<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Damaged Wire&quot;]]></title>
<link>https://ts.ifixit.com/Answers/Device/Damaged_Wire/All?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Damaged Wire&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Thu, 20 Aug 2026 05:26:16 -0700</pubDate>
<item>
<title><![CDATA[Damaged Wire: Is there a good tool to strip wireless antenna coax? mostly for MHF4]]></title>
<description><![CDATA[<p>I am interested in trying to re-wire an antenna that has a broken wire (and MHF4 connector).  Can someone recommend any stripping tools for this fine work?  I realize that the wires are extremely small, is there a tool or tools to do it manually?  I know there are machines that can do it, but they're not in the budget.  I intend on stripping and soldering the cable to a new antenna.  Thanks in advance for any insight.</p>
<p>⟐ Answered July 20, 2026 at 22:29 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/755083/Is+there+a+good+tool+to+strip+wireless+antenna+coax+mostly+for+MHF4</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/755083</guid>
<pubDate>Mon, 20 Jul 2026 22:29:19 -0700</pubDate>
</item>
<item>
<title><![CDATA[Damaged Wire: minimum wire mm for 3 kw load]]></title>
<description><![CDATA[<p>What minimum mm wire (aluminium) should be used to carry a load of 3 KW to house?</p>
<p>⟐ Answer accepted September 30, 2023 at 16:35 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/798993/minimum+wire+mm+for+3+kw+load</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/798993</guid>
<pubDate>Sat, 30 Sep 2023 16:35:30 -0700</pubDate>
</item>
<item>
<title><![CDATA[Damaged Wire: office telephone Rj9 cable to mobile headphones]]></title>
<description><![CDATA[<p>Hey!</p>
<p>I need to use my mobile headphones for an office phone ,</p>
<p>I probably need to buy a converter but it isn't available in my country , so ..</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/rbv2L6k2Mei5H2Sq.standard" width="282" height="138" class="hasMenu hasLarge" alt="crwdns2915344:0crwdne2915344:0" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/rbv2L6k2Mei5H2Sq.full&quot;, '', 'width=1343,height=656')" /></div>
<p>what I did was to cut the 3.5mm jack of my headphones and try to connect it with the rj9 cable..</p>
<p>I was able to get the sound working in my headphones but not the mic</p>
<p>when i try to connect the 2 grounds of the rj9 cable to the ground of the headphones , I hear a terrible whistle</p>
<p>so if any one can tell me the exact circuit between them , it will be great!</p>
<p>thanks in advance!</p>
<p>⟐ Answer accepted September 29, 2023 at 11:47 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/710220/office+telephone+Rj9+cable+to+mobile+headphones</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/710220</guid>
<pubDate>Fri, 29 Sep 2023 11:47:47 -0700</pubDate>
</item>
<item>
<title><![CDATA[Damaged Wire: Aluminium cable wire for domestic electric load supply]]></title>
<description><![CDATA[<p>I have recently finished my house construction. In which preliminarily I applied my house for a electric load of 1 KW (commercial) Single Phase supply for the usage of various electrical tools during construction. The electricity board supplied this through single core 4 sq mm aluminum service cable wire connection from the main pole. After I permanently resided to my house I opted for a load increase to 5KW (domestic) supply. But during usage of various appliances in home I found very low voltage often which made running heavy appliances like AC, water geysers and microwave ovens difficult.</p>
<p>Then I filled a request for increase in service wire guage increase.  The board supplied me now with 8 sq mm single core aluminium cable wire. After this for few months everything went good and I got good voltage (~220 - 230V). But recently I started getting low voltage again.</p>
<p><strong>Is this still because of the aluminium cable or is it normal to get low voltage around this time since its peak summer time now?  Is 8 sq mm aluminum wire enough for home if run almost 5000 Watt load?</strong></p>
<p>⟐ Commented May 13, 2023 at 8:11 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/790975/Aluminium+cable+wire+for+domestic+electric+load+supply</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/790975</guid>
<pubDate>Sat, 13 May 2023 08:11:12 -0700</pubDate>
</item>
<item>
<title><![CDATA[Damaged Wire: Help! Sentimental item has 3 loose wires.]]></title>
<description><![CDATA[<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/cKgDjG2knBe25NYl.standard" width="169" height="225" class="hasMenu hasLarge" alt="crwdns2915344:0crwdne2915344:0" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/cKgDjG2knBe25NYl.huge&quot;, '', 'width=900,height=1200')" /></div>
