Need to know how to replace the filter for a water filtration system? I am going to show you how to do this so that you can drink clean, filtered water. There is no risk during this procedure and it is simple; no background experience is needed. This is a helpful guide to show you how to replace a used water filter.
Note: Filters need to be changed every three months, otherwise the water will be undrinkable and can pose health risks.
Press the button on the top of the filtration device to release water pressure and let excess water drain.
Unscrew the filter canister using the canister wrench.
Take out the old filter and discard it.
Clean out the inside of the filter canister with soap and water.
Put the new filter inside the filter canister, making sure it goes in properly.
Screw the filter canister back into place using the canister wrench, making sure it's tightly screwed in.
Press the button on the top of the device to release any air trapped inside.
You have now successfully replaced your water filter.
