com.apple.BootCache    40</p>
<p>com.apple.AppleFSCompression.AppleFSCompressionTypeZlib    1.0.0</p>
<p>com.apple.AppleSystemPolicy    1.0</p>
<p>com.apple.iokit.SCSITaskUserClient    404.30.3</p>
<p>com.apple.filesystems.apfs    748.51.0</p>
<p>com.apple.driver.AppleSDXC    1.7.6</p>
<p>com.apple.driver.AppleFWOHCI    5.5.9</p>
<p>com.apple.driver.AppleAHCIPort    329.50.2</p>
<p>com.apple.driver.AppleACPIButtons    6.1</p>
<p>com.apple.driver.AppleRTC    2.0</p>
<p>com.apple.driver.AppleHPET    1.8</p>
<p>com.apple.driver.AppleSMBIOS    2.1</p>
<p>com.apple.driver.AppleACPIEC    6.1</p>
<p>com.apple.driver.AppleAPIC    1.7</p>
<p>com.apple.driver.AppleIntelCPUPowerManagementClient    220.50.1</p>
<p>com.apple.nke.applicationfirewall    186</p>
<p>com.apple.security.TMSafetyNet    8</p>
<p>com.apple.security.quarantine    3</p>
<p>com.apple.driver.AppleIntelCPUPowerManagement    220.50.1</p>
<p>com.apple.kext.AMDLegacySupport    1.6.8</p>
<p>com.apple.iokit.IOFireWireIP    2.2.9</p>
<p>com.apple.iokit.IOEthernetAVBController    1.1.0</p>
<p>com.apple.iokit.IO80211Family    1200.12.2</p>
<p>com.apple.driver.mDNSOffloadUserClient    1.0.1b8</p>
<p>com.apple.driver.corecapture    1.0.4</p>
<p>com.apple.kext.triggers    1.0</p>
<p>com.apple.driver.DspFuncLib    281.52</p>
<p>com.apple.kext.OSvKernDSPLib    526</p>
<p>com.apple.iokit.IOSurface    211.15</p>
<p>com.apple.iokit.IOSerialFamily    11</p>
<p>com.apple.driver.AppleSSE    1.0</p>
<p>com.apple.driver.IOPlatformPluginLegacy    1.0.0</p>
<p>com.apple.driver.IOPlatformPluginFamily    6.0.0d8</p>
<p>com.apple.driver.AppleHDAController    281.52</p>
<p>com.apple.iokit.IOHDAFamily    281.52</p>
<p>com.apple.iokit.IOAudioFamily    206.5</p>
<p>com.apple.vecLib.kext    1.2.0</p>
<p>com.apple.driver.AppleSMBusPCI    1.0.14d1</p>
<p>com.apple.driver.AppleBacklightExpert    1.1.0</p>
<p>com.apple.iokit.IONDRVSupport    519.21</p>
<p>com.apple.driver.AppleGraphicsControl    3.20.18</p>
<p>com.apple.AppleGPUWrangler    3.20.18</p>
<p>com.apple.AppleGraphicsDeviceControl    3.20.18</p>
<p>com.apple.iokit.IOSlowAdaptiveClockingFamily    1.0.0</p>
<p>com.apple.driver.AppleThunderboltEDMSink    4.1.4</p>
<p>com.apple.driver.AppleSMBusController    1.0.18d1</p>
<p>com.apple.iokit.IOGraphicsFamily    519.23</p>
<p>com.apple.iokit.BroadcomBluetoothHostControllerUSBTransport    6.0.7f22</p>
<p>com.apple.iokit.IOBluetoothHostControllerUSBTransport    6.0.7f22</p>
<p>com.apple.iokit.IOBluetoothHostControllerTransport    6.0.7f22</p>
<p>com.apple.iokit.IOBluetoothFamily    6.0.7f22</p>
<p>com.apple.driver.AppleUSBMultitouch    262</p>
<p>com.apple.driver.usb.IOUSBHostHIDDevice    1.2</p>
<p>com.apple.driver.usb.cdc    5.0.0</p>
<p>com.apple.driver.usb.networking    5.0.0</p>
<p>com.apple.driver.usb.AppleUSBHostCompositeDevice    1.2</p>
<p>com.apple.driver.usb.AppleUSBHub    1.2</p>
<p>com.apple.filesystems.hfs.encodings.kext    1</p>
<p>com.apple.driver.AppleUSBMergeNub    900.4.1</p>
<p>com.apple.driver.AppleUSBHostMergeProperties    1.2</p>
<p>com.apple.driver.usb.AppleUSBHostPacketFilter    1.0</p>
<p>com.apple.iokit.IOUSBFamily    900.4.1</p>
<p>com.apple.iokit.IOSCSIMultimediaCommandsDevice    404.30.3</p>
<p>com.apple.iokit.IOBDStorageFamily    1.8</p>
<p>com.apple.iokit.IODVDStorageFamily    1.8</p>
<p>com.apple.iokit.IOCDStorageFamily    1.8</p>
<p>com.apple.driver.AppleThunderboltDPOutAdapter    5.5.5</p>
<p>com.apple.driver.AppleThunderboltDPInAdapter    5.5.5</p>
<p>com.apple.driver.AppleThunderboltDPAdapterFamily    5.5.5</p>
<p>com.apple.driver.AppleThunderboltPCIDownAdapter    2.1.3</p>
<p>com.apple.driver.AppleXsanScheme    3</p>
<p>com.apple.iokit.IOAHCISerialATAPI    267.50.1</p>
<p>com.apple.iokit.IOAHCIBlockStorage    301.40.2</p>
<p>com.apple.driver.AppleThunderboltNHI    4.7.3</p>
<p>com.apple.iokit.IOThunderboltFamily    6.7.10</p>
<p>com.apple.iokit.IOFireWireFamily    4.7.2</p>
<p>com.apple.iokit.IOAHCIFamily    288</p>
<p>com.apple.driver.usb.AppleUSBEHCIPCI    1.2</p>
<p>com.apple.driver.usb.AppleUSBUHCIPCI    1.2</p>
<p>com.apple.driver.usb.AppleUSBUHCI    1.2</p>
<p>com.apple.driver.usb.AppleUSBEHCI    1.2</p>
<p>com.apple.driver.AppleEFINVRAM    2.1</p>
<p>com.apple.driver.AppleEFIRuntime    2.1</p>
<p>com.apple.iokit.IOSMBusFamily    1.1</p>
<p>com.apple.iokit.IOHIDFamily    2.0.0</p>
<p>com.apple.security.sandbox    300.0</p>
