<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;KitchenAid Tilt-Head Mixers&quot;]]></title>
<link>https://ts.ifixit.com/Answers/Device/KitchenAid_Tilt-Head_Mixers?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;KitchenAid Tilt-Head Mixers&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Thu, 14 May 2026 02:30:17 -0700</pubDate>
<item>
<title><![CDATA[KitchenAid Classic Mixer K45SSWH: Why won't my mixer turn on?]]></title>
<description><![CDATA[<p>I have my KitchenAid Classic Mixer plugged into the wall and when I turn it on to any of the speeds nothing happens.  I've tried to unplug it and plug it back in but I cannot get it to turn on!</p>
<p>⟐ Answered M02 10, 2025 at 13:58 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/197048/Why+won&#039;t+my+mixer+turn+on</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/197048</guid>
<pubDate>Mon, 10 Feb 2025 13:58:09 -0700</pubDate>
</item>
<item>
<title><![CDATA[KitchenAid Artisan Mixer: My kitchen aid artisan stand mixer wont turn on. it is like it has no]]></title>
<description><![CDATA[<p>my kitchenaid artisan stand mixer wont turn on. its like it has no power going to it, and yes I made sure the plug on the wall is working.</p>
<p>⟐ Edited M12 22, 2023 at 7:52 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/371612/My+kitchen+aid+artisan+stand+mixer+wont+turn+on.+it+is+like+it+has+no</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/371612</guid>
<pubDate>Fri, 22 Dec 2023 07:52:20 -0700</pubDate>
</item>
<item>
<title><![CDATA[KitchenAid Classic Mixer K45SSWH: How to change the motor? Ours has lost it's umph.]]></title>
<description><![CDATA[<p>Our K45SS still turns on but doesn't have the power for anything thick.  Still whips liquids just fine.  Do I need a new motor or just a part?  Can I do it myself?</p>
<p>⟐ Answered M05 12, 2023 at 7:53 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/791715/How+to+change+the+motor+Ours+has+lost+it&#039;s+umph.</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/791715</guid>
<pubDate>Fri, 12 May 2023 07:53:55 -0700</pubDate>
</item>
<item>
<title><![CDATA[KitchenAid Classic Mixer K45SSWH: Spark while replacing brush and now the mixer won't turn on]]></title>
<description><![CDATA[<p>Messed up while putting the brush spring back into the side of the mixer and left the power on. While inserting the brush head there was a pop and spark. Now when I insert the brush head (double checked the orientation) the motor still won’t turn on. Guess that means I shorted something, but is there anything I can do to fix it from here?</p>
<p>⟐ Commented M06 27, 2025 at 12:45 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/538397/Spark+while+replacing+brush+and+now+the+mixer+won&#039;t+turn+on</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/538397</guid>
<pubDate>Fri, 27 Jun 2025 12:45:30 -0700</pubDate>
</item>
<item>
<title><![CDATA[KitchenAid KSM150PSER: Help with a piece that fell out of the back control area]]></title>
<description><![CDATA[<p>My speed control panel needed adjusting as my stand mixer would only go high speed no matter what setting. When I opened up the back to try adjusting the screws first to fix the speed problem a little piece fell out that is a U-shaped with a rolling metal cylinder on the bottom. It just fell out and I have no idea where it goes or if it’s essential to put back in but I’m guessing so. My model number is KSM155GBSN it is a KitchenAid artisan 5 quart.</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/hZv6O4MmVFUsyEDd.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/hZv6O4MmVFUsyEDd.huge&quot;, '', 'width=900,height=1200')" /></div>
<p>⟐ Answered M04 24, 2025 at 14:16 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/726063/Help+with+a+piece+that+fell+out+of+the+back+control+area</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/726063</guid>
<pubDate>Thu, 24 Apr 2025 14:16:10 -0700</pubDate>
</item>
<item>
<title><![CDATA[KitchenAid Classic Mixer K45SSWH: Oil or grease leaking into mixing bowl?]]></title>
<description><![CDATA[<p>My KitchenAid mixer has recently been leaking some type of oil or grease out of beater shaft.  It sometimes drips into the mixing bowl!  Do I need to replace the grease in my mixer or is it one of the seals?  Thank you!!</p>
<p>⟐ Commented M12 23, 2022 at 19:02 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/197052/Oil+or+grease+leaking+into+mixing+bowl</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/197052</guid>
<pubDate>Fri, 23 Dec 2022 19:02:05 -0700</pubDate>
</item>
<item>
<title><![CDATA[KitchenAid KSM150PSER: Kitchenaid Speed 2 too fast, can't adjust it]]></title>
<description><![CDATA[<p>Hello everybody!</p>
<p>I bought an KSM150 which  was bought in the Unites States around 2005. For using it here in Germany I use a Converter from 230 V to 120 V which works perfectly.</p>
<p>My problem is, that speed 2 is nearly twice as fast as it should be, speed 2 , 6 and 8 are nearly the same and speed 10 is a lot faster. I tried to adjust it, what didn't work. So i bought a new phase control board and replaced the old one, sadly without an effect.</p>
