<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Home Audio Amplifier&quot;]]></title>
<link>https://ts.ifixit.com/Answers/Device/Home_Audio_Amplifier?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Home Audio Amplifier&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Sat, 18 Jul 2026 03:52:37 -0700</pubDate>
<item>
<title><![CDATA[Home Audio Amplifier: Why won't my Amp power up?]]></title>
<description><![CDATA[<p>I have an A500 Behringer power amp that will not power up. I replaced the power cord and fuse with known working ones, with no result. Next, I took the fuse I tested in it and plugged it back into a working amp of the same model, which ran fine (so I know the amp isn't just killing fuses).</p>
<p>Any ideas?</p>
<div class="clearer"></div><div class="headerContainer"><h2 id="Section_UPDATE" class="header">UPDATE:</h2></div>
<p>(I would have put this as a comment,  but needed more words. I would have edited my original post, but couldn't upload pics on an edit.) Every once in a long while, the lights on the front of the power amp will light briefly and then die, but 98 percent of the time, nothing. I have opened it up, and here is the power path:</p>
<p>There is the plug/fuse combo:</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/ty5vI6p21powNYR5.standard" width="282" height="211" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/ty5vI6p21powNYR5.huge&quot;, '', 'width=1600,height=1200')" /></div>
<p>As you can see, there is a green/yellow ground. There is a black wire that goes straight into the heart (massive heavy cylinder of wires) of the amp. There is another black wire with a capacitor (I think?) directly after the plug. This wire goes to the switch in the front, which is a simple push button. There is a blue wire coming out of the switch back into the heart of the amp, completing the circuit.</p>
<p>The rest of the components (led board, input boards, output boards, volume knobs) seem irrelevant because it's not getting power at tall (but I could be wrong). Here's a pic of the entire setup:</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/tq3w6arFUiDjoSJj.standard" width="282" height="211" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/tq3w6arFUiDjoSJj.huge&quot;, '', 'width=1600,height=1200')" /></div>
<p>Any ideas? I am not an electrician, so please use small words :)</p>
<p>⟐ Commented février 20, 2021 at 15:16 UTC−7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/2453/Why+won&#039;t+my+Amp+power+up</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/2453</guid>
<pubDate>Sat, 20 Feb 2021 15:16:38 -0700</pubDate>
</item>
<item>
<title><![CDATA[Home Audio Amplifier: Maintenance of an old but very good Amplifier]]></title>
<description><![CDATA[<p>Hi, is there anybody that can teach me how to maintain and old amplifier. Understand when a capacitor is good or not, where and what to clean... this kind of stuff. Thanks a lot in advance</p>
<p>⟐ Commented février 14, 2021 at 9:32 UTC−7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/304994/Maintenance+of+an+old+but+very+good+Amplifier</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/304994</guid>
<pubDate>Sun, 14 Feb 2021 09:32:08 -0700</pubDate>
</item>
<item>
<title><![CDATA[Home Audio Amplifier: How to fix a protect display]]></title>
<description><![CDATA[<p>I have a onkyo tx sv424</p>
<p>Gow i can fix it</p>
<p>I have CONNECT  a pair of tower speaker that never used or test BEFORE,</p>
<p>Do you think that speaker  can blow a power transistor  and display now  protect on display</p>
<p>Any ideas</p>
<p>⟐ Answered février 01, 2026 at 7:39 UTC−7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/462347/How+to+fix+a+protect+display</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/462347</guid>
<pubDate>Sun, 01 Feb 2026 07:39:04 -0700</pubDate>
</item>
<item>
<title><![CDATA[Home Audio Amplifier: Right speaker terminals have no signal. Possible to fix?]]></title>
<description><![CDATA[<p>Hello guys,</p>
<p>I wanted to use this old amplifier, a Kenwood KA-56.</p>
<p>But unfortunately for both outputs (speakers A and B) only the left connector receives a signal.</p>
<p>Somewhere the signal to the right terminal is lost.</p>
<p>I know i is not expensive to buy a new one, but I wanted to have an idea first about the option to fix this myself.</p>
<p>what do you think?</p>
<p>Thanks,</p>
<p>⟐ Answered septembre 02, 2020 at 5:07 UTC−7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/213555/Right+speaker+terminals+have+no+signal.+Possible+to+fix</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/213555</guid>
<pubDate>Wed, 02 Sep 2020 05:07:39 -0700</pubDate>
</item>
<item>
<title><![CDATA[Home Audio Amplifier: shake 33 power amp in protect e01]]></title>
<description><![CDATA[<p>I have a Sony Shake33.</p>