<p>com.apple.kext.AppleMatch    1.0.0d1</p>
<p>com.apple.driver.DiskImages    480.60.3</p>
<p>com.apple.driver.AppleFDEKeyStore    28.30</p>
<p>com.apple.driver.AppleEffaceableStorage    1.0</p>
<p>com.apple.driver.AppleKeyStore    2</p>
<p>com.apple.driver.AppleUSBTDM    439.70.3</p>
<p>com.apple.driver.AppleMobileFileIntegrity    1.0.5</p>
<p>com.apple.iokit.IOUSBMassStorageDriver    140.70.2</p>
<p>com.apple.iokit.IOSCSIBlockCommandsDevice    404.30.3</p>
<p>com.apple.iokit.IOSCSIArchitectureModelFamily    404.30.3</p>
<p>com.apple.iokit.IOStorageFamily    2.1</p>
<p>com.apple.driver.AppleCredentialManager    1.0</p>
<p>com.apple.driver.KernelRelayHost    1</p>
<p>com.apple.iokit.IOUSBHostFamily    1.2</p>
<p>com.apple.driver.usb.AppleUSBCommon    1.0</p>
<p>com.apple.driver.AppleBusPowerController    1.0</p>
<p>com.apple.driver.AppleSEPManager    1.0.1</p>
<p>com.apple.driver.IOSlaveProcessor    1</p>
<p>com.apple.iokit.IOReportFamily    31</p>
<p>com.apple.iokit.IOTimeSyncFamily    680.15</p>
<p>com.apple.iokit.IONetworkingFamily    3.4</p>
<p>com.apple.driver.AppleACPIPlatform    6.1</p>
<p>com.apple.driver.AppleSMC    3.1.9</p>
<p>com.apple.iokit.IOPCIFamily    2.9</p>
<p>com.apple.iokit.IOACPIFamily    1.4</p>
<p>com.apple.kec.pthread    1</p>
<p>com.apple.kec.Libm    1</p>
<p>com.apple.kec.corecrypto    1.0</p>
<p><br /></p>
<p>EOF</p>
<p>Model: MacBookPro8,2, BootROM MBP81.0047.B27, 4 processors, Intel Core i7, 2 GHz, 8 GB, SMC 1.69f1</p>
<p>Graphics: Intel HD Graphics 3000, Intel HD Graphics 3000, Built-In</p>
<p>Graphics: AMD Radeon HD 6490M, AMD Radeon HD 6490M, PCIe</p>
<p>Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1333 MHz, 0x0198, 0x393955353436392D3034362E4130304C4620</p>
<p>Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1333 MHz, 0x0198, 0x393930353436392D3130362E4130304C4620</p>
<p>AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xD6), Broadcom BCM43xx 1.0 (5.106.98.102.30)</p>
<p>Bluetooth: Version 6.0.7f22, 3 services, 27 devices, 0 incoming serial ports</p>
<p>Network Service: Wi-Fi, AirPort, en1</p>
<p>Serial ATA Device: KINGSTON SA400S37240G, 240,06 GB</p>
<p>USB Device: USB 2.0 Bus</p>
<p>USB Device: Hub</p>
<p>USB Device: IR Receiver</p>
<p>USB Device: FaceTime HD Camera (Built-in)</p>
<p>USB Device: Apple Internal Keyboard / Trackpad</p>
<p>USB Device: BRCM2070 Hub</p>
<p>USB Device: Bluetooth USB Host Controller</p>
<p>Thunderbolt Bus: MacBook Pro, Apple Inc., 22.1</p>
<p>⟐ Answered april 28, 2026 at 0:36 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/704152/MacBook+Pro+2011,+I+replaced+the+logic+board+but+can&#039;t+get+it+to+work</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/704152</guid>
<pubDate>Tue, 28 Apr 2026 00:36:14 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 15" Retina Display Mid 2015: Battery Level dropping from 60% to 7% instantly]]></title>
<description><![CDATA[<p>Hi!</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/ah6DCXZVsiHTpdf3.standard" width="282" height="124" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/ah6DCXZVsiHTpdf3.huge&quot;, '', 'width=1600,height=701')" /></div>
<p>This is the second time I’ve replaced my battery with an ifixit battery and this is the second time this issue has came up. After replacing the battery and running the calibration cycle, I would use my laptop on its battery and somewhere around 70%-60% battery level, the battery level would just shoot down to 7%.</p>
<p>Initially on the first time around with replacing the battery, I just figured they sent me a faulty battery, but didn’t have time to buy another one and change it out, so i lived with the power adapter. I finally had a chance to replace it to a new battery, but the same thing just happened. Now, Im hoping to find some answers from you all if I have another faulty battery or some other insight on what it might can be.</p>
<p>Appreciate whatever insight provided!</p>
<p>UPDATE</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/CtUhuYNLDKPHePg5.standard" width="282" height="139" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/CtUhuYNLDKPHePg5.full&quot;, '', 'width=1001,height=491')" /></div>
<p>Here’s a photo with the coconut battery app. In the screenshot under the “BATTERY (last 12 hours)” you can  see the instant drop in battery level.</p>
<p>UPDATE #2</p>