<p>Do you think it's the speed control plate or could it also be the Mixer Motor Governor which causes the problem?</p>
<p>Thanks for your help,</p>
<p>Alex</p>
<p>⟐ Commented M10 03, 2021 at 7:28 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/500137/Kitchenaid+Speed+2+too+fast,+can&#039;t+adjust+it</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/500137</guid>
<pubDate>Sun, 03 Oct 2021 07:28:37 -0700</pubDate>
</item>
<item>
<title><![CDATA[KitchenAid Classic Mixer K45SSWH: Will not start on low speeds]]></title>
<description><![CDATA[<p>My 32 year old KitchenAid Mixer Model K45SS (no WH at the end) will not start  until I move the speed lever to at least 5 (that gets messy!).  I can then move the lever back to the lower speeds and it will work fine.</p>
<p>⟐ Commented M04 02, 2020 at 13:18 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/590547/Will+not+start+on+low+speeds</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/590547</guid>
<pubDate>Thu, 02 Apr 2020 13:18:12 -0700</pubDate>
</item>
<item>
<title><![CDATA[KitchenAid Classic Mixer K45SSWH: Will not turn on at all after cleaning. No motor running]]></title>
<description><![CDATA[<p>Kitchen aid mixer K45SS, bought in 70s, won't come on.  I cleaned it by removing screws and cleaned screws and replaced.  Oiled moving parts.  Put everything back like it was.  Now, won't turn on at all.  Is there something not adjusted right for it to refuse to work.  No motor sound, no nothing. Thanks, Debra Huffman</p>
<p>⟐ Commented M08 19, 2024 at 5:30 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/798329/Will+not+turn+on+at+all+after+cleaning.+No+motor+running</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/798329</guid>
<pubDate>Mon, 19 Aug 2024 05:30:36 -0700</pubDate>
</item>
<item>
<title><![CDATA[KitchenAid Classic Mixer K45SSWH: Do I oil it or have it serviced]]></title>
<description><![CDATA[<p>Laid it over to get model number oil came out. Is there away for me to oil it or does it have to be serviced and if so where  machine about 8 years old. Thanks</p>
<p>⟐ Answer accepted M10 27, 2021 at 21:18 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/408984/Do+I+oil+it+or+have+it+serviced</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/408984</guid>
<pubDate>Wed, 27 Oct 2021 21:18:57 -0700</pubDate>
</item>
<item>
<title><![CDATA[KitchenAid KSM150PSER: Meat Grinder Attachment Won't Grind...It Sticks]]></title>
<description><![CDATA[<p>While grinding meat using the grinder attachment, the sound of the motor has changed and then the grinder stops. I suspect it needs to be cleaned. What is the recommended method and materials to do this?</p>
<p>⟐ Answered M10 23, 2019 at 10:12 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/593501/Meat+Grinder+Attachment+Won&#039;t+Grind...It+Sticks</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/593501</guid>
<pubDate>Wed, 23 Oct 2019 10:12:12 -0700</pubDate>
</item>
<item>
<title><![CDATA[KitchenAid Classic Mixer K45SSWH: Won't work at higher speeds]]></title>
<description><![CDATA[<p>KitchenAid Mixer KP26M1XPM5</p>
<p>I live in Costa Rica....so bringing it in for repair won't work.</p>
<p>My mixer is only a couple of years old, and I haven't used it in awhile.  The last time was to put a pasta attachment on it and it worked great.</p>
<p>The problem: It works great up to speed 3, then it won't ramp up past that speed.</p>
<p>⟐ Answer accepted M08 08, 2017 at 4:16 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/407008/Won&#039;t+work+at+higher+speeds</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/407008</guid>
<pubDate>Tue, 08 Aug 2017 04:16:24 -0700</pubDate>
</item>
<item>
<title><![CDATA[KitchenAid Artisan Mixer: Will not turn off]]></title>
<description><![CDATA[<p>I have a Kitchen Aid Artisan stand mixer, about 5 years old. The switch will not stay in the off position, but will move (all by itself) into the stir position. If I tighten the recommended screw, it solves this problem, but then the mixer runs at a much higher speed and will not run at low speeds at all.</p>
<p>A question that was asked previously is similar to mine:</p>
<p><a href="/Answers/View/42154/Doesn%27t+actually+turn+off">Doesn't actually turn off</a></p>
<p>If it is a part that needs to be replaced, I would appreciate a new link to the part that I need as the old link is now broken. If I need to test if a switch is bad, if you could let me know exactly how to do that, that would be great as well.</p>
<p>Thank you in advance.</p>
<p>⟐ Edited M04 19, 2024 at 7:17 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/198749/Will+not+turn+off</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/198749</guid>
<pubDate>Fri, 19 Apr 2024 07:17:39 -0700</pubDate>
</item>
<item>
<title><![CDATA[KitchenAid Tilt-Head Mixers: Why is the speed too low at setting 10]]></title>
<description><![CDATA[<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/auN4iBwnYUR4vCxr.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/auN4iBwnYUR4vCxr.full&quot;, '', 'width=1200,height=1600')" /></div>