<p>It is stuck in protect e01.</p>
<p>The repair manual says that it could the main amp board or the power supply. Here is the description: &quot;The overcurrent condition to MOSFET occurs by a defect of MOSFET or defect of PS output line.&quot;</p>
<p>So I want to check the power supply first. Since I cannot power up the amp as it disconnects on boot, I can unplug it as it is modular and it boots fine. The test procedure doesn't require high-end testing equipment just a multimeter. The readings on the pins that come from the power supply are all good with the exception of the 1 st pin.  It shows -22V when it should be 16V~23V. The actual power supply schematic says &quot;pin1: V3+ (DC+16V~23V) _ (ref-V1)&quot;.</p>
<p>My question is what is V3 and ref-V1 from the above formula? Am I testing this correctly?</p>
<p>⟐ Answered juillet 22, 2018 at 11:09 UTC−7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/502484/shake+33+power+amp+in+protect+e01</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/502484</guid>
<pubDate>Sun, 22 Jul 2018 11:09:58 -0700</pubDate>
</item>
<item>
<title><![CDATA[Home Audio Amplifier: What are the parts required for a working RS-914A stereo amplifier?]]></title>
<description><![CDATA[<p>I obtained a Fisher non-operable stereo amplifier model number RS-914A but I've noticed some of the capacitors were missing and possible other parts. I'm looking to rebuild it but need to know what parts are required so that I can purchase and apply them to the circuit board. I've looked everywhere online and I can't find anything helpful, so a part list would be majorly helpful.</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/HtN1nkKwW6Icidri.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/HtN1nkKwW6Icidri.huge&quot;, '', 'width=897,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/4dWPcDGqLdLIvBxI.standard" width="282" height="211" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/4dWPcDGqLdLIvBxI.huge&quot;, '', 'width=1600,height=1196')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/G4Ip2HskHdeQLlDW.standard" width="282" height="211" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/G4Ip2HskHdeQLlDW.huge&quot;, '', 'width=1600,height=1196')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/Wb3UjIDG4DMB5AvB.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/Wb3UjIDG4DMB5AvB.huge&quot;, '', 'width=897,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/DJeLUGyeFhKPgrPJ.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/DJeLUGyeFhKPgrPJ.huge&quot;, '', 'width=897,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/tS6ReJIPSfKvHpbR.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/tS6ReJIPSfKvHpbR.huge&quot;, '', 'width=897,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/OOCIg4IQ5agtFIRo.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/OOCIg4IQ5agtFIRo.huge&quot;, '', 'width=897,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/5M3WqQBBn1XAEqb6.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/5M3WqQBBn1XAEqb6.huge&quot;, '', 'width=897,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/lJUDyJPGWGJZN1W6.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/lJUDyJPGWGJZN1W6.huge&quot;, '', 'width=897,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/lmh2EPi1sPxbYmBr.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/lmh2EPi1sPxbYmBr.huge&quot;, '', 'width=897,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/iVhEBgD5qSTsvNyi.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/iVhEBgD5qSTsvNyi.huge&quot;, '', 'width=897,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/bfINOO6sCtBsVkTv.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/bfINOO6sCtBsVkTv.huge&quot;, '', 'width=897,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/bWAUaUpQMJnSECWf.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/bWAUaUpQMJnSECWf.huge&quot;, '', 'width=897,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/VFLOnTTcRycwfjU2.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/VFLOnTTcRycwfjU2.huge&quot;, '', 'width=897,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/GyIRsXVfVeOPUa1r.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/GyIRsXVfVeOPUa1r.huge&quot;, '', 'width=897,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/mn3nPRbGtqGW311i.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/mn3nPRbGtqGW311i.huge&quot;, '', 'width=897,height=1200')" /></div>
<p>⟐ Comment deleted juillet 28, 2017 at 18:38 UTC−7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/217319/What+are+the+parts+required+for+a+working+RS-914A+stereo+amplifier</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/217319</guid>
<pubDate>Fri, 28 Jul 2017 18:38:06 -0700</pubDate>
</item>
<item>
<title><![CDATA[Onkyo TX-800: Will not power up?]]></title>