<p>2 red and one black wire disconnected. No idea where they go. I’m assuming I will need to attempt to solder? Please help as this is a very sentimental item.</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/t5dwftmKLa33R6TR.standard" width="169" height="225" class="hasMenu hasLarge" alt="crwdns2915344:0crwdne2915344:0" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/t5dwftmKLa33R6TR.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/bNcZVmOiGIRnHtHp.standard" width="169" height="225" class="hasMenu hasLarge" alt="crwdns2915344:0crwdne2915344:0" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/bNcZVmOiGIRnHtHp.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/cLnHNiyBCQAjoCQQ.standard" width="169" height="225" class="hasMenu hasLarge" alt="crwdns2915344:0crwdne2915344:0" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/cLnHNiyBCQAjoCQQ.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/rtjsnWDnkVWPa3lJ.standard" width="169" height="225" class="hasMenu hasLarge" alt="crwdns2915344:0crwdne2915344:0" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/rtjsnWDnkVWPa3lJ.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/1GPiJTrec6yN3IKe.standard" width="282" height="211" class="hasMenu hasLarge" alt="crwdns2915344:0crwdne2915344:0" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/1GPiJTrec6yN3IKe.huge&quot;, '', 'width=1600,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/45WdDFrQbE1Twmu2.standard" width="282" height="211" class="hasMenu hasLarge" alt="crwdns2915344:0crwdne2915344:0" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/45WdDFrQbE1Twmu2.huge&quot;, '', 'width=1600,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/YqiPBtBkXwDh52HM.standard" width="169" height="225" class="hasMenu hasLarge" alt="crwdns2915344:0crwdne2915344:0" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/YqiPBtBkXwDh52HM.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/56XZHtLRcZ66rXPY.standard" width="282" height="211" class="hasMenu hasLarge" alt="crwdns2915344:0crwdne2915344:0" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/56XZHtLRcZ66rXPY.huge&quot;, '', 'width=1600,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/BsnVvdXiQ2uXSSVy.standard" width="282" height="211" class="hasMenu hasLarge" alt="crwdns2915344:0crwdne2915344:0" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/BsnVvdXiQ2uXSSVy.huge&quot;, '', 'width=1600,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/5T2YNViECd3xK4aE.standard" width="169" height="225" class="hasMenu hasLarge" alt="crwdns2915344:0crwdne2915344:0" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/5T2YNViECd3xK4aE.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/rNfpYwrqESCJvXVc.standard" width="169" height="225" class="hasMenu hasLarge" alt="crwdns2915344:0crwdne2915344:0" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/rNfpYwrqESCJvXVc.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/nFsZDUAc32xSFl2u.standard" width="169" height="225" class="hasMenu hasLarge" alt="crwdns2915344:0crwdne2915344:0" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/nFsZDUAc32xSFl2u.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/DXinQIL4ZF1xMumy.standard" width="169" height="225" class="hasMenu hasLarge" alt="crwdns2915344:0crwdne2915344:0" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/DXinQIL4ZF1xMumy.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/IDPOXv5eCvHRNEPR.standard" width="169" height="225" class="hasMenu hasLarge" alt="crwdns2915344:0crwdne2915344:0" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/IDPOXv5eCvHRNEPR.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/BWIZUobRcwyYgjym.standard" width="169" height="225" class="hasMenu hasLarge" alt="crwdns2915344:0crwdne2915344:0" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/BWIZUobRcwyYgjym.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/RwlPCMfjCuJgpiWq.standard" width="169" height="225" class="hasMenu hasLarge" alt="crwdns2915344:0crwdne2915344:0" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/RwlPCMfjCuJgpiWq.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/K56gcGTFnRNMuyUj.standard" width="169" height="225" class="hasMenu hasLarge" alt="crwdns2915344:0crwdne2915344:0" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/K56gcGTFnRNMuyUj.huge&quot;, '', 'width=900,height=1200')" /></div>
<p>⟐ Commented March 25, 2022 at 7:37 MST</p>]]></description>
<link>https://ts.ifixit.com/Answers/View/725635/Help!+Sentimental+item+has+3+loose+wires.</link>
<guid isPermaLink="false" >https://ts.ifixit.com/Answers/View/725635</guid>
<pubDate>Fri, 25 Mar 2022 07:37:21 -0700</pubDate>
</item>
</channel>
</rss>