<p>I have an older Kitchenaid Artisan tilt head mixer and even after speed adjustment and replacement of top plastic gear assembly, food grade grease and phase control board (original spare part) the speed won’t go up after position 8. Even when properly adjusted (60 rpm at 1, 180 rpm at 6), the speed difference between position 6 and 8 is minimal and between 8 and 10 is absent.</p>
<p>This speed problem was already there when I was given the mixer, but I was hoping the replacements and adjustments would fix the speed problem. Please advise.</p>
<p>⟐ Commented M11 02, 2025 at 6:20 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/924214/Why+is+the+speed+too+low+at+setting+10</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/924214</guid>
<pubDate>Sun, 02 Nov 2025 06:20:34 -0700</pubDate>
</item>
<item>
<title><![CDATA[KitchenAid KSM150PSER: Gradual loss of lower speeds - now only speed 6 and up work]]></title>
<description><![CDATA[<p>My kitchenaid 220V when purchased used did not work on stir and speed 1. Eventually over time speed 2, all the way to 8 no longer worked. The machine would sometimes give a half effort to turn and then nothing. My friend took apart the whole machine and put it back together and it magically worked again. He didn't exactly know what he  did. He said he just cleaned it up and reassembled it.</p>
<p>Fast forward 3 years, and the same thing has happened. Gradually over 2 months stir stopped working, and now only speed 6 and up work (at proper spinning speed).</p>
<p>Any thoughts?</p>
<p>⟐ Answered M05 26, 2022 at 15:41 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/477294/Gradual+loss+of+lower+speeds+-+now+only+speed+6+and+up+work</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/477294</guid>
<pubDate>Thu, 26 May 2022 15:41:53 -0700</pubDate>
</item>
<item>
<title><![CDATA[KitchenAid Artisan Mixer: Oil or grease leaking from bottom of stand.]]></title>
<description><![CDATA[<p>Is this an easy fix or should I look at replacing it?  15 yr old</p>
<p>Thanks,</p>
<p>Mike</p>
<p>⟐ Answered M01 01, 2026 at 20:52 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/812788/Oil+or+grease+leaking+from+bottom+of+stand.</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/812788</guid>
<pubDate>Thu, 01 Jan 2026 20:52:22 -0700</pubDate>
</item>
<item>
<title><![CDATA[KitchenAid KSM150PSER: Speed control lever won't stay in off position]]></title>
<description><![CDATA[<p>I have an Artisan KA about 9 years old.  It has done well but over the last few months the speed control lever has started to jump out of the off position so that when you switch the power on at the mains it starts from speed one.  I’ve taken the back off, and the adjustment screw wasn’t all the way in - but if I screw that in then it forces the main contacts apart until the lever moves to position 3.  It feels like the lever needs more upward pressure, so that the raised bump on top of the lever is pushed more firmly into the grooves carved into the side of the body (they are hidden under the thin aluminium strip that wraps round the machine).  Anyone got any ideas?  Many thanks!</p>
<p>⟐ Commented M12 26, 2023 at 11:11 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/628116/Speed+control+lever+won&#039;t+stay+in+off+position</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/628116</guid>
<pubDate>Tue, 26 Dec 2023 11:11:38 -0700</pubDate>
</item>
<item>
<title><![CDATA[KitchenAid Classic Mixer K45SSWH: Why is my mixer hot and leaking oil?]]></title>
<description><![CDATA[<p>My mixer is leaking oil from under / behind the logo band ( has kitchenaid ,classical the speeds on it.  How can I get an actual manual for this thing 😫  I'm so frustrated with this!!</p>
<p>⟐ Answer edited M05 16, 2022 at 16:18 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/732831/Why+is+my+mixer+hot+and+leaking+oil</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/732831</guid>
<pubDate>Mon, 16 May 2022 16:18:07 -0700</pubDate>
</item>
<item>
<title><![CDATA[KitchenAid Classic Mixer K45SSWH: How can I adjust the height of the beater?]]></title>
<description><![CDATA[<p>The beater head of my mixer is being damaged from being too low!  Can I adjust the height to add clearance between the bowl and the beater head?</p>
<p>⟐ Commented M01 28, 2021 at 1:26 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/197050/How+can+I+adjust+the+height+of+the+beater</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/197050</guid>
<pubDate>Thu, 28 Jan 2021 01:26:41 -0700</pubDate>
</item>
<item>
<title><![CDATA[KitchenAid KSM150PSER: Interference filter board installation]]></title>
<description><![CDATA[<p>Hi,</p>
<p>I need to fit a new interference filter board to my mixer, part number rfi pub 9705132 but can’t see how it screws to the body of the mixer. Any help would be appreciated.</p>
<p>⟐ Answered M03 10, 2026 at 7:27 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/944168/Interference+filter+board+installation</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/944168</guid>
<pubDate>Tue, 10 Mar 2026 07:27:42 -0700</pubDate>
</item>
</channel>
</rss>