<description><![CDATA[<p>We have an Onkyo  TX-830 purchased December 1988. When you turn the power switch on it does not power up. The  &quot;Stand-BY Received&quot; light comes on but will not power up. Any ideas of a fix???</p>
<p>⟐ Commented octobre 19, 2010 at 21:32 UTC−7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/29178/Will+not+power+up</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/29178</guid>
<pubDate>Tue, 19 Oct 2010 21:32:21 -0700</pubDate>
</item>
<item>
<title><![CDATA[Onkyo TX-800: How to replace the on-off switch]]></title>
<description><![CDATA[<p>Unit will not turn on. Fuse is ok</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/211906/How+to+replace+the+on-off+switch</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/211906</guid>
<pubDate>Mon, 26 Jan 2015 13:16:42 -0700</pubDate>
</item>
<item>
<title><![CDATA[Home Audio Amplifier: Why is my amp staying in protection mode]]></title>
<description><![CDATA[<p>Protection light stays...fuse is good</p>
<p>⟐ Answered octobre 13, 2025 at 8:50 UTC−7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/386772/Why+is+my+amp+staying+in+protection+mode</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/386772</guid>
<pubDate>Mon, 13 Oct 2025 08:50:11 -0700</pubDate>
</item>
<item>
<title><![CDATA[Cambridge Audio A3i: Why is the volume when playing from turntable very low]]></title>
<description><![CDATA[<p>Volume is very low when using the Technics SL-1700 turntable</p>
<p>⟐ Answered avril 27, 2021 at 16:33 UTC−7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/422427/Why+is+the+volume+when+playing+from+turntable+very+low</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/422427</guid>
<pubDate>Tue, 27 Apr 2021 16:33:30 -0700</pubDate>
</item>
<item>
<title><![CDATA[TEAC GSA-5300 stereo integrated amplifier: The mains fuse inside the amplifier and I found R145, R170 melted]]></title>
<description><![CDATA[<p>The amplifier keeps blowing the mains fuse and i found R145,R170  are melted on the pcb can you help me fix this problem?</p>
<p>⟐ Answered septembre 02, 2020 at 5:11 UTC−7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/254093/The+mains+fuse+inside+the+amplifier+and+I+found+R145,+R170+melted</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/254093</guid>
<pubDate>Wed, 02 Sep 2020 05:11:40 -0700</pubDate>
</item>
<item>
<title><![CDATA[Home Audio Amplifier: I have a Sansui 550 Classique amplifier -need help]]></title>
<description><![CDATA[<p>My Sansui 550 Classique amp will not turn on, just humming sound and we have blown multiple fuses.  Now even when replacing the fuse we get nothing.</p>
<p>We’ve checked the speaker wires.  Receiver turns on.  Amp shorts out after a crackle-hum sound.</p>
<p>any advice for repairing this?</p>
<p>⟐ Commented septembre 16, 2025 at 3:48 UTC−7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/716342/I+have+a+Sansui+550+Classique+amplifier+-need+help</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/716342</guid>
<pubDate>Tue, 16 Sep 2025 03:48:21 -0700</pubDate>
</item>
<item>
<title><![CDATA[Home Audio Amplifier: VSX819H amp wont enter service mode]]></title>
<description><![CDATA[<p>Hi, My pioneer VSX 819h went into protection mode. It now won’t enter service mode. I’m following the service manual. The only thing it does is turns on for 4-5 secs when pressing power button+adv-surround which according to the service manual is used for clearing the error counts. Thanks</p>
<p>⟐ Commented août 08, 2025 at 8:12 UTC−7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/610120/VSX819H+amp+wont+enter+service+mode</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/610120</guid>
<pubDate>Fri, 08 Aug 2025 08:12:33 -0700</pubDate>
</item>
<item>
<title><![CDATA[Home Audio Amplifier: Behringer b212d Blowing Fuses]]></title>
<description><![CDATA[<p>Hi there!  I have a Behringer B212D powered speaker that keeps blowing fuses. I opened it up and see I have 2 MOSFETS that have blown up on the primary side of the switch mode power supply. I haven’t been able to locate any shorts on the primary side, but I hear that when the fets blow and the fuse blows, there are likely other parts that got taken out as well. I’ve checked all the resistors and capacitors and diodes and can’t find any parts that measure faulty or show a short. I’ve also used an ESR tester on all the electrolytics.</p>
<p>I read somewhere that when the fets blow, the IC that regulates the switching of the fets gets taken out as well. I’ve taken out the 2 blown up fets and was thinking of powering up the SMPS  with a light bulb limiter to see if I could measure the voltage coming into the IC, but I read somewhere that you should replace both the IC and fet, because if you don’t, then whichever part you leave in will cause the other part to blow again. That is, if I replace the fets only and if the IC is blown, the IC will cause the new fets to blow.</p>