<p>at 50% charge</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/Act6tSFysh6mxKM3.standard" width="119" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/Act6tSFysh6mxKM3.full&quot;, '', 'width=516,height=978')" /></div>
<p>at 100% charge</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/2palnuqo4HsiQj4e.standard" width="119" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/2palnuqo4HsiQj4e.full&quot;, '', 'width=520,height=984')" /></div>
<p>UPDATE #3</p>
<p>Screenshot charging from 0% to 50%</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/ErnhaZTqhD4XJdAl.standard" width="120" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/ErnhaZTqhD4XJdAl.full&quot;, '', 'width=261,height=491')" /></div>
<p>⟐ Answered april 27, 2026 at 7:38 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/671978/Battery+Level+dropping+from+60%25+to+7%25+instantly</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/671978</guid>
<pubDate>Mon, 27 Apr 2026 07:38:45 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 15" Unibody Mid 2009: Airport Card - Antenna connector broken]]></title>
<description><![CDATA[<p>Hi Guys,</p>
<p>I just broke my Airport Card Antenna connector from the Airport Card. There are 2 connectors - &quot;J1&quot; and &quot;J2&quot;</p>
<p>J2 is fully broken from the airport card, but the WiFi is still working. Do you have any idea what is the &quot;J2&quot; connection for...? is it just for boost the signal ?</p>
<p>Thanks!</p>
<p>⟐ Commented april 27, 2026 at 0:38 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/124450/Airport+Card+-+Antenna+connector+broken</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/124450</guid>
<pubDate>Mon, 27 Apr 2026 00:38:53 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 15" Retina: Why doesn't keyboard and trackpad work after battery replacement?]]></title>
<description><![CDATA[<p>I replaced a dead battery on my MacBook Pro and now the keyboard and trackpad aren't working. The battery works fine, but the fans come on like gangbusters and won't go off. I can use a remote keyboard and plug in mouse but the fans blow and blow. I did my best to reconnect the track board ribbon but clearly something is amiss.  Help!</p>
<p>⟐ Commented april 22, 2026 at 16:00 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/413054/Why+doesn&#039;t+keyboard+and+trackpad+work+after+battery+replacement</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/413054</guid>
<pubDate>Wed, 22 Apr 2026 16:00:18 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 15" Touch Bar 2019: Replacing Power/ID button - 2019 MBPro 15" Retina Touch Bar(A1990)]]></title>
<description><![CDATA[<p>I'm replacing the logic board on the above MBP as well as both USB-C boards; the ID/Power button that is matched to the board has a ribbon cable that doesn't seem to have the typical &quot;butterfly&quot; hinged lock on it. It seems like the cable is secured by a white adhesive pad beneath it. Has anyone had experience swapping the button and cable out? I'm tempted to leave the old one in and just give up the touch function. There are NO guides on iFixit or anywhere else that resemble this particular ribbon cable. If anyone has actually done this swap, I'd appreciate some sage counsel. I'd like to make the board swap in the next 24 hours.</p>
<p>⟐ Answered april 21, 2026 at 8:31 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/951320/Replacing+Power-ID+button+-+2019+MBPro+15%22+Retina+Touch+Bar(A1990)</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/951320</guid>
<pubDate>Tue, 21 Apr 2026 08:31:15 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 15" Touch Bar 2019: MacBook bms not working. Please help]]></title>
<description><![CDATA[<p>So when my bms daughter board cable is plugged in it won't turn on. After installing new ifixit battery and bms cable. It won't turn on with the bms cable. Could it be the security settings?  It happend before</p>
<p>⟐ Commented april 17, 2026 at 17:20 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/950634/MacBook+bms+not+working.+Please+help</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/950634</guid>
<pubDate>Fri, 17 Apr 2026 17:20:42 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 15" Retina Display Mid 2015: MacBook Pro A1398 got boot loop and not charge]]></title>
