<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;General Pipe Cleaners Drain Cleaner&quot;]]></title>
<link>https://ts.ifixit.com/Answers/Device/General_Pipe_Cleaners_Drain_Cleaner/All?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;General Pipe Cleaners Drain Cleaner&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Fri, 21 Aug 2026 16:44:29 -0700</pubDate>
<item>
<title><![CDATA[General Pipe Cleaners Drain Cleaner MiniRooter XP 2012: Wiring Diagram for Toggle Switch]]></title>
<description><![CDATA[<p>Where can I get a wiring diagram for a general mini rooter?</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/952441/Wiring+Diagram+for+Toggle+Switch</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/952441</guid>
<pubDate>Tue, 28 Apr 2026 03:34:42 -0700</pubDate>
</item>
<item>
<title><![CDATA[General Wire Spring Co AutoFeed Drain Cleaner 100 x 58 HDPS92EO: How to connect the 5/8 Cable to the machine?]]></title>
<description><![CDATA[<p>doing maintenance on the machine, needed a new cable, when ordered the hold for connection wont fit on the screw, what are some ways to safely install the cable back onto the machine?</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/888102/How+to+connect+the+5-8+Cable+to+the+machine</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/888102</guid>
<pubDate>Sun, 16 Feb 2025 13:57:30 -0700</pubDate>
</item>
<item>
<title><![CDATA[General Wire Spring Co AutoFeed Drain Cleaner 100 x 58 HDPS92EO: The machine stops retracting the snake. Extending the snake works fine]]></title>
<description><![CDATA[<p>When using the <strong>General Drain Cleaner Speedrooter 92R</strong></p>
<p>The General Speedrooter 92R Drain Cleaner is an auto-feed drain cleaner 100' x 5/8&quot; from General Pipe Cleaners. Released in 2010. Model number: HDPS92EO.</p>
<p>The snake extends just fine but the retraction of the snake often stops completely. What is needed to be replaced to correct that problem?</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/879185/The+machine+stops+retracting+the+snake.+Extending+the+snake+works+fine</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/879185</guid>
<pubDate>Tue, 03 Dec 2024 02:01:39 -0700</pubDate>
</item>
<item>
<title><![CDATA[General Wire Spring Co AutoFeed Drain Cleaner 100 x 58 HDPS92EO: rescue a 5/8 cable]]></title>
<description><![CDATA[<p>I have a 100’ drain snake that kinked about 15’ in from the tip, so I cut the cable back and used a quick fix to replace the end. Is there a way I can connect 2 cables together to replace the piece I cut off? rather then replacing the whole cable.</p>
<p>⟐ Answered janeiro 17, 2024 at 12:55 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/723770/rescue+a+5-8+cable</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/723770</guid>
<pubDate>Wed, 17 Jan 2024 12:55:06 -0700</pubDate>
</item>
<item>
<title><![CDATA[General Wire Spring Co AutoFeed Drain Cleaner 100 x 58 HDPS92EO: speedrooter 92r drum bearings repair]]></title>
<description><![CDATA[<p>speedspool 92 r drum bushing repair</p>
<p>⟐ Answer edited janeiro 11, 2023 at 0:23 GMT-7</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/763558/speedrooter+92r+drum+bearings+repair</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/763558</guid>
<pubDate>Wed, 11 Jan 2023 00:23:21 -0700</pubDate>
</item>
</channel>
</rss>