<p>So my question is, should I replace the IC and fets together?  Can I try powering up the board without the fets and see if I’m getting voltage to the IC, or is it likely I’ll blow something else up?  The schematic is for a B215D which is very close to the B212D I have. The main difference is it has a 15” speaker, where mine has a 12” speaker. Unfortunately the schematic came out blurry where the original is not. I’ll see what I can do to get it clearer. Thank you!</p>
<p><a href="/Document/O3J2pZYDbPsZrQ6y/Behringer-B215D-Schematics.pdf" class="docLink"><span    class="fa-svg-icon docLink-icon"><svg width="14" height="14" xmlns="http://www.w3.org/2000/svg" viewBox="0 0 384 512"><!--! Font Awesome Pro 6.5.1 by @fontawesome - https://fontawesome.com License - https://fontawesome.com/license (Commercial License) Copyright 2023 Fonticons, Inc. --><path d="M64 464c-8.8 0-16-7.2-16-16V64c0-8.8 7.2-16 16-16H224v80c0 17.7 14.3 32 32 32h80V448c0 8.8-7.2 16-16 16H64zM64 0C28.7 0 0 28.7 0 64V448c0 35.3 28.7 64 64 64H320c35.3 0 64-28.7 64-64V154.5c0-17-6.7-33.3-18.7-45.3L274.7 18.7C262.7 6.7 246.5 0 229.5 0H64zm56 256c-13.3 0-24 10.7-24 24s10.7 24 24 24H264c13.3 0 24-10.7 24-24s-10.7-24-24-24H120zm0 96c-13.3 0-24 10.7-24 24s10.7 24 24 24H264c13.3 0 24-10.7 24-24s-10.7-24-24-24H120z"/></svg></span>Behringer B215D Schematics</a></p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/jGKZUQxMwXIoStPl.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/jGKZUQxMwXIoStPl.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/FcHTxEQRXmDfmeXu.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/FcHTxEQRXmDfmeXu.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/3yCGUdlEjVYEjp1M.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/3yCGUdlEjVYEjp1M.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/x1wjRMfIxI1L1dke.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/x1wjRMfIxI1L1dke.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/n3kyFn5qsyURLHyP.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/n3kyFn5qsyURLHyP.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/AyV5ExdZRvg4D6Xp.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/AyV5ExdZRvg4D6Xp.huge&quot;, '', 'width=900,height=1200')" /></div>
<p>⟐ Commented février 18, 2023 at 12:44 UTC−7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/769516/Behringer+b212d+Blowing+Fuses</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/769516</guid>
<pubDate>Sat, 18 Feb 2023 12:44:47 -0700</pubDate>
</item>
<item>
<title><![CDATA[Home Audio Amplifier: Technics amp RCA inputs barely works.]]></title>
<description><![CDATA[<p>I have a Technics SU-V7X home amplifier and it works except when I plug anything into the rca inputs on the back and turn on the amp and select it I have to turn up the volume knob to max and the tweeter in my speaker plays very little of what music I’m playing, but if I plug that rca cable from my source into direct input it works like a charm but there’s only 1 of those and I wanna connect my new vinyl players and my Bluetooth receiver, so what causes the selector input to not work?</p>
<p>⟐ Answered novembre 22, 2022 at 13:04 UTC−7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/665782/Technics+amp+RCA+inputs+barely+works.</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/665782</guid>
<pubDate>Tue, 22 Nov 2022 13:04:55 -0700</pubDate>
</item>
<item>
<title><![CDATA[Home Audio Amplifier: Why is my integrated amp going into Standby mode?]]></title>
<description><![CDATA[<p>My Yamaha A - S301 integrated amp powers up and goes immediately into Standby mode.  I already checked the impedance switch on the back of the unit.  I also disconnected the speakers to see if they are the culprit, but the problem persists.</p>
<p>⟐ Commented août 06, 2022 at 5:42 UTC−7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/723684/Why+is+my+integrated+amp+going+into+Standby+mode</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/723684</guid>
<pubDate>Sat, 06 Aug 2022 05:42:16 -0700</pubDate>
</item>
<item>
<title><![CDATA[Home Audio Amplifier: there is no sound output on the speakers anymore]]></title>
<description><![CDATA[<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Sony_TA_FE910R" class="header">Sony TA-FE910R</h3></div>
<p>I dont understand much of the internals of my technical devices, unfortunately. Its getting power and I can turn it on, LED's are shining from inside and from the power button. Also you can connect other devices t the AC-Power Outlet. But there is no sound output on the speakers anymore. I tried every input channel, different cables and every output speaker channel. All dead output.</p>