<description><![CDATA[<p>Battery is completely discharged. Not turn on. If charger is plugged, it turn on but just keep boot looping. If charger unplugged, it turn off right away.</p>
<p>It is possible to enter Internet recovery mode, startup disk selection mode, Apple Diagnostics by using Startup key combinations.</p>
<p>But when I try to load recovery disk or MacOS boot disk(which show apple logo), it just boot loop.</p>
<p>I tried resetting SMC/NVRAM and it did nothing.</p>
<p>What's happening on my Macbook? I have no idea.</p>
<p>⟐ Answered april 16, 2026 at 10:41 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/950673/MacBook+Pro+A1398+got+boot+loop+and+not+charge</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/950673</guid>
<pubDate>Thu, 16 Apr 2026 10:41:59 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Pro 15" Unibody Late 2011: How do I clean mbp after coffee spill?]]></title>
<description><![CDATA[<p>Spilled coffee with sugar and milk on the right side of the keyboard on my macbook pro. Immediately set aside the computer and dried most of liquid off, then turned the machine off and more intensively dried with a cloth. Turned it back on (which I now realize wasn't the wisest move, and I'm very lucky nothing got fried) and everything worked, so I put it to sleep and left it while I went to work.</p>
<p>After work (about 5 hours later) I found the keyboard keys weren't working right (no response to occasional response from enter, spacebar and delete keys, and one of the directional keys seemed to be constantly active - computer making bumping sound like incorrect key pressed), so I powered the laptop off and opened up the back to see if there was any liquid inside. The machine was bone dry inside, dust undisturbed with the only oddity being a slight coffee smell coming from the optical drive corner (drive was a little hesitant to release disk inside - took 2 tries to eject disk), but no smell anywhere else. Left the computer upside down for about a day to dry out some more (powered off) and popped off and cleaned the keys that weren't working with a damp cloth (water - dried thoroughly before popping back in place).</p>
<p>Powered the laptop on the next day and everything works except the keyboard. No response at all from any key, and the backlight only appears to be working in the very center of the board. However the computer does not sound as if it's working too hard, no overpowered fan noise, just operating normally. Currently is powered off and upside down with a small cooling fan on the keys.</p>
<p>Tried further drying by setting rice over the keys for a few hours, which was a mistake. Took a few hours to get the rice out that had seeped to the internals of the machine. I think there is still a rice piece stuck under the optical drive, but don't have the correct tools to pry it out yet.</p>
<p>Recently ordered a torc screwdriver to see if I can clean off the drive with some isopropanol, but not sure if I should replace the keyboard or not. Is there a way to fix it without replacing the whole thing? Would cleaning it with isopropanol as well help it? Should I try to clean everything since rice did get inside the machine?</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_08_09_Num_13" class="header">Update (08/09/13)</h3></div>
<p>My last attempt to turn my mac on left me a little fearful as the keys began to respond again, but not in the way they should have (pressed delete and got a letter on screen). It also befuddled me that my login screen popped up, when I have always had my mac set up to go directly to my home screen without a forced login. It had never acted up like that before, so I actually ended up taking it into the Geek Squad and am glad I did. It needed not only a new keyboard, but a new power button (which made sense to me as the power button was very hesitant to respond) and hard drive! Just lucky that I backed up my important files before sending it off! Expensive lesson, and I now have my mac ensured for any future problems. Thanks so much for your input!</p>
<p>⟐ Edited by author april 14, 2026 at 9:51 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/137623/How+do+I+clean+mbp+after+coffee+spill</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/137623</guid>
<pubDate>Tue, 14 Apr 2026 09:51:53 -0700</pubDate>
</item>
</channel>
</rss>