<p>And diffrent speakers of course</p>
<p>Im affraid I damaged it when I, in my stupidity, coneccted a battery powered fary lights to the music output (speakers) adapter/ports. I know, I shouldnt have done that. But im not sure its realy the reasen for it to be dead and I never would understand whats damaged exactely.</p>
<p>Thanks for your interest! Havent expected that :)</p>
<p>PS: I also checked the boards inside for any burned stuff. But with my untrained eyes I coulnd find any obvious damaged components</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/YJNKs14ks4LHAkHB.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/YJNKs14ks4LHAkHB.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/FvuGV5ddIeo3UHKa.standard" width="282" height="211" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/FvuGV5ddIeo3UHKa.huge&quot;, '', 'width=1600,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/gSqLcq4RAIkxZLSW.standard" width="282" height="211" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/gSqLcq4RAIkxZLSW.huge&quot;, '', 'width=1600,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/DLhdHmiFZWKQeFvK.standard" width="174" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/DLhdHmiFZWKQeFvK.huge&quot;, '', 'width=927,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/RdMZufBYPMWyjDKp.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/RdMZufBYPMWyjDKp.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/OpPIXkH3GYdtpTFP.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/OpPIXkH3GYdtpTFP.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/TeeVD6t2EbTpDvJ2.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/TeeVD6t2EbTpDvJ2.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/MSdRByMZeZOfmaaA.standard" width="228" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/MSdRByMZeZOfmaaA.huge&quot;, '', 'width=1215,height=1200')" /></div>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_" class="header">===</h3></div>
<p>Update (11/06/2021) ===</p>
<p>ok I got the multimeter now and watched some youtube videos to get an expert.</p>
<p>I would set it like on the photo to measure the 2.2V:</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/5fXDIZADcNKiBgq6.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/5fXDIZADcNKiBgq6.huge&quot;, '', 'width=900,height=1200')" /></div>
<p>But then… Where do I have to touch the black and red stick of the multimeter? One of them to the 7th pin of CI 401 (photo), but which one? And the second to…?</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/O4xiMGQALsMoDIkt.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/O4xiMGQALsMoDIkt.huge&quot;, '', 'width=900,height=1200')" /></div>
<p>And I’ll do all this while the amplifire is pluged in and powered on right? Little afraid of that :)</p>
<p>⟐ Commented janvier 24, 2022 at 10:41 UTC−7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/711072/there+is+no+sound+output+on+the+speakers+anymore</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/711072</guid>
<pubDate>Mon, 24 Jan 2022 10:41:50 -0700</pubDate>
</item>
<item>
<title><![CDATA[Home Audio Amplifier: Technics eh 500 shows F61 and becomes hot then shut off.]]></title>
<description><![CDATA[<p>Technics eh500 shows f61 and cuts off</p>
<p>⟐ Commented décembre 04, 2021 at 4:58 UTC−7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/638944/Technics+eh+500+shows+F61+and+becomes+hot+then+shut+off.</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/638944</guid>
<pubDate>Sat, 04 Dec 2021 04:58:25 -0700</pubDate>
</item>
<item>
<title><![CDATA[Home Audio Amplifier: Home Stereo Power amp switches self off after +- 30 minutes.]]></title>
<description><![CDATA[<p>I have a 21year old Technics Stereo Component system which has worked flawlessly until about a month ago.</p>
<p>Now, regardless whether I am playing CD's, radio or tapes, it powers down after about 20 mins from starting. I can then power up immediately again and it will operate for a shorter time before powering down again and so forth.</p>
<p>Any thoughts on what may be causing this?</p>
<p>⟐ Commented juin 28, 2021 at 19:58 UTC−7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/242728/Home+Stereo+Power+amp+switches+self+off+after++-+30+minutes.</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/242728</guid>
<pubDate>Mon, 28 Jun 2021 19:58:36 -0700</pubDate>
</item>
<item>
<title><![CDATA[Home Audio Amplifier: Amplifier not turning on]]></title>
<description><![CDATA[<p>Power to unit but not powering up it's a Yamaha rxv1900</p>
<p>⟐ Commented juin 03, 2019 at 20:44 UTC−7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/570841/Amplifier+not+turning+on</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/570841</guid>
<pubDate>Mon, 03 Jun 2019 20:44:45 -0700</pubDate>
</item>
</channel>
</rss>
